- Anyone have satelite radio in their Integra?
- ECU doesnt flash
- ITR Expo 6 - Gingerman Raceway June 12/13
- Turbo question
- Water leak in passenger side
- Rubbing ?
- my auto integra ls in the 15's with common upgrades
- 00 Integra GSR:Having problems starting! any suggestions?!
- I might purchase 1994 Integra.. but..
- my car
- rear quarter rust
- Heater
- Timing belt
- 3 angle grind advantage.
- 1990 integra has no spark
- Integra GSR with retarded heating system
- Intersting video but unrealistic #'s
- Who ever thought that.....
- about to buy a 1995 GSR
- crashed my teg help!!
- need help
- LS to GSR Exhuast Compatibility
- crankshaft position sensor 94 integra
- Finally!
- car won't heat up
- Test pipe with rsr
- Front LCA for G3, same as Civic 92-95?
- acura abs?
- '96 5 spd transmission types
- How do you find Honda numbers for Acura parts?
- Car Stolen [Update: Recovered, but Stripped]
- sell or fix
- Building a turbo kit for a GSR with $800
- Lowering and Body Kit
- just checking
- im getting a 94 gsr for $600
- car sputtering!!
- stock b18c1 hold 6lbs boost safely?
- which bushings are critical?
- Jdm Climate Control.
- Firewall Plug fell out of Rear Wiper Hole
- Stock Ls Rim Offsett???
- Tegs in snow
- how low can you go?
- ABS light comes on when driving
- help me decide on exhaust
- First Mods For A '96 Teg GSR
- 98GSR Timing Belt/Water Pump?
- Ls Rim Question
- when are stock gsr shocks worn out?
- O2 sensor heater circuit malfunction??
- weird fan problem (i searched)
- Installing dizzy
- noob here about to get 95 RS
- 1992 Integra LS 3dr Blower motor, switch
- starter relay fuse
- convincing info about itr's.
- Turbo help??
- Head gasket replacement from hell!!! need advise
- port and polished 97 gsr
- Help decide first mods
- steering oscillations....
- IACV wiring question
- 1990 Acura Integra with Emission Problems
- Gsr Lsd
- type r ecu on a gsr
- Wiring in Type R vs. GSR
- Installed my Skunk2 manifold and CTR cams today
- Another turn signal thread
- Wires
- just asking
- Do civic radiators fit integras?
- Attention All Body Mechanics !!!!! (or guru's who know about body repair)
- 93 integra clicking/knocking when turning
- 94 integra ls starting problems
- gsr or ls
- "maint Reqd" Light!!!
- Distributor Cap Help!
- I cant decide what to do next
- replaced air filter...now alot of noise
- Wiring harness/ Fuse box
- 95 Integra RS - rotor removal help
- Wiring Harness/ Fuse box
- Starter Question - did your's fit?
- Big Problem!!!
- Does anyone have bushings installed? IE: Energy Suspsension or some other brand.
- Suggestions for alternate mounting of the front license plate?
- Springs Retainers. Helllllllllp W/ Finding A Tool
- window probs...
- Squeaky Front End
- Going to look for a replacement motor due to spun bearing, have a few questions......
- Sway Bars arrived for my '91
- Dropzone???????
- leak ... taillight or power antenna?
- handling sugestions
- gsr head in my 91 ls
- Fuel pump priming sound...
- Important Question
- help with exhaust!!
- I need a race prediction
- when DOES vtec kick in?
- b18a1 engine swap
- Integra HP question
- tuning
- HElp please my 94 RS wont start!!!
- RE: 90K service??
- So, I have a problem, think its electral, but HELP ME!!!!!!
- '96 Integra bad tranny need advice
- black smoke
- After market gauge help.....
- Missing Piece
- Help me figure out this new noise I discovered.
- turbo...bored
- ????camber Kit????
- Hesitation problem need help
- where did YOU buy YOUR tuneup parts, and how much did ya spend?
- Random Shocks + Lowering Springs?
