View Full Version : CRX & Pre '92 Civic
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. WTB 86-87 CRX Si rear spoiler
  2. Axle problem?
  3. Dashboard 1988 Honda Civic
  4. 90 CRX Si
  5. Coil blaster help
  6. Forgot something.
  7. Radiator fan?
  8. MSD distributor, 95 JDM B16 Vtec, 91 HB Si Civic
  9. Mudguard?
  10. Big ecu or wiring problem
  11. I figured it out
  12. Throwing CEL: code 17
  13. 90 civic 4 speed problems
  14. Best CR-X Setup
  15. crx sunroof how to?
  16. can anyone help
  17. crx lip kit?
  18. jdm front end
  19. 91 hatch window regulator ?
  20. Dead dash
  21. 91 Civic DX D15 motor?
  22. buiilding my first honda.need advice
  23. Need help/advice H22 swap into a CRX
  24. Wheel Off Set?
  25. Starter 1 Gen B16
  26. help with hydro tranny
  27. 84 crx issue
  28. 88-89 dash removal for 88-89 cluster with tach
  29. Cap and Rotor?
  30. Transmission possibilities...
  31. need advice on a d16a6
  32. need help wit civic hb clutch issues
  33. 90 crx hf hesitation up to around 2500 rpm
  34. courtesy light
  35. looking for a d16
  36. on a 86 crx can any one tell me how tall the spacers are under the fuel rail
  37. crx si with a zc axels broke
  38. Lighting Helper arrived!!
  39. cps sensor issue
  40. Universal Carbon Fiber Diffuser for sale
  41. Where do you get your Genuine/OEM Honda Parts?
  42. 1 Gen B16A ?
  43. 90 crx-si seeking parts
  44. Headgasket R&R questions
  45. hydrolic converion into an EF?
  46. 89 CRX SI sunroof PLUG?
  47. crx project
  48. help identifying motor year
  49. GSR gauge cluster swap
  50. What Fuel Pump?
  51. Clutch will not engage..
  52. Fuel Filter/ Fuel Pump?
  53. 90 crx si
  54. 1990 crx si
  55. Isn't a Civic Si & CRX Si front rotors/pads same??
  56. Transmission identification
  57. No spark condition....need advice....
  58. D16z6 build Help please..
  59. SiR headlights?
  60. Limp mode!!!!! Help!!!!
  61. Introduction my self
  62. 1990 honda civic dx conversion to a 2000 honda civic 2 door si
  63. tach won't work after swap
  64. 1990 CRX Break Lights Not Working
  65. 1990 civic tranny problem HELP
  66. KYB GR2 or Tokico Blues?
  67. I have 2 ??s
  68. rebuild or not to rebuild...
  69. Need Help!!! 91 Hatch With D16Z6 Swap!
  70. 91 Si Allignment ??s
  71. Aren't CRX & Civic Shocks
  72. wire tuck
  73. zc engine picked up and starting the build
  74. Rust repair panels for 86 CRX
  75. fenders, and wheel liners
  76. 91 Civic Si Need Help Bad !!
  77. Steering Rack Problems
  78. 86 CRX Si PFI vacuum line routing ????
  79. help!!!
  80. What does the JDM EF ?
  81. When Should You Clean?
  82. 91 CRX Si Special Edition w/ 93 Integ GSR motor - Carputer and Hondata done!
  83. Can a Teg?
  84. Update on Emissions & Thermostat?
  85. I am doing a dpi to mpfi swap 20 my 91 crx need a little help
  86. Need tranny help?
  87. hey guys im having problems with my exhaust fumes
  88. What's The Best Way ?
  89. want to know why?
  90. help please, Ignitin switch issue?
  91. duel carb crx
  92. cold start
  93. High Idle lot's of smoke new hg
  94. starter issure
  95. Z6 into 90crx?(EF?)
  96. crx head bolts reusable??????
  97. crx parts??????
  98. Help!
  99. Honda Civic Lsi 92 Running problems?
  100. I have a problem with my 91 SI..
  101. 1GEN B16 timing belt?
  102. crx hf w/ b18 help
  103. starting up engine problem
  104. headlights honda crx 89
  105. just want to make sure
  106. cable clutch loosing stiffness
  107. going green
  108. Anyone Know?
  109. 88 crx parts
  110. go back original or after market
  111. Rotor Screws?
  112. very confuse,b16,b18,b19,b20,jdmb16
  113. performance parts
  114. camber
  115. great mpg check this out!!!!
  116. crx with b16 dohc vtech
  117. 36 people look at post but no answers
  118. si-hf tranny swap
  119. Spark? Check Fuel? Check Start? No WTF!!
  120. starter issue
  121. 84-87 civic crx header panel
  122. 90-91 crx wiring harness in a 89 crx?
  123. adons b and c pillar
  124. dx and si speed sensor difference?
  125. engine serial number resource?
