Swapped in GSR.... problems....
Old Feb 20, 2004 | 02:30 AM
EddieK's Avatar
EddieK
Default Swapped in GSR.... problems....
Hey I got the GSR motor put into my EK. Okay here are a few problems. When the car idles it revs by itself from from 1Krpm up to 2Krpm and goes up and down like that. Anyone know what the problem is?
Old Feb 20, 2004 | 06:07 AM
ludeboom's Avatar
ludeboom
make sure you dont have air in the coolant lines near the thermostat housing.
the IAC sensor is regulated by coolant to determine fast idle when engine is cold. there is a bleed valve on the the thermostat housing, use it to bleed air out of the system. usually this is the cause of the idle hunting.
it could also be the ecu/wiring/vacuum.
wat ecu is it p72?
who installed the motor?
obd2 motor?
~boom
Old Feb 23, 2004 | 05:58 PM
eGsr's Avatar
eGsr
User
Check to make sure you have no vacuum leaks. Check all vacuum hoses. make sure every vacuum hose is plugged in or caped off.
twin3037
7
Jun 27, 2003 08:00 AM
98RedGS
Engine Swaps, Tech & Tuning
Jun 17, 2003 11:04 PM
thadon617
11
May 31, 2003 02:29 PM
saber1
92+ Civic/EL & Del Sol
9
Aug 25, 2002 05:04 PM
saber1
5
Aug 24, 2002 05:13 PM
