I am doing a dpi to mpfi swap 20 my 91 crx need a little help
Old Jan 25, 2009 | 10:28 AM
WEMERICK1983's Avatar
WEMERICK1983
Default I am doing a dpi to mpfi swap 20 my 91 crx need a little help
I am do a swap from dpi to mpfi and i bought a kit to do so off line and the guy said its everything i need but i have filling its not this is what it come with and i need to know what else do i need. Si intake with throttle body
si injectors with resister box
si ecu and wiring harrness
my maion questions is do i need the si dist. And what else i need please help me.
Old Jan 26, 2009 | 07:00 AM
jlicrx's Avatar
jlicrx
you need the 88-91 CRX Si, 88-91 CRX HF, 89-91 Civic Si or 90-91 Civic EX distributor or one from 4wd wagon with D16A6 engine
is the wiring harness that you purchased, a DPFI engine harness that has been converted to MPFI or is it just an Si harness? if it is just an Si engine harness, you will need to use the DPFI engine harness from your car and convert it to MPFI using the Si harness for parts - the Si harness will not work in the DPFI car
did you get a fuel line that goes from the fuel filter to the fuel rail?
if you have to convert the wiring for MPFI, use this:
http://www.fourthgenhatch.net/mpfi.html
