B18C1 and B18C5??
Old Jan 27, 2004 | 04:01 PM
  #31
TotalVelocity's Avatar
TotalVelocity
i know almost close to noithing about turbos
Old Jan 27, 2004 | 04:02 PM
  #32
TotalVelocity
im doing as much research on engines right now..
Old Jan 27, 2004 | 04:12 PM
  #33
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
The ITR head is also not a great choice for boost. The cams have a longer duration for the N/A app and will not be optimal for boost.
Just get a B18C1 and turbo that. Go for a MaxRev/RevHard/Precision T3/T04E kit.
You are going the WAY long way around just to use an ITR head. You can get a better head by using a GSR full swap and porting the head out. h:
Old Jan 27, 2004 | 04:15 PM
  #34
TotalVelocity
a GSR swap would be a lot better then to use.
Old Jan 27, 2004 | 04:27 PM
  #35
TotalVelocity
What type of transmition is good for this type of engine?....and setup
Old Jan 27, 2004 | 05:05 PM
  #36
westcoaststyle
GSR, some will say LS, but I've had both and GSR is better.
Old Jan 27, 2004 | 05:17 PM
  #37
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
GSR is fine until you're up around 400+, then you wish you had longer gears
-Harry
AIM: NDcissive
Old Jan 27, 2004 | 05:35 PM
  #38
westcoaststyle
true... true...
Old Jan 27, 2004 | 06:53 PM
  #39
TotalVelocity
what what does a short block consist of???
Old Jan 27, 2004 | 06:56 PM
  #40
1stGenCRXer
Block, crank, pistons, and rods.
-Harry
AIM: NDcissive
