help see dyno sheet
Old Feb 18, 2004 | 10:32 AM
96-Turbo-Civic's Avatar
96-Turbo-Civic
BOOOOOOOST
Default help see dyno sheet
I also posted this in the 92+ civic area but I thought others that dont visit that area might see it here and have an idea.
Thanks
Ok as you can see at 5000 to 5500 rpm I am losing alot of HP with that dip. here are my car specs.
D16Y8 @ 9psi boost
f-max (turbonetics kit) using the MF2 fuel controller with the two extra fuel injectors.
JE / SRP forged pistons 9.0:1 compression ratio
Crower Econo Billet Rods
Crower stage 2 camshaft with valve springs and titanium retainers
Greedy Profec B-Spec boost controller
when I am driving and this occurs at 5000 - 5500 rpm it feels like all boost is gone and the car stops pulling hard. But if I take my foot off the gas then go WOT the problem goes away and starts to pull hard again.
another problem I noticed as of yesterday is that the car is detnating coming off the line in first gear only???
I pulled the plugs and they are black which I believe indicates that the car is running way to ritch. Do you think that when I'm taking off from the line it is dumping to much fuel causing the detnation.
I believe the problem at 5000 -5500 rpm is also a ritch / lean problem.
here is a website that talks about the MF2 controllerhttp://www.aquamist.co.uk/cp/mf2/techmf2/mf2tec.html
with this controller I can ajust the amount of fuel at 1000, 2000, 3000 RPM and so on...
any help is appreciated thanks.
Old Feb 18, 2004 | 04:11 PM
96-Turbo-Civic
BOOOOOOOST
I am glad to say that I have solved all the problems at this time.
here is what I did.
The filter had come out of the missing link put a new one in solved the detnation problem.
Bought new NGK plugs.
adjusted the the MF2 controller to be leaner through 5000 - 7000 rpm and that solved the down curve it was boosting and pulling right through all rpm range.
I thought I might be getting to much back pressure in the in the catalitic converter so I made a straight pipe and took out the cat. all pipe is now 2 1/2".
It pulled very hard so I have a big smile again.
Now I just wonder what the true HP is with the drop at 5000rpm gone??? any one got a guess.
96-Turbo-Civic
92+ Civic/EL & Del Sol
13
Feb 19, 2004 09:59 AM
Josh M
Jun 23, 2003 05:02 PM
TheBlurr
Accord
7
Apr 24, 2003 07:43 AM
kris79
2
Apr 10, 2003 09:27 PM
Elusive Designs
Meets & Events
Mar 24, 2003 01:15 PM
