B18C1 and B18C5??
Old Jan 27, 2004 | 03:09 PM
TotalVelocity's Avatar
TotalVelocity
yeh thats understandable
Old Jan 27, 2004 | 03:10 PM
TotalVelocity
now i just need to find somewhere to buy the block
Old Jan 27, 2004 | 03:11 PM
dustimus's Avatar
dustimus
Better golfer than you
if you search in this forum on differences between b18c1 and b18c5 you will come up with tons of info on the differences, but if you drive a LS/RS/GS/SE integra now, dont waste your money on a swap, turbo the b18b
Old Jan 27, 2004 | 03:13 PM
TotalVelocity
yeh I only see the difference is in the head gasket
Old Jan 27, 2004 | 03:17 PM
dustimus's Avatar
dustimus
between the b18c1 and the b18c5, no there are many more differences
Old Jan 27, 2004 | 03:18 PM
TotalVelocity
in the block???
Old Jan 27, 2004 | 03:20 PM
dustimus's Avatar
dustimus
Originally Posted by norcalsmoka
slightly higher compression pistons, lighter connecting rods and the stock ITR's crankshaft was made wtih some kind of heavy duty steel and was also semi balanced. The b18c1 isn't a terrible block, it came with oil squirters to cool down the pistons and a block girdle. If you can find a cheap c5 block go with that, but a c1 is fine and is gonna be cheaper.
The block includes all of that
Old Jan 27, 2004 | 03:22 PM
TotalVelocity
im gonna change the rods, pistons, and crank shaft in the C1 block if i get it
Old Jan 27, 2004 | 03:26 PM
dustimus's Avatar
dustimus
:thinking:
no you wouldnt really need to do that, if you have the money go ahead and do that, but your gonna need more money for the swap/turbo/tuning and other misc crap. New rods/pistons/ and a crankshaft is gonna cost you a hefty amound of cash, and from what it sounds like your not goin to be running a terrible amound of boost, the stock b18c1 is fine for mild boost
Old Jan 27, 2004 | 03:27 PM
TotalVelocity
im doing all the labor myself
