b18c1 c5 or b16a2
Old Jan 30, 2004 | 11:34 AM
Ammadien's Avatar
Ammadien
Default b18c1 c5 or b16a2
Just want to know best base for turbo setup? i heard b18c5 due to high compression can blow easy without re-done internals, im planning to redo the internals and whatnot but just need to know best base to start with for turbo set up and possibly N20 later. thanks for all your help.
Old Jan 30, 2004 | 01:47 PM
Snoopy's Avatar
Snoopy
been there done that
b18c1 if you'll be changing internals
Old Jan 30, 2004 | 04:43 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
most b series are the same.
compression level are similar ranging from 10.1:1 to 11.1:1
having lower compression gives you more room for error.
it's possible to run turbo on higher compression, but you have much less room for error.
you make more power per lbs of boost with higher compression.
i'd stick with a b18c1 block myself. it's the best medium
if you plan to get a block for the sole purpose of rebuilding it.
get the cheapest b16a block you can find, and build it up.
got money just burning a hole in your pocket, get yourself a dart block, only 1800, you'll need everything, it's just a very bare short block.
Project EVA - The Track Package
Project EVA
Old Jan 30, 2004 | 08:35 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
I would either go b18c1 or b18b if I was going to build it for boost.
SSCivic
92+ Civic/EL & Del Sol
65
Jul 15, 2003 03:49 AM
SSCivic
Jun 28, 2003 09:17 AM
ThaDogg420
Engine Swaps, Tech & Tuning
4
Jun 23, 2003 05:35 PM
CivicRacr
Jun 14, 2003 06:31 AM
JDM02CivicSi
Aug 6, 2002 08:50 AM