  126. 1990 si tranny problems
  127. Can someone tell me??
  128. Help!! Vacuum leak...or something
  129. your expertise needed!!
  130. 91 hatch cluster info
  131. Failed Emissions Again
  132. Anyone with opinions/testimonials on Koni's new Str.t shocks...?
  133. Should I try to adjust my carb on my own?
  134. 86crx hf trany in a 85 crx si?
  135. Removing CD player and speakers from 91 civic LX
  136. 91crxDX what tranny can i use?
  137. No more ugly duckling!
  138. 91 Si failed emissions?
  139. ? about a swap
  140. gas
  141. parts: starter relay and clutch switch
  142. Stolen civic
  143. I kept blowing fuses for my turn signals...now it doesn't work at all
  144. what's the problem
  145. 91 CRX Si Special Edition w/ 93 Integ GSR motor
  146. crx stalling, Electrical problems? Bad distributor?
  147. air fuel ratio
  148. aftermatket intake manifold
  149. Code 9
  150. my crx..new to the forum..
  151. 1991 Civic 1.5L Rear Main Seal Replacement
  152. thud sound
  153. 91 CRX hood fit anything else
  154. how to identify hf tranny 88 crx
  155. wireing diagram
  156. d16a6 head on a d15b7 block
  157. crx h22a redtop
  158. D4 blinking after engine swap on '96 Civic
  159. Driving over 200,000 miles
  160. I have some questions about a turbo kit
  161. 89 Civic Si - CEL code #5, dies after 20 seconds
  162. the difference is???
  163. need assistance...
  164. Has this ever happened to you?
  165. upper control arm anchor bolt
  166. CRX Si GSR Swap questions, please help
  167. Front brakes overheating....Need help
  168. Crx swap: opinion needed
  169. Will this fit?
  170. rear suspension
  171. front motor mount ?
  172. CRX rpm problems.
  173. 89 Honda Civic tail light fuse keeps blowin??
  174. problem going on its like its bogging
  175. will 92 integra cluster fit 90 si
  176. Never ending REX
  177. Niagra 14 CRX meet pics
  178. single tranny
  179. Need help with a 90 CRX, A mystery to me, Maybe you can help solve
  180. starting issue 90crx
  181. 91 Civic Bogging Issues
  182. Motor and Trans Help?
  183. suspension swap for crx
  184. need help on gauges
  185. 91 civic 1.5 wont start just chuggs
  186. Fuel Injection Relay Location?
  187. SSR MK-III's
  188. dx or hf?
  189. Clutch won't disengage.
  190. Sir2 B16 In A EF?
  191. Cold Squeal
  192. Engine Compartment Fuses ??? 87 Si
  193. Bushing Interchange ability
  194. Brake problem
  195. CRX Help
  196. Gauge cluster problems-Will this work???
  197. Crx b16a Trouble shooting?
  198. code 17
  199. 91 civic no start ( tech chime in please)
  200. Radio Help
  201. idle revs up and down
  202. Something blew, maybe a seal?
  203. EF9 civic from malaysia, with EF8 crx front
  204. Air conditioner
  205. brake lights stay on
  206. Problem with stereo system
  207. Moonroof for '90 HB?
  208. omg clutch
  209. No power to ANYTHING good battery
  210. crx bumpers
  211. 1989 civic TPS/TAS
  212. looking for....ugh...ZC motor
  213. Is there a rebuild kit for a 1986 HF carb motor
  214. freeze12
  215. 86 Civic DX Wagon 1.5L NEED HELP!
  216. rims
  217. Dohc Zc
  218. EF Hatch vtec wiring??
  219. A/C compressor from other models?
  220. What's some sites ?
  221. Electronic guru needed: wiring D15B2 from scratch
  222. 89 Engine Swap to Acura
  223. Wanted:: ECU/wiring for 88-91 DX 1.5
  224. Crx electrial problems
  225. fuel rail leak
  226. New guy needing engine ID help
  227. crx heater control in hatch
  228. 88 hatch
  229. D16a6
  230. starting problem
  231. Odometer & Climax control light bulb !
  232. just bought a ukdm cluster will this work on a usdm?
  233. Swap options for a 1st Gen CRX
  234. Removing rear bumper on 91 Civic hatch
  235. B16 start up
  236. Crx b16a1 axles and clutch
  237. Spring help
  238. b16tranny rebuild
  239. 88 crx short shifter to a 87crx
  240. question about 89 crx
  241. h22 into a 90 ef civic, what do I need besides the obvious?
  242. 86 CRX Si bogging/hesitation/staggering
  243. B16 Tranny
  244. servicing a 89 honda transmission
  245. temp gauge sending unit
  246. Engine Help
  247. Fuel gauge problems
  248. 89 crx engine swap help
  249. What do i need for a B16A1 swap in a 91 crx Si
  250. Alternator in 91 Civic?
go
