timing marks
Old Feb 14, 2011 | 01:31 AM
ohfelecia's Avatar
ohfelecia
Default timing marks
how to locate timing belt marks on timing cover on 1986 crx
Old Feb 14, 2011 | 09:49 PM
ChrisS's Avatar
ChrisS
I guess, you pulled the head to replace the head gasket or do other work.
Basically,
-get piston #1 to top-dead-center (TDC, top of the stroke; there's also a red tick mark on the main pulley and a gun sight the points to it on the front of the engine)
-look at the cam sprocket (there should be an arrow pointing out from the center near one edge, and two tick marks +90 and -90 degrees)
-the arrow should point up 90 degrees to the head gasket surface
-the two tick marks should be parallel to the head gasket surface
