PDA
View Full Version : Engine Swaps, Tech & Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. 96 teg in 97 civic ex
  2. Mini me swap D16z6 questions??
  3. difference between B16B, B16A, B16A2, B16A6...
  4. Is it safe to remove my CAT converter??
  5. B18C1 Swap
  6. Someone who actually knows what I'm talking about needs to help me PLEASE!
  7. Broken off Valve Cover Bolt On 1992 D16z6
  8. sYNTHETIC oIL qUestions
  9. 1992 D16z6 questions
  10. Compressed air Turbo??
  11. MT6+b-series?
  12. places to find usdm b18c1's
  13. B16A2 problem..
  14. AEM Cold Air Intake Help!!
  15. Short ram Vs Cold Air
  16. Swapped in GSR.... problems....
  17. easy question How do I reset my ecu??
  18. carburated to OBD
  19. anyone with forced induction in CT, please HELP!!!
  20. D15B help
  21. Turbo Fan Works?
  22. whine at idle
  23. Gs-r/b-16
  24. Swapping GSR motor. Few Questions.
  25. Best Engine for Boost?
  26. B Series head swaps compression change?
  27. Keeping my ac with my gsr swap
  28. h22a / manual swap
  29. help see dyno sheet
  30. b18c1 re-build questions
  31. OBD1 or OBD2 GSR motor Which is faster?
  32. buddyclub
  33. `94 Del Sol in Need of Vtec Rocker Arm
  34. 97 b20b into 95 gsr harness question!
  35. SDS EIC . . Do i need a missing link?
  36. Engine acting strange
  37. Motor Swap ?'s!!!
  38. pulleys..
  39. OBD conversion help needed QUICK!
  40. iVtech engines better than Vtech engines?
  41. 95 integra back fired and died
  42. engine lamp =high idle
  43. turbo question
  44. antifreeze leak..
  45. Turbo/supercharged with varied exhaust diameter?
  46. d16y7 noise... valves maybe?
  47. gsr engine into del sol help...
  48. vtec harness
  49. I really need some help with my engine decision
  50. HELP.obd2 convertion...
  51. Engine Code P0107
  52. D16Z6 vs. D16Y8
  53. h22a swap help
  54. Cat Box or Flash ECU?
  55. axle problems...93 B18A in 91 civic
  56. G3.Integra:Engine Check Light decoding ...
  57. Engine Swap Help
  58. Motor Swap Help!!!!
  59. Please post ur thoughts.....
  60. What does "Adaptive Transmission" mean?
  61. Are SR20DET's illegal?
  62. Why do my spark plugs look like this?
  63. Building b16a... need ideas?
  64. head swap
  65. obd1 vs obd2
  66. obd1 vs obd2 parts???
  67. Hybrid H22a Motor? Pic inside.
  68. Enging Knocking 101
  69. Bseries sleeves
  70. Storing an engine?
  71. ? about Honda Element's K24A2 TPS
  72. JRSC B18CR problem
  73. Oil on Spark Plugs
  74. Question
  75. EG B16A swap help?
  76. H22A4 and H23A Compatibility?
  77. HELP!! GSR/EG swap wiring
  78. couple b-series turbo setup questions
  79. problem once again
  80. Honda Vs. Acura compatibility
  81. does this sound complete?
  82. Distributor problem
  83. 96RL egr help needed
  84. 99 Civic HX Error Code P1457 - EVAP canister
  85. radiator hose inner diameter reduction
  86. RPM Issue
  87. Fuel management question
  88. intermediat/half shaft
  89. 5th gear grind at high RPMs
  90. Can anyone help me here.....
  91. Camshafts for B18C1
  92. Water in Exhaust?
  93. High compression engines and boost
  94. would i need to swap?
  95. Toda spec b camshaft daily drivable?
  96. question about 99 motor in 95 civic?
  97. Blue Smoked
  98. ECU question, etc.. PLEASE HELP!
  99. when is it time for a rebuild
  100. Edelbrock intake manifold for D16Y8
  101. 1998 civic cracked heder
  102. b18c1 c5 or b16a2
  103. 94 Accord EX-4 cyl VTEC EGR Ports clogged??
  104. need some help arguing pros of manual over auto
  105. whistle?
  106. iacv....
  107. Bought a Cheapo Ebay Header
  108. bootle neck effect
  109. Not running well...
  110. What Engine Is This... I'm Confused
  111. Jdm b18 into 97 civic EX
  112. Expert Troubleshooter Needed
  113. OBD2 or OBD1
  114. HELMS are back up
  115. B18c1
  116. Piston install
  117. Problem with '03 TL-TypeS baffling everyone
  118. B18C1 and B18C5??
  119. website for "ecu" tech and engine code breaker.
