Please Help. On Going Problem
Old Jan 17, 2004 | 09:57 AM
Diz's Avatar
Diz
Default Please Help. On Going Problem
NEED ALL SERVICE MANUAL FOR 1992 INTEGRA???? DOWNLOAD?
parts department closed! need car today-
PROBLEM NOW:
FRONT PANEL OF CAR WAS TAKING OFF AND WAS HOT WIRED...(LONG STORY DONT' BOTHER)- AND WAS DRIVEN WITHa blown water pump, and with MOST OF FRONT PANEL OFF...IGINITION, WIRES, WERE HANGING OVER EVERYWHERE. ALL THE SUDDEN DRIVEN A FEW MILES THE CAR DIES AND NOW DOESN'T START. CHECK BATTERY ::even bought a new one:: CHANGE THE CRAKCED ROTOR, STARTER......*PULLS OUT HAIR* arghghgh :upset:
PREVIOUS RUN-INS:
BEFORE ALL THIS...THIS BUCKET was SALVAGED (unknown reason) but were damages on front right looking a car. i know the best thing is to blow it up but :mommy gave me this deathtrap:: therefore priceless. IN THE PAST COUPLE MONTHS BATTERY DIED. CAR DOESN'T START, solutaion new battery. worked for a shot while, then blown water pump. problem still persisted one after another. something leaking in water front and back causing mold all inside of car- YEs! this is a huge problem! i know! rotor cracked, distrubitor blown, water pump blown, no electrical power...all this was either fixed or replaced. what else is there? no warning Signs, just failure to start and stay that way- SOMETHING IS NOT CATCHING BECAUSE THE DAMN THING WONT EVEN START NOW. could it be wiring?
SO MANY QUESTION...LOOKING FOR ANSWERS8 please help! DESPERATE FOR SOME SANITY-
Old Jan 17, 2004 | 11:35 AM
Kestrel's Avatar
Kestrel
Push to shock!
Slow down there....
So when you turn the key, what happens exactly? Does it crank and then start and then die, or does it not even crank?
There are two basic things that run the car, spark and gas. It sounds like you've changed out most of the electrical stuff, so I'm assuming you've changed out plugs and plug wires. Another thing is to look for a disconnected or corroded ground wire or something like that. Also, have you checked that there is fuel going into the cylinder (or your fuel pump)?
Sorry for this really general answer, but it was pretty hard to read your post.
Old Jan 17, 2004 | 05:36 PM
Diz's Avatar
Diz
IT CRANKS BUT WONT START. THERE ARE TON'S OF UNKNOWN WIRES. I HAVE A HEADACHE JUST LOOKING THEM. I DONT KNOW WHERE TO BEGIN TO LOOK FOR THIS PROBLEM.
Old Jan 19, 2004 | 08:19 PM
PHiZ's Avatar
PHiZ
BOOST GOD
poor honda =(
-PHiZ
Old Jan 19, 2004 | 09:05 PM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
Take this car to a mechanic. Pronto.
It sounds like you have a MAJOR problem on your hand - it could be a wiring problem, a mechanical problem, or a combination of both. It's obvious you don't know what you're doing as far as the wiring is concerned, and running the car with a blown water pump... well, not a good idea. Without really detailed pictures and a much clearer, thoughtful detailed analysis of the problem, none of us here will be able to help much.
If this car is really "priceless" to you, absolutely run - do not walk - and take this car to a dealer. Maybe an independant mech who specializes in Honda/Acura and can do complicated electrical work.
Old Jan 21, 2004 | 06:12 PM
civic1988's Avatar
civic1988
hey this might be a pretty wierd answer... but you know the fuse box under the hood make sure the fuse that is for the ecu is not blown.... if it is blown you will not have a spark therefor will not start car.... had that problem before... thank god my dads a mechanic... n e wayz update .... peace
www.chivicricacing.com
chivicricer :thumbup:
