G2 Door Panel
Old Mar 13, 2004 | 10:47 AM
Robstunner's Avatar
Robstunner
y0! Vito!
Default G2 Door Panel
Hey, i have a new door lock, and handle for my drivers side door. i was wonder what the proper way to remove the panel for it it. I see two screws, but theres still stuff holding the door to it. NE 1 have any poiinters, tips or advice???
Old Mar 13, 2004 | 11:06 AM
b00gers's Avatar
b00gers
which screws did you remove? i know on the G3 teg, there are 3 screws, and the clips on the bottom.
here is a pic of the G2 door. circled are the screws found on the G3 (sound be similar to G2) and the clips are lined on the bottom. you can pry and pull straight out. after the clips are undone, itll be held in at the top which you can just pull UP to take out. disconnect the harnesses and you should be good to go.
have fun putting it back in h:
File Type: jpg
