door lock actuator
When I use the power un-lock (95 Integ) the driver side lock will click into the un-lock position about 4 to 5 times rapidly. At first thoughts it seemed to be the actuator. Any one had this problem?
it is most likely some screwy wiring...from the switch to the actuator...or it's being grounded out somewhere so it thinks that u are hitting the switch when ur not *hence the several locks and unlocks*...if u dont know what ur doing....i suggest ur local auto shop....it's not a super easy job
