- Lowering The Type R
- Virginia Intl Raceway (Driving Event)
- New Type R Owner
- what could this be ?.
- Spark Plug and a Couple ?'s For a New Type R Owner
- Is the 1989 Integra a good car?
- Are these the oil galleys where oil squirters go?
- What color is this?
- Fuel pump er no?
- GSR Engine Problem
- B18C1 intake manifold busy-ness
- my chRistmas pResent (capslock hint)
- how big is too big for wheels on a 96 integra?
- Tachometers??
- So I received my steering wheel today for my Integra.
- weds sports sa90's
- Can a p8r head be put on an b18b?
- DA integra fuel pump??
- itr cams or ctr cams
- gsr transmission
- Help me run low 14's on my 94' LS!?
- jacksonracing gsr
- Oxygen Sensor
- tunning E-manage on supercharged gsr
- Need help with interior disassemble & moulding removal
- Just test drove a jdm dc2 210bhp ;)
- integra engine swap
- shift light install
- my 92 integra turbo
- Water inside on passenger side
- Are the B18A stock sleeves better than the B18B stock sleeves?
- Crank sensor failure = new distributor = $500?
- Transmission compatibility
- Piston / Rod Problem
- Super Charging the R
- Temp problem on teg (over heating), need assistance.
- 94 It Tranny Q
- Can anyone identify this part?
- Rev limiter at 3200 on CEL, suspect IAC valve
- How does the shift boot come off
- Keyless Entry Remote
- Brake Rotors and Pads
- FS: New Vision carbon fiber spark plug cover for B18/B16 (VTEC)
- any others
- how do i take engine checklight off after turbo
- Desperate need of help!
- advice on suspension setup
- where to shift...
- Bad Camber
- Upgrading R's exhaust
- Information: JDM Type R-(X)
- messed up sound at 1500 rpm
- Problems with my ABS
- Eibach Pro Kit Spring
- New Jersey CAR OWNERS!!! HELP!!!
- Non Srs Jdm Steering Wheel
- Gsr Engine VS. LS engine (what are the diffs)
- Are these clutches the same?
- does anyone know if a full n1 exhaust comes slanted?is it good to run wid trbo, price
- Very Sluggish Clutch Pedal / Cold Temps
- Water leaking from above drivers side.
- 1997 Integra Transmission Problem
- integra generations
- Help wrecked G3, need help with parts
- Missing Juice
- b18b pistons (pr4)
- Integra passed BAR Smog test!!!
- how and where can I find paint code manual.
- radiatorbarn's two core radiator
- ITR limited slip in gsr?
- Right rear hub spindle nut?
- should i buy this?
- making my 95 look like an 01
- GS-R performance specs?
- 4 door integra spoiler advice
- Intergra ZSI?!
- heater/ac blower
- Is this Strut bar worth it?
- Stock ITR Exhaust
- suspension ?
- Chilton Idiots
- Short Shifters Yet Again....
- Daytime Driving LIghts
- clutch or tranny
- God! Igniter and Coil!?
- preformace parts
- Shifting gears and removing key problem !!!
- Starting while cold?
- Front anti-sway bar
- Weight Of Engine Components
- Does anyone know how to take the steering wheel off?
- what do you think?
- What to pay for 99-01 GS-R with ~50K miles?
- Hatch Shocks
- ls/Vtec??????
- engine help please
- HELP!! Engine swap from a LS to a GSR
- Need Pics of ITR with NSX-R style Paint job
- OEM Exhaust Questions??
- Replacement Mirrors
- oh yeah another ls v/tech ?
- adjusting headlight
- Clutch kits, stage 2?
- type r strut bars
- Wreked Itr
- Is it safe to boost an ITR???
- 95 GSR Stalls Cold Startup
- Replace OEM Headunit and Speakers for a new system for Xmas..
- Overheating, Radiator fan Problem
- American Idle...
- Need help with Fuel Pressure regulator
- Difference in teg and Crx calipers?
- Simple Suspension Question...
- weird jumping idle in "P"
- how to remove power steering
- Tranny swap, anyone done it?
- Tires
- Door jam stickers
- A question for anybody
- Water around my spare tire???
- hP FOR A ls??????
- where can one Find clear or blue head lights for a 2000???????
- My 4dr GSR what do you think?
- noise from steering
- Braided brake lines???
