90 crx d15b2 swap sohc zc vtec motor mount
ok, so Im swapping out my stock d15b2 dpfi for a sohc zc vtec mpfi need wire diagram or step by step directions for wiring? and the motor mount does not line up wtf???( 1 motor mount 3 transmission mounts duh!!!) [driver side mount] what mount should i ask for at the parts store? WHAT WORKS????? THANKS ALL YOU G-MONKEYS!!!! ALSO, I already have p28 ecu, jumper harness, ect. .. if you want to or need to see pics to answer ?'s please ask i will post LIKE NOW!!!!!!!
thanks alot jilicrx, i thought that at first!!! then changed my mind and figured i could just find a mount so i put it in and blocked it up, now i realize rushing a project is stupid ( im puling the motor back out tomorrow) swapping the mount and gonna do the water pump, timing belt and tensioner!!!! just so eger to hear it run!!!!