- New guy -
- upper control arm problems
- Gas Milage is HOOOOOORIIIBLEE
- 95 integra gsr radio wiring diagram????
- ????camber Kit???????
- I have $400 what do i buy
- 90/91 vs 92/93 ls intake manifold
- 95 Teg coolant leak
- Clutch/Maint light connection?
- Who Else Has A Leaky Tail Light??
- Strange thing happend today
- Finally, trailing arm bushing replacement made easy
- place to find OEM stuff
- Clutches and fly
- 3rd brake light is being a bastage
- Teg not shifting
- Broken Motor Mount
- Bump Stop Question
- How do I get a 89 Integra LS radiator off?
- cel 4 and 8
- tegs with HIGH BOOOOOOST
- A/c pulley Question
- engine code 68???
- Integra Steering Wheel Question
- power steering pump woes.....
- Should I sell my 00GSR and buy a 94GSR?
- b18a\b rods
- internal ?
- Its that time of month... time for some PADS!
- Spring Compressor
- Wheel Question?
- tranny coolant lines???
- Trunk question
- Tsud Cat Backs R Crap
- pics
- coolant leak
- alarm problem
- 3" Exhaust
- Knocking Driver's Side front tire/axel somthing...
- Wing?
- GSR head vs. SI
- integra gsr turbo question
- how many coolant sensors are there??
- 97 integra, stock stereo - hook up AUX adapter to back of stereo?
- Installed my first clutch...something is not right.
- bad idle and thick black residue
- Mystery On/Off Switch
- motor
- Obd1
- Rebuilt head
- Here is my 2001 Integra DC4 Turbo 12.529 @ 112.393
- GS gas mileage - overdrive?
- will second gen seats fit from 4 door to 2 door?
- One of those Weird problems?
- Auto tranny drain plug
- 1st gen ZC
- Weird idle, '88 Integra
- Apexi Exhaust????
- help with my car
- VR6 vs. GS-R
- Just Bought Plugs And....
- my car is running poopy
- ecu
- Quick Brake Rotor and Pad Question
- visual differences between itrs and other
- Turn signal bulbs
- Header Problem
- Clutch pedal has no pressure...need help fast
- What wire is to get the fans always working?
- Kinda New
- Clutch is acting up, but not slipping
- adjusting valves
- Bose Suspension...
- HID Retrofit help please?
- track racing/ street racing
- 1st time tegger...long time car enthusiast!
- pics of my type r
- I think my head gasket has blown?
- greddy evo2 exhaust
- msd btm on na motor
- Valve Help!!!
- Whats everyones Mileage ?
- What's a reasonable offer for this ITR?
- New Guy
- HELP! Turn signals not working
- "integra" Vs "2003 Neon Sxt"
- Foglight fuse? Relay? location
- door lock actuator
- Need Help Fast!!!
- Squealling now
- Power Window
- Turbo Questions
- engine pics
- Overheating Problem Help!!!!!!!!!!!!!!
- 1st time Tegger
- question on 90 tranny!!
- Modified exhaust?
- Acura emblems...
- brakes question
- Exhaust
- Clutch
- last turbo checklist...
- CAI Guys Beware!!!!!!!!!
- Integ projector headlight into foglight?
- Manual conversion in 95 ls
- city speed
- 98 integra fan help
- Revhard or Drag?
- weather stripping
- Engine bore
- Car sometimes won't start
- Timing belt replacement - After Action Review.
- heater sounds like its chopping up wood
- 1997 Acura Integra GSR
- SI tranny with GSR Motor..
- gonna blow this years bonus on a set of coilovers.
- Who wants a carfax report ?
- Opinions On Brake Pads
- installation
- 98-01 front bumper on a 1994???
- Radial Pull on tires
- Trans probs
- idle surging = pissing me off
- Help
- Whats the name of these?
- installing a vtec head on a 90 rs teg
- is my 2"drop mistake?
- what would you do? blown motor question...
- • Integra Gallery v2.0: Post Your Integra Pics HERE
- My car
- whole JDM front end conversion (clip?)
- Brake Lights!!
