injen intake
Old Feb 8, 2006 | 06:50 PM
joflo95'ls's Avatar
joflo95'ls
Default injen intake
all right peeps, i need some directions for installing an injen cold-air intake for a 95 LS. bolt for bolt if possible.post pics if you can. thanks for all ur help. oh ne-body have an rs-r exhaust on their car or an hks exhaust, if so send me some pics and sounds samples if you have them
PEACE
JOJO
Old Feb 8, 2006 | 07:28 PM
Driverman5777's Avatar
Driverman5777
Well the intake is very, very simple. U first need to unbolt the air filter, then the filter box ounting bolts, which are easy to see. Then take the hose off. Next get under the car and remove the resonator and such and the pipe off the throttle body. Then you can install your intake. Which is just as simple as running the pipe and like 2 or 3 bolts, very easy.
Welcome to HAN
Old Feb 9, 2006 | 03:51 AM
torn_phoenix's Avatar
torn_phoenix
you would
It's easier if you take the passenger side wheel off to get to the resonator and get that out of the way. There should only be one bolt that mounts under where the OEM airbox was. It shouldn't take long at all to be honest.
Old Feb 9, 2006 | 06:20 AM
joflo95'ls's Avatar
joflo95'ls
Default resonator
this is stupid but does anyone have a pic of the resonator?
Old Feb 9, 2006 | 01:29 PM
Driverman5777
If you take off you splashguard and look behind it it is a big freaking box. You can't miss it.
Old Feb 9, 2006 | 05:46 PM
joflo95'ls's Avatar
joflo95'ls
the installation paper states that i need to take of the fron bumper, is that necessary, and the intake cant get wet right?. so washing my car isnt a safe thing?
Old Feb 9, 2006 | 06:15 PM
Driverman5777
God no. Granted I have an AEM one. BTW how does tht 1 keep water out of the engine? The AEM intake has a bypass valve. Just raise ur car on a jack, take off the inner fender lining, and work from there.
Old Feb 9, 2006 | 09:06 PM
joflo95'ls's Avatar
joflo95'ls
Default bypass?
no it doesnt. so its safe to wash ur car like normal?
Old Feb 10, 2006 | 09:47 AM
Driverman5777
I'm not sure I'd be very worried about doing it I still am w/ even my bypass valve I'd look it2 calling Injen or something and asking them.
Old Feb 10, 2006 | 10:03 AM
torn_phoenix
you would
You could wash your car, I would recommend doing it yourself and not injecting any water into the fender liner right under the filter, that's how you get water in the filter. As long as you're careful about it, you shouldn't have a problem.
The resonator (at least for me) was a big white box beneath the splash gaurd in front of the passenger wheel well. You'll definitely see it once you take off the 8 or so screw/pop things that hold the guard in.
