PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. someone please correct me if im wrong or am missing something.
  2. Happy Birthday Trey!
  3. Mods, thank you
  4. not a mag racer
  5. full throttle bog
  6. more G2 <-> G3 compability issues
  7. dropping value
  8. MODIFIED MY STOCK INTAKE, PLEASE GIVE ADVICE
  9. CTR pistons
  10. New 2004 S2000
  11. Squeaking Noise..I'm thinking linked to a/c??
  12. HEY! is there a such dc2 integra oem rear apron?
  13. manifold question?
  14. Integra LS exhaust ?
  15. Strut Bars?
  16. How much HP gain from ITR cams?
  17. Installation of Greddy Oil Catch can
  18. exhaust question
  19. Wedge bulb question....
  20. aww its an alternator!
  21. Repair Shops in Sacramento/Davis
  22. Tein Flex adjustment #'s
  23. if u had money to spend...
  24. Vinyl wrinkles on door panels, easy fix?
  25. compression test results 95 se
  26. Unorthodox Racing Underdrive Pulleys
  27. Tranny or engine problem, HELP!!!!!
  28. Braille Auto Acura Integra Drift Car to Debut at Hialeah Speedway April 2nd
  29. i lost my wheel locks 4 my stock wheel gsr
  30. suspension ?
  31. how much does a GSR motor Weigh?
  32. 91 integra
  33. Dyno of 2001 ITR with bolts-ons.
  34. Coilover problem
  35. is it going to be easier to install koni yellows on rear
  36. compression test
  37. will vtec engage with the CEL on?
  38. What car should i get?
  39. did i install the neuspeed koni sp3's correctly?
  40. Any Feedback on J's racing intake for Type R?
  41. A/C gone
  42. jdm b18
  43. Horn Wiring in a '90 RS - Advice?
  44. tire sizes for 90 integra
  45. swap ???????????
  46. Rear Suspension Install?
  47. Timing belt worn? Pictures...
  48. before my dyno..99 gsr
  49. my situation...
  50. Making my ITR a reliable 13.0 second car...
  51. here's a little video production I made - I locked it- link.
  52. A little video production I made
  53. Got my EXPO3 DVD today!
  54. b16a and b16a2
  55. Buying Integra
  56. OBD conversion question...
  57. finally doing my suspension!! (got some ?'s)
  58. heal toe?
  59. fat five weight
  60. got some gidggy pics!
  61. JDM Valve Cover W Moon Cuts
  62. HELP! need OEM ITR part#
  63. Power Steering...
  64. pic request
  65. does anyone know how much it cost to ship out rims with tires
  66. How high to rev while downshifting?
  67. My Integra and Bump Steer
  68. question for you integra body experts...
  69. Help - Car turnsover, but does not STAY running...
  70. Maint Reqd Light
  71. removing power antenna- HELP!
  72. removing steering wheel- HELP!
  73. jdm honda engine
  74. 1990 jdm 1 piece bulbs
  75. MAP sensor location
  76. New to the Type R world........
  77. exhaust and Header
  78. Alternator
  79. question about afc
  80. is it true or not?
  81. Final Decision
  82. passenger axle
  83. Dropzone spring ?
  84. Moving to San Diego
  85. Westcoast ITR Track/Meet Event
  86. HKS Hi-Power Exhaust on a GSR?
  87. Good news! 2nd post on "My car got jacked last night!"
  88. swapping auto for manual
  89. putting GSR trans into LS
  90. ITR Throttle
  91. handling
  92. just purchase neuspeed/koni yellows sp3's
  93. car takes long time to start
  94. Stainless steel Vs. Ceramic header?
  95. Tranny Problems Help!!!
  96. Fake tags for events, where to get them???
  97. Suspension Set-Up, so many choices...
  98. injector
  99. WHAT TO ASK FOR 2001 PY TYPE R NEW STOCK
  100. Is the ITR spoiler functional?
  101. need to rebuild my tranny. where can i get parts?
  102. Single or Dual Bend?
  103. Any Dyno Plots AEM/Injen CAI vs. Comptech Icebox?
  104. Car jacked last night... thieves must die
  105. gs-r noise
  106. got some ITR wheels refinished :-)
  107. Clutch pedal clicks when released halfway
  108. b20 into an ls auto
  109. swapping part from gsr to a type r
  110. HElp and Advice!! Integra LS
  111. Clutch sqeeak?
  112. Lowering springs for '89 Integra?
  113. trunk lock
  114. obd1 vs obd2
  115. a guy in a new z bmw with the M package wanted to race me
  116. which coil over system should i get
  117. my clutch is getting weird
  118. Pressure Bleeding your brakes?
  119. Hondata Questions
  120. Another new member
  121. R as a daily driver??
  122. power antenna question
  123. LBS of Torque on a strut bar
  124. How to buy tires?
  125. integra vs eclipse
  126. First Car... What Should It Be?
  127. Why Am I Failing Emissions???
  128. Rear Seats
  129. master cyclinder info
  130. exhaust sound clips
  131. WINTER tires for the Type R?? what should i use?
  132. boosted road racing and auto x ?'s
  133. Dyno Tune Question
  134. Integra Type-R Car Cover
  135. Im going to do an engine rebuild and also...
  136. 90 Integra horn relay
  137. REAR brakes for '95 Integra SE
  138. Mirrors, Power mirrors.... Question inside.
  139. super glue
  140. same calipers?
