- Colors for Various Model Years
- How can I make my GSR tougher + faster?
- motor mount Question
- b18a problems
- dual bend short shifter
- Fan Wont Cut Off
- Neg Press test,
- Noise is killing.
- 99 integra b18c1 tranny
- what are some light weight rims?
- car smoking
- H&R Springs-race or sport?
- sway bars
- Over Kill or A OK
- HID effect on halogen?
- good n/a and turbo exhaust?
- RS-R GTII exhaust
- p30 flywheel in GSR?
- top speed on GSR??
- halogen or hid kit???
- Integra wont crank
- intercooler
- Clutch Brand??? Need suggestions
- HELP!!! Shift Lock & Brake Light!!
- fuel pressure regualtor
- Thinking of buying a salvaged / wrecked teg???
- Help with clutch
- Engine stall after downhill
- projector headlight w/ HID??
- Swap to GSR or Type R
- Ls
- Integra LS Special Edition
- 90 Ls\Vtec Swap
- Ex-Honda owner obtaining an Integra
- Problems with a recently swaped ls to gsr obd2
- tying to get an exhaust
- HELP THErmostat maybe ???
- best exhast?
- Serious issuses..need some REAL tech advice..
- 3rd gear popped out
- need a carfax ~~~URGENT
- Not sure if I'll rub, need your guys' help
- Check Engine light coming on and shuting down car.
- Buying a '94 GS-R
- Sound while braking
- Help
- How about a round of applause for me :-)
- obd2 p75 ecu
- need help finding part number (related to brakes)
- Suspension ?
- 94 LS bumming
- Looking for opinions
- holes in the hatch
- Integra wont start!
- g-racing wheels?
- need help choosing
- Tough decision
- ECU Help
- Engine Swap
- Header gasket
- Question for all that are wise & knowledgable?
- which spark plugs to use for FI applications?
- Would u buy a 92 integra gs-r?
- Crome Pro software
- Thermostat and Fan Problems Please help
- Suspension setup opinions.....
- Dc4 Vs. 4th Gen Lude-----what To Buy
- back pressure
- injen intake
- which is it says Mr Pepboy
- dome light is MIA
- Vlave Adjustment on '91 integra
- Just Bought Turbonetics Turbo
- ´90 teg & ALB or ABS (question)
- 98 Type R integra, What is the biggest turbo it can take?
- hondabond question
- re-painting my car
- would this make my cel pop
- Suspension
- weirdness...
- Coil Springs
- Headlight problem
- 94 Acura Integra Exhaust
- can someone give me that link
- heating problems with turboed teg?
- 1988 acura integra ?'s
- Header & Exhaust-Greddy
- scraping noise after brake job...
- preparing for poly bushings install
- Leaky Hatch
- air tube for cat?
- Need help on tire size
- digital boost or manual boost
- Im a Newbie!!!
- lsvtec head comparison Q's
- rim offset
- ebay parts
- overheating problems!!!!
- a simple quick question
- Engine startup troubles
- My car is still running bad
- A/C smells like burnt plastic!
- Ls Pulley
- un-lowering
- painting the skirts
- 90 Teg
- Death rattle idle + overheating + no heater
- jdm b18 ecu question
- The New Guy
- Should I buy?
- Replacing Brake Light Bulb
- Turbo Manifolds
- Intercooler size?
- weight of adr suko's
- Need lowering shocks
- 17inch wheels on205 50 15?
- how much to lower
- 90 integra still wont start?
- radiator problem....
- changing a starter
- 94 integra frontend to 99 integra front end
- Turbo Help! - 95 GSR
- probably a repost....
- Integra Pix, ohh so sad.
- floormat question
- This will make you cry!!!
- shock mount bushing greasing...
- STEERING WHEEL REMOVAL! Help plz
- Noobie Questions!
- axle question
- spring question
- Hey, FatMat users
- Swappable manifold parts??!?!
- pics of itr on jdm rims?
- climate control question
- ABS diagnostics for a 96 Gsr
- Upper Ball Joint Question
- ecu
- 3rd Gen Speaker Install
- times
- temp guage
- I Need to replace my cv joints
- pistons
- 94 integra horn relay
- can i use a 89 integra distributor on 91 integra motor
- 92 integra gs sedan 1/4 mile time
- wheels/tire ?
- Brake Caliper Paint
- Integra ls Question!!
- IS THIS it
- all motor
- 94 accord ex auto vs 92 interga gs sedan auto
- fitting finders on my 90 teggy
- Transmision
- Removing Gaskets??
- 13 sec integra???
- Blox 21mm rear sway bar
- Price for a GSR engine and tranny
- what is normal operating temp?
- Bolt Ons For Ls Special
- i wanna make my car faster
- Not enough Fuel, or not enough spark???
- Range for autometer oil temperature sensor gauge
- water pump, belts.....any performance parts while I am at it?
- Seat Belts Beep And Light Do No Turn Off 93 Ls
- Excessive break dust on one wheel
- Electrical Going haywire!!!!! HELP!!!
- 94 integra to get B16a Swap.
- ls into ls vtec.
- 92 GSR - Advice?
- b18c5
- this one is way out there
- which one
- Value of a 97 ITR ???
- turbo kit
- cam journal bolts
- Any Difference In These Rads.?
- Custom Charge Piping
- Turbo question
- Hatch Tray Cover
- speedometer help
- *rant* Brakes suck
- i need help to buy a integra 95 4 door
- gauge cluster removal
- Some n00b questions about maintainence (gonna ship my car out of the country)
- Headlights, HELP!!!
- Tint allowance
- Who makes the best intake mainfold.
- b16a2 in my teggy
- Bone stock gsr 1500$ what to do?
- Got some Spoon sw388s
- timing redone but still having soem problems
- 1st gear lock out?
- ABS Code 1
- Car Alarm!
- help
- Weird Electrical Behavior
- 5 lug conversion
- 88' Integra RS 5 Speed......Hesitation Prob.
- service info
- Rocker panels
- Roll Cage Pics
- Getting my obd1 p75 chipped...what sensors to kill?
- looking to get your radio reception back?
- I may be going to the dark side...Testing waters on the GSR
- G2 and G3 strut/tie bars compatible?
- 01 gsr s2 im tb wtf???
- Where can I find a type R front spoiler lip
- Suspension Help!
- Ebay Screws up once again! Please Help!
- code 3, 14, 16
- Problems!?!?!
- Carfax
- How much should a 1st generation lip cost from dealer?
- 99' integra dist rotor
- 1990 Integra wont start
- annoying squeak
- LS VTEC Rod bolt HELP
- can anyone get carfax?
- I need Some Help With my car "Missing"
- Header question
- Maintenance Reqd Light Is Flashing
- running on 3 cylinders...
- 91 w/ 92-93 bumper
- What the hell...here we go again.
- Who makes the best header for 98 GS-R
- no spark
- Weekend Horror!!!!!!!!!!!
- 02 sensor situation
- Steering gear boot replacement question???
- fuel filter
- Sensor by crank pulley
- turbo with stock cat
- Reving W/ No Gas
- quick ECU question for JDM swap
- mid-90's integra vs Accord
- Can someone help me on how to change my engine mounts and motor mounts
- can i get a vin check
- car is running crappy
- My GSR's transmission self-destructed this morning...
- Please Help Me!! Car Wont Start
- best way to clean/engine flsuh u r teg ;` 0
- I'm replacing my wheel bearing today.
- New video of my R motor :)
- Custom exhaust materials
- Help w/ b18c werid noise
- Tweeter mirror mounts
- t3/t4....63ar or .48ar?
- another exhaust question thread..
