Using DC2 rotors on 91 civic si ?
Whats good everybody. I wanted to ask a few ?s My 1st is im bout to replace my rotors on my DC2. I wanted to use my DC rotors on my 91 EF Civic Si. Will these work & what parts needed to make work or any other vehicle? I'd like to have a stiffer brake pedal when applying brakes.
Thanks
any advice appreciated
Thanks
They won't work. The rotors are bigger and would need the calipers to compensate, which won't bolt straight up to the EF steering knuckles.
If you want to do a reasonable, straightforward brake upgrade, do what I'm doing next weekend: '91 Civic EX sedan brakes. The sedan calipers bolt right up, plus the rotors and pads and bigger. The brake booster's are the same for Civic Si/EX sedan, so you just need the EX master cylinder.
pacific dave, let me kno how brakes feel when you do swap. I like to do that one day, but right now trying to get civic fixed. My TB might have broke. If the belt is still attached to the cams my belt still good to go.
post a pic when you finsh swap.
Thanks
Thanks
In the end it won't work unless you get the correct steering knuckles. I may do this correctly sometime down the road, but for now I'm just getting rebuilt stock calipers since my right front is failing anyways.
