- CEL Help: 00' DC4 with B18C5 code 91
- Quick Question: winter tire PSI
- Checking CEL Light
- B18C3 info
- How to lift an integra
- bout to start my clutch install...
- Can the stock pressure plate hold any extra power?
- installing type R spoiler
- i wanna turbo my LS
- Who makes the best cams & cam gears? for B18c1
- 92 GSR Question?
- brake/caliper question
- Is there any way to upgrade the air conditioner?
- 95 integra worth this much?
- Want to upgrade my integra but dont know where to start
- Da Owners Need Ur Help!!!!
- Help: Is the Intake Air bypass check valve neccessary
- clicking when turning right..not CV though?
- Need 1989 Integra LS VECI Label
- Intake Manifold help
- Seat belts!!!
- Still Slugish!!!
- turbo ?'s - ruff idle, fuel pressure
- 93 Integ / Only starts in hard reverse
- 89 Integra LS - Idle Adjustment
- ****offset question****
- Need Mechanic In Smyrna Ga Area
- 94-95 security unit wire harness
- Belt deflection/tension measurement tool?
- help!!!! on the gsr
- popping noise...
- Sell mine and buy 2??
- Adjusting the camber
- tranny swap
- engine temp?
- timing issues
- 1990 Integra??
- steering wheel swap help
- Raising a '98 Integra to Stock Height
- Help: anybody know how to remove the pulley from the alternator
- problems with my fans
- why was my thread closed?
- Fog Lights
- 3rd Gear Grinds
- air intake manifold trouble
- Control Module
- Recommendation on engine
- 1996 integra breakdown possibly timing chain failure
- Help
- Fuse for fuel pump
- What spring rate is everyone running?
- Tweaker blinkers...?
- turboing integra....radiator question
- Help w/aftermarket gsr h-beam rods
- Finally I got what I need
- radiator leak
- anybody knows how the intake work on a b18c1--- vvis intake port
- Ques: What Radiators to use with JDM B18C GSR
- Rubber Strips On Roof
- grindding when shifting.
- del sol seats?
- HELP: does anybody have pics of their Intake manifold for JDM B18C GSR
- Reseting the ECU
- KYB* Shocks
- A few questions...
- OEM brake pads vs Axxis Ultimates
- front bumper damage
- 1990 Integra - A/C Relay
- lookin into the cost for a ls motor, n what i need for it
- Ls Daily Driver Turbo Question
- o2 sensor
- 1990 LS not shifting automatically
- new clutch problem..HELP
- steering wheel not strait
- A\C Question
- 98 ls problem with H&R's
- Rear spoiler removal??
- new 92 integra mod questions
- New Teg'
- Car won't start in the summer heat.
- OEM Steering Wheel Cover? Beige
- Engine is DEAD:(
- new header - O2 sensor conversion to OBD1 required?
- where to find vac gauge line?
- HELP: Vacuum lines and coolant lines on a b18c1 engine
- 93 Integra GSR
- A/c Question
- Question
- Transmission question - Trouble Shifting
- couple of questions on ls/vtec
- Motor Build Question [Split from ITR Side Skirt Thread]
- Is the Tokico Illumina Suspension Kit any good?
- ~ Blow Head Gasket ~
- 95 acura integra Brake issues
- Suspension Help
- Retrofit HID's
- Team Integra Raffle
- removing rear main seal?
- coil over install problems please help
- Electronic Problem HeLP!!!
- My 93 GSR needs a clutch any recomendations
- 2nd gen boost
- just got my omni camber kit
- my first car
- what ecu should i get?
- obd1 vs obd2
- bleeding brakes
- I wanted to get out and kick my car like the dog it is!
- Turbo Auto
- Nippon Racing Pistons
- I want to buy an integra. Can i get some help?
- type r style optional side skirts
- '94-'97 to '98-'01 tail light swap
- how do you figure out the year on the gsr
- what mods?
- Seat brackets
- what should i expect
- Cobalt in flames
- My OEM clutch felt very spongy this morning.
- My First Mod!
- Re-located my license plate on my 99 GSR.
- difference between GSR LSD tranny an ITR tranny?
