turbo question
Old Feb 15, 2004 | 08:26 AM
dicivicHB's Avatar
dicivicHB
...on Christ's Team...
Default turbo question
i've been wonderin this for a little while now...atmosphere is like what, 7psi?...in a turbo setup...if i ran 7psi on my turbo, is it 7psi on top of atmosphere, or is it equivalent to atmosphere....
Old Feb 15, 2004 | 01:14 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Boost is PSI above atmospheric pressure.
-Harry
AIM: NDcissive
Old Feb 15, 2004 | 07:31 PM
bnuk's Avatar
bnuk
atmospheric pressure is 14.7 PSI so 7 psi of boost is like 50% more pressure
Old Feb 16, 2004 | 01:16 PM
dicivicHB's Avatar
dicivicHB
so if i'm runing 14.7psi in my turbo setup, and i running atmospheric pressure? or am i doubling atmosphere
Old Feb 16, 2004 | 02:21 PM
1stGenCRXer
The only time the engine sees less pressure than atmospheric is when it's normally aspirated, and at part throttle. Boost is pressure above atmospheric, so if your "boost" guage registers anything above zero, it's added to atmospheric pressure. By adding 1 BAR [14.7 PSI] of boost, you're running 1 BAR of boost, but that is equal to doubling atmospheric pressure. For the sake of simplicity, you don't refer to the absolute pressure the engine is seeing though, that's why when your turbo is running 14.7psi, then all you refer to is the boost pressure, and not try to add in atmospheric pressure in with that boost reference, since atmospheric is a constant anyway.
Even when you measure your tire pressure, you aren't measuring the absolute pressure inside the tire, you're measuring the pressure above atmospheric. The reason being is that when your tire is inflated to 35psi, the absolute pressure inside the tire is actually 49.7psi, but there's also 14.7psi on the outside of the tire due to atmosphere pushing back on the tire.
The only time you need to worry about absolute pressure as opposed to differential pressure, is when you're dealing with different atmospheres. Last time I checked, the only careers that did that deal with NASA, and deep sea exploration.
-Harry
AIM: NDcissive
Ivn
S2000
9
Aug 28, 2003 03:43 PM
Dragn
RSX & 02-05 Civic Si
3
Apr 19, 2003 09:50 AM
incublinkus
Engine Swaps, Tech & Tuning
5
Jan 8, 2003 08:17 AM
Ronin
92+ Civic/EL & Del Sol
9
Jan 4, 2003 05:54 PM
91integrals
Nov 7, 2002 04:56 PM