  141. Swapping ITR wing for Stock U.S Model Wing
  142. Anyone want a spare set of rotors and pads?
  143. my ride...
  144. 2nd gen integra power antenna compatibility
  145. World Challange ITR Complete.....
  146. which shocks you recommend for 2 inch or more drop
  147. gas gauge acting up
  148. Sprint Springs and Struts
  149. Need used parts for my smashed front
  150. 93 Integra LS with Overheated Engine, what's it worth?
  151. new engine idea
  152. What's involved in replacing the a/c belt?
  153. Turbo Cams
  154. Transmission Mount help?
  155. turbo filter
  156. Honda-Challenge Video
  157. Suspension setups?
  158. Changing tranny fluid...
  159. hood question
  160. eibach springs?
  161. Would You Hit It..?
  162. turbo ?
  163. Insurance outta hand
  164. No engine in 94 LS, reliability a must, but haul ass factor very close second
  165. rusty teg
  166. JG/Edelbrock or AEBS intake manifold
  167. AEM Questions
  168. Fastline Performance Road Race shifter installed!
  169. Ingalls tork specs, bought used, no instructions
  170. Road Atlanta June 19-20, NASA- HPDE???
  171. G2 Door Panel
  172. Problem changing my axles...
  173. LS exhaust question
  174. Camber help
  175. what are the rarest colors on a teg??
  176. P1259! ! !
  177. Lowering Springs
  178. CAT Bad, need advice on replacements
  179. Unsteady Idle thinking head gasket...thoughts?
  180. how to tell if a jdm itr cluster?
  181. 5 speed integra
  182. Congratulations are in order, hit 250K today
  183. removing climate control
  184. 94 Integra Instrument Panel Bulb Replacement
  185. traction problem...
  186. brembo blanks vs bendix
  187. Catalytic Converter
  188. Does any one know the check engine light codes???
  189. My car got jacked last night :(
  190. CW ITR spotted - I-77 in Lake Norman
  191. Quick question about Fuel Filters
  192. Question about stock stereo
  193. Finally GOT MY R!!
  194. Suspension help
  195. Motor mount inserts
  196. motor mounts suck
  197. hondata
  198. **Brakes thread**
  199. Is mugen worth it?
  200. what size donut gasket?
  201. Terrible Rattle/Clunk in my trunk/hatch/rear of car
  202. DYNO Results...What is wrong with my car?
  203. Best shop to tune Hondata near Omaha NE?
  204. Best Motoring Type R Legend
  205. s2000 antenna conversion... where can i find it???
  206. what class am i? newbie
  207. Fuel Pressure Regulator ?
  208. Returning Member
  209. ITR Pistons fit in b16 block?
  210. New to this board
  211. GSR final drive in LS tranny.
  212. Bolt on upgrades, most efficient?
  213. clutch
  214. Rim question!
  215. which mugen header 4 to 1 or 4 2 1?
  216. header noise
  217. Painted Rims?
  218. cheapest place for kyb shocks?
  219. GSR Converted Type R or Honda Civic Si w/ B16 which to buy??
  220. Apexi VAFC-II
  221. Whats a good asking price for a brand new DC sports 4-1 Header?
  222. question about the mugen intake
  223. Type R Block...How Much Boost is SAFE!
  224. smashed my front... suggestions?
  225. VTEC Badge
  226. Question on JDM sized Carsound Catalytic
  227. CF craze
  228. manually resetting SRS light
  229. turbo pistons?
  230. Any R owners Near E. Brunswick NJ today? Want to meet?
  231. Sigh...sold my teg and am regretting it already
  232. hub centric rings?
  233. Compression Test 220 across the board
  234. Found a Type R on ebay...
  235. Does Anyone Know? 96 Integra Rs
  236. intercooler turbo kit
  237. Price New....
  238. engine code
  239. integra gsr shifter needed/wanted oem
  240. Where to buy a new engine in Ontario
  241. newb question... what does it take to beat a 2002 mustang?
  242. noob ? which lug nuts to use with these?
  243. I'm very close to be CRAZY
  244. Stock Wheel Well Gap?
  245. 93 integra
  246. BOSH PLATIUMS OK? APC 9.5mm WIRES ok to use?
  247. Terrible brake noise
  248. Nose Mask?
  249. ITR and b18b parts?
  250. Spark plugs being white
