- Camber Kit Question
- headlamp cleaning?
- 98 Integra GS Tail Lights
- brake light not working
- Simple Question
- No Emmisions Testing!
- B18a1
- RSX Gauges into a 94 Teg
- Crunching/Squeaking Noise from Suspension?
- tranny fluid question
- DC Sport's Cat-Back
- My Integra SUC…
- Z Max ..bull Or Does It Work?
- need a new tranny
- Help 1992 GS - How to drain Auto transmission fluid? (Cant find drain plug)
- Excessive Gas Consumption
- What short shifter do you have?
- A Good Scrap Yard for Acura's?
- B16a Swap Help!!!
- ls skunk2 intake manifold
- Ticking sound from interior fan
- Tuning!
- how to change alternator belt?
- heater making weird smell
- Abs Light Problem
- Gsr options question
- Good Price for a GSR
- ITR spoiler adding on instruction needed!
- Abs Problem
- Camber Kit Required 1.75/1.5 Drop?
- Rookie Report and Some Qs
- GS-R question
- Odd sound from front of car
- p75 ecu
- Lowering Question.
- Is a high flow cat necessary?
- MSD question
- Honda ticking, should it be heard INSIDE?!?
- PCV valve questions
- Intake Installed!
- how much you willing to pay for a J-spec RHD 97 integra Type-R?
- Civic Si/3rd gen integra shocks
- Good set of headlights
- Old integra 1 peice headlights???? Pre-94 Models.
- blew my car sideways
- Clear Bumper Lights
- Hesitation, driving me crazy
- Air/Fuel
- odometer cluster stopped working
- camber kit...
- mirror loose
- GS-R brake rotors
- need help on emmisions
- Fuel gauge off alignment
- King Motorsports Dyno Day at CJ Motorsports (West Chicago, IL) April 24th 1:00 PM
- Corner light problem *Help*
- accident last night :(
- Gap in change rod & shifter on skunk 2 shifter base?
- thinking of buyin gsr and need advice
- Anyone know if '89 Civic alternator fits '88 Integra??
- Car Starter
- More CEL fun...HELP
- Mugen street sus
- Rattle when shifting
- Weird noise/idle somthing to do with ps pump
- temp gauge
- Expo 4: The Last and Final Change!
- ITR Expo 4 FINAL Information
- Scratches. Paint it or leave it?
- How do you stop the power antenna from going up and down?
- bought my GSR today
- my GSR feels weak
- Check Engine Light question
- s2000 reception loss ..really?
- Mobil 0w-20
- Horrible looking type-r . why????
- Back end is not siting even, need help?
- Itr Lsd???
- Abs
- nology hot wires
- Will my slammed Integ fit 17"?
- Ingall Camber Kit Broke!
- Noise at clutch catch point...
- G2 timing belt tention
- cam comparison..itr and gsr
- Radiator troubles
- 1999 integra gs problem
- Zero Offset
- Get A Life Thieves!!!!
- vafc pressure wire?
- A look at a SMSP test pipe and bottle neck adapter-NO-56K-
- clutch squeaking
- Bad to run without O2 sensor?
- Itr Sway Problem!
- questions about superchargers
- how much horse power
- 98 Integra offset?
- ideas
- JVC Sirius Plug and Play Unit...Places to mount???
- 50-100 RPM idle
- Help !!! Dyi
- Does anyone have a Vortech Supercharger?
- Cheap e-bay CAI's any good?
- Clutch Replacement "how too"
- Stupid car...Radiator's busted
- which is better for my 90 integra?
- Burning oil
- Exhaust and Body question from new teggy owner
- Gauging Interest in Falken Azenis Group Buy.
- Metal in tranny fluid...LOTS...Help
- what company makes 2.5in exhausts?
- front / rear brake pads question
- cant find fuse
- Coolant Gage Malfunction / Check Engine
- No Turn Signal or Hazard Lights
- jdm front wiring help?
- Skunkwork Cam Gears
- Engine block JERKS while shifting from Park->Drive->Reverse
- just bought a t3 turbo
- this new vr6 gti vw rev up at me
- Blinkers don't work
- hello new
- RS Master Cylinder
- exhaust fitment ?
- Dyno Tune Question
- LSD question on a product
- integra left me at lowe's!
- Vibration, GRRRRRRR!
- Common bolt-on's before upgrading cams?
