B Series head swaps compression change?
Old Feb 18, 2004 | 09:14 PM
99Accolude's Avatar
99Accolude
heavy cars Rule!
Default B Series head swaps compression change?
I heard if you change heads on b series motors like b18c block with b16 head makes different compression than b18c block with b18c head. is this true. if so whats the estimated compression on a b20b block with b16a head?
Old Feb 19, 2004 | 12:59 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
B16 head on the B20 block is actually the preferred setup for the CRVTEC changeover and isquite common because of the raise in compression level. As for how high it puts your compression I am not entirely sure but I believe it puts it at 10:1....I may be wrong on this but I seem to remember this being the number it came up with.
Old Feb 19, 2004 | 04:43 PM
99Accolude's Avatar
99Accolude
heavy cars Rule!
Whoa so if i get arias 10:1 compression that would push my compression to 11:1. thats noo good. cause im supercharged so i would only be able to boost like 5 pounds tops, right?
Old Feb 19, 2004 | 07:39 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Well I would double check because I may be wrong on that number.....I know it was somewhere around there but very well may be 9.5:1
I wish I could get ahold of a friend of mine because he has all these numbers set to memory.
Old Feb 19, 2004 | 11:16 PM
99Accolude's Avatar
99Accolude
heavy cars Rule!
oh ok thanks alot . let me know if you do find out
Old Feb 19, 2004 | 11:47 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Not a prob I will ind out for sure tomorrow and post it up for ya.
Old Feb 20, 2004 | 10:46 AM
Snoopy's Avatar
Snoopy
been there done that
assuming everything's stock, a b16 head on a b20b block will come out to around 9:1 cr. http://www.c-speedracing.com/howto/c...c/compcalc.php
Old Feb 20, 2004 | 11:16 AM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Good find Snoop definitley going to my favs list
I guess I was further off than I thought h:
Old Feb 22, 2004 | 09:59 AM
B16Drag's Avatar
B16Drag
Sup Dawg!
Actually you were almost right on
Using that website
change the head to B20, and then change the pistons to B20
Compression Ratio for B20b/B16 head is 9.3:1 and for B20z/B16 head is 10.2:1
HLD_Civic
92+ Civic/EL & Del Sol
19
Jul 23, 2003 12:10 AM
rustybody
Apr 16, 2003 07:15 AM
djsonic
5
Feb 23, 2003 03:36 PM
