tach won't work after swap
1991 CIVIC SI
hello there,i just finished my swap and my tach wont work it dont even move at all.ive looked over every thing and cant find out why.the speed omater works just not my tach...so if any of you can tell me something i have might overlooked i will apperceate it
check your tach wire. the tach wire in the engine bay will be towards the left side of the tower strut. Its a 2pin connector with a rubber boot on it. If you did a swap, run a wire from the cluster through the firewall, and tap into this wire. this will ensure the tach will work.
1991 CIVIC SI
i dont have any pics, but its fairly simple to find. It will often be on the left side of the engine bay at the strut tower. It also may be on the right side. BUt if you did a direct swap, make sure you didnt miss a connection.
