- cams 4 turbo b18c1
- type r or not a type r
- gallery
- b18c gsr squeaky clutch
- Brake Heatshield
- B20 head/B18 block, help
- Need Some New Headers
- O2 Software Issues w/Integra 2000?
- Going turbo...will the B18B handle it?
- Integra Steering Linkage?
- Push retainers in the trunk
- I got a question!?
- Master cylinder rebuild kit?
- UNI Cone Filters
- 93 Integra Main Realy location
- why does my car lag power now?
- Shifter Bushings
- What should be my 1/4 goal with this new setup?
- GSR trans oil
- CVjoint 95GSR
- Buddy Club Spec III
- will a 5speed tanny fit on a automatic motor?
- how to install a electrical oil pressure gauge?
- Piston Question
- help my car is overheating!
- igniton upgrade
- b&m fuel pressure gauge help..
- clutch install went bad on gsr
- exhaust problems
- 2 unrelated problems with 93 teg LS can you help?
- gsr engine/ls tranny
- integra coolant diagram
- Alternator Replaced / New Battery
- need engine help bad
- too much for alternator?
- Vtec Problems
- Rear View mirror broke
- VAFC in 94 GSR
- Loose steering
- muffler tip
- Need help
- Picking Up The CAI
- which one?
- Stupid question... Car Abbreviations??
- cleaning JDM DC2 lenses...
- trunk brace?
- best spark plugs
- air intake install
- How much you pay for insurance on a teg??
- Question about LS
- Sick spark plugs for 2001 ITR
- Wrong Clutch! Help anyone?
- oil leak
- Vtec head on auto integra?
- Locking problem
- Type R Exhaust
- wal-mart mechanic can work on teg
- gunmetal paint code?
- car cut off when put in gear
- CRITICAL transmission service question - 90 Integra GS
- Rad fan not comming on
- 93 Integra Performance Upgrades
- fuel line replacement.
- H&R Sport springs and what shocks ?
- Stupid Question...
- slim fans
- Clutches
- NA 88 integra (still honda)
- looking for lights
- 2001 GSR Burning Oil at 40K ?
- JDM Conversion... HELP
- what is jdm?
- just got a acura integra newboe needs help
- I mite be getting a type R [**Merged**]
- Little Quirks
- Type R Cat
- Rookie Looking For Answers
- Bi-Xenon Conversion
- dam time to smog car.. with turbo
- car just hit 60,ooo
- Poor Mileage woohoo!...
- compression test?right and wrong ways
- Problem with back door locking
- High-flow cat?
- how much should I pay
- The Best Way To Shut A CF Hood?
- Brake Pad Suggestions
- An Interesting Read
- Strut/Sway bars
- Removing Pwr Steering = HP? - Lets settle this
- vtech
- Integra engine rebuild
- fixed the taillight!....but now a new problem
- Noob here
- JDM Amber vs Stock Amber
- New brakes and rotors hanging up...normal??????
- Thoughts and/or opinions on Magnaflow catback exhaust on a GS???
- R.i.p. 1996 Gsr
- Need opinions on the MagnaFlow Catback Exhaust for my 01 GS...
- How fast are crown vics?
- gsr swap...how much is this motor worth...
- In the market for a 4 door teg. What colors?
- brake check light
- god y do u do this to me
- anyone have pic of teg on rota gt3 ?
- Code 43, can't figure it out!!!
- Temperature Guage
- Struts/Spoiler Light
- reduce gsr compression?
- possible clutch problem?
- Where to go
- Gas tank removal ---HELPPPPPPP!!!
- type r prices
- does a starter from a D16Y8 bolt up to a B18B1?
- integra si information needed
- Silvania VS philips bulbs
- What MPG are you getting?
- Lugnut Lock Help Needed!!!!!!!!!!!!
- car hesitates or lurches while moving.
- What is recommended timing belt deflection?
- No Spark and No Fuel
- Block heater install
- ITR Dyno Results Web page
- Best oil for integras?