- Gauge cluster+Clock not working?
- Rear wheel bearing...
- Dented rim losing tire pressure
- will 7 inches wide fit?
- engines for integras?
- bnky carbon fiber hood
- GSR swap into LS (have some questions)
- If you guys think my Integra failed smog...
- HOLY CRAP IM PISSED. Broke the door handle
- running car with no raditor
- OBD issues
- Anyone with standard Ground Control kit??
- whats so special about itr lcas?
- Thanks!
- spoon n1 fitment?
- Best way to install 3pt or 4pt harness? (Did a search)
- o2 sensor location is messed up
- 96 GSR Fuel Type
- How do I locate the transmission plug?
- what do you guys think of my setup??
- ITR B pipe
- car idle problem
- EFI fuse?
- Why are spark plug wire covers so damn expensive?
- failed ca smog... timing help
- Vehicle weight
- Solution to My Car Starting Problem
- Newbie removing seats & carpet in 4 dr. teg for impossible to find water leak, what t
- Factory Fog Lights!?!
- Done a search...
- comptech icebox?
- Remote Start on Man. Tranny
- 98 GSR with 93k miles stock SSBP. whats it worth?
- what does this tube do?
- Do Gen 3 Tegs all use the same Timing Belt?
- Color/Paint
- 99 and up transmission
- freezing my a$$ off please help
- Water in Taillights
- Front Turn Signal Wiring? JDM DC2
- Clutch Noise, Loud!!!
- What do you guys think of the clover color green for Integras?
- Another crazy person thinking about s2k cluster swap
- Scratch
- Engine oil level, turning noise
- brakes on 93 integra 1.8l
- ITR springs
- Help Bleeding Brakes
- Integra Type R B pipe
- 92 Integra tranny question
- 17" Rims????
- 9004 conversion done
- RonJon Inspyre Wheels - At Dealer Cost!
- noise from the rear of my car?
- does anyone know where i can find code meanings?
- Rotor Help
- Acura dealer shipping internationally needed
- Heat on, Bad Smell
- LS for $600
- I got $2k
- HELP Installing Different Gauge Clusters In Teg
- Short shifters, and bends
- If I install a skunk 2 intake manifold...
- GSR CV Axle Replacement?
- need info on parts
- Jdm Itr Piston install in b18c1 require break-in?
- idle controll valve location?
- Exhaust Manifold Problem - Suggestion needed
- Right Real wheel bearing
- Nology Hot Wires / Capacitors ect.
- 17" too much for integra
- Jackson Racing Supercharger for LS/VTEC?
- LS Vs. SER SPEC-V
- Maintenece Required light
- AC problems
- Hazard Lights not working
- Problems Getting Car Started
- QUESTION. . i need some feedback ppl! :)
- 95 Integra Auto Trans with V-Tec???
- Exhaust
- Integra ignition?
- What length Carsound Cat?
- seat question
- Help: Need estimate of front bumper replacement..painted & installed on a 98
- stupid ?
- question?
- 93 Integra Engine Swap
- mybad, let me rephrase
- JDM ITR 4-1 header replica
- how to adjust headlights-need help asap
- Ls Vs. Gsr
- Compression Raising
- Good Compression?
- Auto-Manual Swap/Conversion
- b16 in integra
- Shorted issues... help~
- idle problems on my turbo dc2
- can too much back pressure mess up turbo? or cause problems?
- frankenstein GS-R pics
- intake header exhaust (need ur vote)
- My Integra passed smog!!! Off to the ref. station.
- S4c Civic SI Tranny Swap
- ABS pump motor over-run
- My Shock is stuck...
- Gauge Question?
- Skunk2 Cams
- My clutch is making noise + ABS problem
- Got bored..took a couple clips
- 5 lugs? i only have 4
- 1997 ls/vtec
- how long turbo last? <<Merged with duplicate>>
- Clutch or Tranny problem?
- 1991 B18A1 Integra LS MT
- Ls\vtec
- rear wiper removal
- Ignition Control Module helppppppppp
- Running rough, misfiring?
- having IDLE proplem need help pleaseeee
- ctr n1 crank pulley?
- Possible IACV problem, not sure... I'm starting to think it's a clutch thing
- Rear brake questions
- New teg
- 1991 Acura LS B18A1 MT
- Aluminum radiator?
- lookin for a tranny