- Power antenna question
- Body Difference in Vtec and Non?
- hey i'm a newbie
- ITR expo 4 (whats going on now?)
- integra comp cams
- help finding a good shop
- VAFC mount (help!)
- Could fuel cutoff switch affect performance?
- Exhaust Shops in Omaha NE?
- Mmm... dirty clutch fluid
- comp cams any good?>
- Left Door Lock
- Help? [Timing Belt Swap, 91 LS]
- Weird noise opon acceleration
- Whiring noise
- interior lights on then off then on
- ITR ECU problem
- urgent, check this jb weld job.
- My first Integra. Need some advice
- I am confused in making a big Decision. (selling my teg)
- integra interior parts
- Romove 3 piece wing spoiler on a teg
- 1999 integra Drop Question
- Replace main relay
- Response to Dual exhaust post
- ABS pump, has anyone here flushed serviced theirs?
- honda made or aftermarket cv joint
- how to turn engine maint. light back on?
- im new!
- high idle stuck on when motor is warm
- What!?
- what size?
- situation with cams/cat and smogging
- Vtec and Redline
- Control Arm
- Why Chattanooga, TN rocks!
- IVR pictures (no way 56k)
- Problems with Skunk2 dual bend (esp for people with skunk2 shifter)
- 94-97 Amber bumper lenses (non-painted)?
- G2 GSR Integra commercial here
- Shrot Throw Shifters
- most quiet exaust (ignore other one)
- 5zigen?
- Lost, and now found
- Exhaust System 94 Integ RS
- Stock ECU?
- how do you remove shock from the rear 2000 integra
- looking for a dual exhaust
- Might Buy 1st 'Teg
- integra CV joints
- Tranny fluid... O crap
- Slight rattle with Comptech Exhaust
- how much hp does skunk 2 stage 1 cams add to 2000 gsr in average?
- question about starting my car
- I'm going to get all this car work done this weekend!!!
- Intake Manifold
- Integra not starting.......
- Cobalt GT Sports and ATE superblue. Thanks Andie!
- how shoud the spring perch on koni yellows on the rear be facing??
- Welcome ITRCA members!
- metal screeching sound turning wheel left
- Header?
- And i thought i researched it!
- my integra scares me
- The story of a little '95 GSR
- jdm itr spoiler fitment?
- Exhaust help
- Lowering Car: Do i need to buy a camber kit?
- rear main seal leak
- Squeak when turning steering wheel
- DC Sports exhaust?
- High Idle after driving around, normal idle when car is first started
- OEM Fog Lights Wiring harness HELP
- having a little bit of trouble...
- got the koni yellows installed on the front side of my 2000 integ,how do you adjust
- CV shaft... does it split?
- 18" rims fit on our Integra with no spacers?
- Expo 4: BeaveRun Rules!!
- ITR info.
- Conversion Calc (Kg/mm->lb/in etc.)
- Rota Center Caps
- Tire Size Calc
- Gear Calculator (Final Drive, Gear Sets, O.D. tires)
- TSI Extreme Turbo Kits????
- Water injection vs intercool on JRSC 10-11 boost.
- noobie questions
- Stock exaust to not.
- How Much???
- Just a rediculous thought: Mexico Spec Integra???
- Should i be alarmed?
- how to fix plastic lip?
- Volk CE28N 18x7.5
- carfax please
- my rpm is spiking!
- Selling my integra
- Mods vs. MPG.
- gauge needles?
- my car won't disengage the tranny out of gear.
- how much of drop in 1/4 mile time
- A little help here please
- whats this mean ? CASE, L. *NH167L* or CASE, L. *YR164L*
- leaking problems
- exhaust sound
- Hawker Battery (Pics, Install, a bit of DIY)
- Autopower Race Bar Install (pics+write-up)
- Weight Reduction (Project Tub-da-R)
- Kteller exhaust (2.5") and T1R muffler
- Having Problems accelerating over 3.5k RPMS
- I'm a n00b again.
- pulgs are they hot?
- another vid wid a bangin' sountrack...
- phoniex yellow paint code
- spam
- good cam for stock setup
- prelude calipers
- I might have to say good bye to my car...
- Fix My Interior!!!
- Update on my car progress
- What did the ITR say to the Berm?
- Would this be stupid?
- someone please correct me if im wrong or am missing something.