- B16 tranny with LS motor
- Clutch Slave Cylinder Replace
- Turbo Integra question
- How to tell if you need new springs/shocks
- Can you recommend struts and springs or coilovers for a 1992 Integra GSR?
- help
- I know this has been covered but...
- Integra LCA and subframe question???
- Not another alingment question
- 89 Integra LS
- does anyone know where i can get a tranny pan gasket and filter for a 97 integra???
- 1989 Plug Suggestion?
- Bye Bye ABS Unit
- scratch/chip repair
- Valve guide seal
- newbie: gsr track car engine
- Ehaust or Intake?
- what is jdm itr hood worth?
- 1993 Integra...NEED HELP!!!!
- Car Slowed Down!!!
- New Cat?
- car starts, then dies
- GS-R Exhaust Rattle!
- Get a Grip!
- crisis situation, cyl. #3 still not burning fuel
- best turbo to use on a da
- Acura Integra Programable...
- 95 LS - brake line flange nuts - overtightened?
- 2nd generation integra no airbags?
- quick itr question
- The Five Steps to Diagnosis
- how much hp is possible?
- Adjusting suspension
- Head Lights
- Rattling around engine area... aem cai 2000 itr
- RE:Brakes for Gsr?
- pistons
- Help with a CEL
- Catalytic Converter for 2000 GS-R
- what's a wrecked '97 ls worth????????
- Starting Problem - Starter Relay or Clutch Interlock Switch
- I just deleted my power steering..
- Had VAFC stolen, had question....
- How do you know when a turbo is locked up
- broken screw on valve cover?
- Junkyard turbo setup for my Integra.
- new integra..
- Metal-on-metal grinding from tranny?
- Stock Adjustment
- big problem, need help.
- Did my timing belt snap?
- 94 Integra running rough
- Integra Turn Signal Wiring
- code 92 evaporative emission control system
- '97 Integra - intermittent jerk when idle
- New Steering Wheel
- Cannot get exterior door handles off
- 1990 integra rs s2(?) anti lock or not?
- New brakes for the GSR
- installed some of my last parts for the teg
- 95' LS idle up and down when I start?
- tranny swap
- Gas Pedal Play??
- Caliper number
- racing seat
- gas tank problem....
- whistle after engine shut down...
- rods on a gsr
- spark plug bubbles.....
- Edge Sport Racing header?
- g3 with a g2 1 piece headlight, is it possible?
- Exhaust Sounds
- RS-R Rr ticking after shut down...
- cat problems
- Tapping sound
- integra starting problem
- Intermittant ABS light getting worse.....
- transmission
- 1996 Acura Integra 2 door LS Questions
- Drive shaft rotating and not in gear
- Stolen owners manuel
- 92 Integra:Sudden Death
- bad gas mileage
- automatic window question
- 93 integra < suv trailer hitch
- Type R Gsr Hybrid
- Got some problems with my R and need some help!
- swapping 95 teg front/rear sections w/ a 98
- hydro series
- Only one radiator fan comes on. Is that right
- Dead CAT
- 90 DA clutch bypass
- Opinion on PY 2000/1 ITR 45K?
- What suspension setup??
- Engine???
- Brighter headlights
- emissions - high HC at low rpm
- turbo kit programs
- How does supercharging/turbo effect mileage?
- JDM Hood
- ignition switch wires... Where do these wires go?
- b20 turbo kit
- 96 Integra Electrical problem
- Need help with integra shocks
- Her She is(1998 GSR)
- LS/VTEC or TURBO $
- tranny good or not
- integra pics
- Taillight doesnt work!!!
- Electrical problem out of this world!
- i got my new motor
- Any way to adjust front caster on the teg?
- Ls?
- b20/vtec
- Question for the circuit racers and the mechanicly inclined?
- Afc2
- rc injectors and venom intake
- Intermittant No Fuel
- 3rd gen seats into a 2nd gen?
- main relay location
- A 96 to a 98?
- integra type r gauge cluster question
- Wondered about ride
- catch can question
- not getting spark from spark plug.
- autocross help
- firing order
- Schmoo's Going Away Meet!!!!!!!!! [Tustin, CA]
