Range for autometer oil temperature sensor gauge
Old Feb 1, 2006 | 03:39 PM
carta79's Avatar
carta79
Life after death
Default Range for autometer oil temperature sensor gauge
I'm planning on boosting the LS. What range is recommended for an oil temperature gauge? I have no idea what the oil temperature can reach.
I was also planning on going with a Moroso oil pan which includes two 1/2 NPT bungs for plumbing turbo oil return line and oil temperature sender. Does anyone foresee fitment problems?
Here are the short sweep electric oil temperature gauges I'm planning on going with.
Notes:
Includes 1/8" NPT Sender.
Air-Core meter movement.
Includes 3/8"" NPT adapter/fitting.
Includes 1/2"" NPT adapter/fitting.
If mounting in a steel pan, model 2260 bung in the Accessories Section is recommended.
File Type: jpg
File Type: jpg
Old Feb 1, 2006 | 06:58 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Get the higher of the two. Mine can get up to 240 degrees on hot days, so it would be good to have a little more room.
If your purpose is to get the moroso pan just for the threaded bungs, look into a sandwich adapter first. I got mine for $50 and it works very well.
Old Feb 2, 2006 | 05:20 AM
carta79's Avatar
carta79
Life after death
Thanks for the reply! :goodjob:
How do you have your gauges and lines set up? Did you tap your stock oil pan for the return line? Forgive me if I'm wrong, does your oil temperature gauge and oil feed run off this sandwich adapter. I don't know much about this adapter.
Old Feb 2, 2006 | 05:30 AM
reno96teg's Avatar
i wouldn't mind getting an oil temp. gauge and an oil pressure gauge just to monitor the engine in general. too bad there's no way for me to do that without looking ricey..
Old Feb 2, 2006 | 05:42 AM
carta79's Avatar
carta79
Life after death
So do you think the gauges I picked out are ricey. :sad:
Old Feb 2, 2006 | 05:51 AM
rugsr's Avatar
rugsr
How do my taillights look
I Think There Good. Do It
Old Feb 2, 2006 | 06:11 AM
reno96teg's Avatar
no no, those look nice and clean.. but i have 0 engine mods.. so someone would point out the gauges and go, "why?" i'd say, :dunno:
:chuckles:
Old Feb 2, 2006 | 06:32 AM
carta79's Avatar
carta79
Life after death
Ok good, I needed some feedback on the appearance of the Z series gauges as well. I'm off to summitracing.com where I shall order one 140-300 oil temp. autometer gauge. Thanks fellas!
Old Feb 2, 2006 | 08:55 AM
:chuckles:
well damn guess im ricey then the first thing i did when i bought my teg was put on a oil pressure gauge...i cannot stand a vehicle without a oil gauge. quick and easy way to verify everything is ok...
Old Feb 2, 2006 | 08:58 AM
Provocateur
On permanent hiatus
I used to have them teed off at the back of the block where the oil pressure sender goes, but I was scared it would snap off inside the block, so I got a sandwich adapter. It has 3 ports, I believe, and I have my oil temp gauge and oil feed line running from it.
Greddy and Golden Eagle both make them, but I went with the Greddy because it is like half the price.