- Laying it on the line I need help fellow teggie owners
- Wahoo...got my c-8's!!
- hatch stuck
- High Mileage oils:
- Ls-r
- RSX tranny on a b18c possable??
- HID install question
- short shifter install
- rubbing sound during sharp turn
- Having a serious power issue.
- my 91 integra shuts down
- OBD1 engine in a 97 GSR?
- Manual Transmission Bushing Kits?
- Full list and a few ?'s
- Starter Removal..
- Weird Speedometer thing
- Rear Wiper Delete Finished - Some Questions and Concerns
- Apexi VAFCII
- Anyone in RI/MA help me with a b18c1 swap tomorrow?
- Buying an Integra Maybe????
- exhaust problem
- AT harsh shifts
- Gsr surging Idle. (why did this work?)
- e-ram?
- Integra Ls
- Non-dealer part source needed: rear caliper bracket (95 GSR)
- gheeeyyy head gasket
- 10 Hp
- will 94-01 greddy turbo ls kit bolt on my 2000 gsr
- Sucky MPG-s-
- New Hood
- Gas pedal play
- a few suspension questions
- Divirginizing of a drag track...
- Car Won't Start
- The difference between 1990 rs and ls motor
- Question reg. '96 Integra stock keyless entry remote
- Thinking of buying a used ITR LSD.
- Installing my air intake.
- What can it be?
- HAN has a Scammer...put an end to it!!!
- anybody have the 98-01 rear lip from streetstyler.com ??
- Before buying
- New transmission break-in?
- Opinion --Please
- wheel weight
- what do i need
- broken swaybar endlink
- I have a question and help!!
- ECU keeps tripping fuse
- Tien sTech Springs... anyone have anything good to say?
- Best sites to purchase H&R Sportlines from...
- is a lightened flywheel worth it?
- Teggy tranny swap
- Any Ideas on Stroker Kits?
- Problems starting on a new turbo install
- can anyone help me
- right wheel pushed back 1/4 inch
- gsr top speed
- help building b20b4
- lowering springs
- smoking problem
- any1 heard of this
- Someone broke into my teg!
- New tires
- Need Advise on my 94 Integra Hood
- obd's
- Taillight Not Working (It's Not the Bulb)
- Integra or civic
- Using oil?????
- OK I'm Confused...
- 92 integra question
- Teg Power window question
- Comptech Intake and Icebox
- Question Regarding Spoiler brake light
- introduction and question
- SNOPPY reply quick
- Need help! caliper piston
- stock body sheet metal filler??
- 2000 Integra LS, catalytic converter
- New ITR from Portugal
- I know what to do next...
- Questions
- Gauge cluster lights
- Help
- possible rebuild time... gsr?turbo
- B20 LS hybrid
- ls non-vtec camshafts
- Using oil...and little smoke during revving???
- Bolt Ons 98 GSR
- b16 head swap
- A/C parts locator
- Eibach pro-kit
- Integra Tail-lights..
- integra fuel filer
- Door Seals Trunk Seals 95 GSR where 2 buy?
- Painting Body Mouldings
- Which clutch for turbo setup daily driver??
- b&m short throws?
- using non-platinum plugs...
- 94 ls w/ 92 ls tranny
- '91 Integra vs. '91 Accord?
- Evaporator Thermo Switch?
- H-Brace Bar
- Ls non-vtec build up
- value of 94 LS motor?
- Lsvtec Vs Type R
- noise?
- CL headlight conversion
- wheel bearing going...
- Tuner in South Carolina???
- Spoiler
- car wont start on 89 civic hb
- dc1 vs dc2 chasis
- serious decision
- michigan runners?
- is it worth it???
- Door Panel Help
- Fuel Problems?
- Looking for good mechanic in San Diego
- moonroof removal bolt lacations
- Can anyone with greddy turbo kit post pics other than shmoo
- Clutch and Flywheel
- AEM Intake
- Omnipower C/O ride is too punishing for me! Help!
- Exhaust leak?