  120. GSR swap...JDM or USDM?
  121. exhaust manifold (red hot)
  122. Cons to turbo an automatic D16Y8
  123. timing belt question
  124. Eg hatches with GSR swaps...
  125. Car wont start! Bad coil? Bad ECU? HELP!!
  126. Accord 94 EX Sedan VTEC main engine bearing problems?
  127. what EXACTLY is the afc hack
  128. Low Idle (Almost Stalls) 99 Civic EX
  129. Help, can't read codes.
  130. Failed emmissions - please help
  131. Optima Batteries...WHY better?
  132. Does an in intake make a difference?
  133. Remove/replace alternator on '91 Integra
  134. Power through my ground wire..why?
  135. need help and info please
  136. b18
  137. Where did you buy your harness?
  138. VTM wire
  139. Vtec Not Functioning Properly
  140. synthetic oil - how mile/km before change?
  141. please help i have a jackson racing supercharger... i have problems
  142. sick engine...please help
  143. Tempest racing or EIP tuning?
  144. Throttle Body 96 Integra
  145. Re: 5th Gen Prelude engine problem...
  146. itr head and b16 block
  147. b16a swap throttle cable question
  148. Seals.
  149. I need d16z6 info of swap into 89 crx hf
  150. CTR Pistons???
  151. Need help from the experts!
  152. rpm always stay high
  153. TROUBLE! Major valve chatter after belt job
  154. B18c Into 94 Del Sol Si....wiring Harness?
  155. Please Help. On Going Problem
  156. how many types of heads are for the B16
  157. 91 accord engine swap????
  158. Undesireable rpm changes
  159. turbo manifolds/keeping AC
  160. o2 Sensor
  161. I need a little bit of help with my H23A engine swap...
  162. I need a little bit of help with my H23A engine swap...
  163. oil pump failure
  164. o2 Sensor
  165. my engine sounds like its deisel pt 2
  166. Cleaning Fuel Injectors
  167. checking vacuum
  168. Any Ideas? Car 'shakes' above ~40mph...
  169. Ahh..screeching!!
  170. Integra Catalytic Converter
  171. Apexi V AFC-II Or Apexi S AFC-II
  172. waterpump replacement?
  173. noob question, cutting hoses
  174. dead sol
  175. Datalog results..........
  176. any had prob with smog in cali?
  177. a Nissan guy aksing a question
  178. Installation of original camshafts Integra Type R on Civic SI (B16A2)
  179. Stuck AC compressor clutch?
  180. Baer BRAKES question!!??
  181. HELP: '04 Civic Sedan - Strange tapping/slight squeak
  182. b18b O2 wiring
  183. Open Exhaust / Exhaust cut out
  184. Type R or GSR fuel rail???
  185. Do I have everything for my swap? Let me know what you think!
  186. JDM Swap problems CODE 6
  187. How difficult is it to change the Stater Cylinoid on a 95 GS-R
  188. Vibration noise under load when engine warm
  189. Does this sound right? d16y8 Q's
  190. K20 in Civic????
  191. i need some advise, can someone help?
  192. turbo downpipe???
  193. Test Pipe or High Flow Cat?
  194. engine swap question
  195. engine swap advice
  196. what causes miss fire?
  197. b18's
  198. 300hp under $4000?
  199. Knock sensor question - Any Ideas
  200. 92 civic 1.5 no start condition
  201. VTEC in all cars?
  202. Mitsubishi Turbo's and different manifolds
  203. auto to manual conversion...?
  204. Please HELP ANYONE
  205. Lack of POWER on B20-R
  206. F22 Engine Compression Ratio
  207. Can Vtec Be Activated to late?
  208. JDM D15B/USDM D16Z6 Comparison
  209. Need Help Installing Head....
  210. Dying Engine Issue
  211. Mini-me ECU help needed
  212. Help!! Just Inatalled JDM H22 in 94 Accord Lx and..
  213. Engine wont start tries to crank
  214. Compression Calculator
  215. z6 swap. Parts needed?
  216. starter relay location in 93 integra ls 5spd
  217. idle
  218. any way to fix a hydrolocked engine?
  219. engine problem 96 integra
  220. JUN 2 cams
  221. simple motor question
  222. Just wanted to wish everybody a safe and happy holiday!
  223. 1988 integra ls
  224. How long does the exhaust really need to be? Muffler inlet/outlet size
  225. Engine help
  226. crazy reving
  227. GSR swap for a 4 dr Civic
  228. Where Has My Vtec Gone? Calling Code 22
  229. car wont stay on
  230. oil leak
  231. Head question
  232. car wont stay on
  233. H22 in a 92 Cx hatch
  234. Price for my stock motor?
  235. Gas Additive Does anyone know about this?
  236. Valve Spring Question
  237. BAR Approval on a K20a2 or jdm K20a...ive searched but still have some questions...
  238. Help me...
  239. Vtec Problems
  240. 92-95 Manual
  241. Help: B18C mods
  242. obs2~obd1 civic ecu swap
  243. engine pressure problems
  244. No Power. Help!
  245. Civic with B18C(SiR-G): questions bout axles
  246. Wideband tuning in PA, weekend of Dec. 19th
  247. pistons and rods ?
  248. clutch went out or clutch cable broken?
  249. Jackson Supercharger Question?
  250. swap in a 88 dx hatch
