B18C1 and B18C5??
Old Jan 27, 2004 | 11:09 AM
TotalVelocity's Avatar
TotalVelocity
Default B18C1 and B18C5??
What is the difference in the ITR block and the GSR block....anything signifacantly different that would stop me from buying the GSR block and poutting an ITR head on it??
Old Jan 27, 2004 | 02:52 PM
dustimus's Avatar
dustimus
Better golfer than you
slightly higher compression pistons, lighter connecting rods and the stock ITR's crankshaft was made wtih some kind of heavy duty steel and was also semi balanced. The b18c1 isn't a terrible block, it came with oil squirters to cool down the pistons and a block girdle. If you can find a cheap c5 block go with that, but a c1 is fine and is gonna be cheaper.
Old Jan 27, 2004 | 02:54 PM
TotalVelocity
right but could i just buy a C1 block and put an itr head on it ??
Old Jan 27, 2004 | 02:58 PM
Snoopy's Avatar
Snoopy
been there done that
you could, but would have lower compression
Old Jan 27, 2004 | 02:59 PM
dustimus's Avatar
dustimus
ya you could if you wanted to, its basically a b16 head with a slight port and polish job, better cams, lightweight valves, single port intake manifold, and i think a 62mm throttle body. It all depends on what your lookind for, if you want to turbo it, Nitrous, or your goin naturally aspirated.
Old Jan 27, 2004 | 03:00 PM
TotalVelocity
not if u change the pistons right??
TotalVelocity
i want to turbo it
Old Jan 27, 2004 | 03:02 PM
dustimus's Avatar
dustimus
hum this is a pickle, it would be cheaper to buy a c1 block and put a itr head on it, the compression would be lower and a little better for your turbo. Do what you want man, you could also buy a complete b18b longblock and spend the extra money from the swap on a nice turbo kit
edit: what are you driving now???
Old Jan 27, 2004 | 03:04 PM
TotalVelocity
i could change the compression though with different pistions right??
Old Jan 27, 2004 | 03:08 PM
dustimus's Avatar
dustimus
ya you could, you could buy forged pistons that would either lower your compression or higher it. But with forged pistons it would be a good idea to buy better rods too
