HELP! Turn signals not working
Old Nov 20, 2005 | 12:07 AM
tientruong's Avatar
tientruong
Default HELP! Turn signals not working
Help, My turn signals wont work. When i signal left or right, i dont see the green blinker blink, nor do i hear the sound. My hazard doesnt work either.
my horn, break light, and everything else works.
I checked all my fuses, and they all have connectivity.
I dont know what's the problem. Please help me
Old Nov 20, 2005 | 08:26 AM
Brar's Avatar
Brar
can u still turn ur headlights on? high beams? u may need a new turn signal switch. c if u can get one from a junkyard cuz those can be costly new :x but it may be that...i havent had a problem with my turn signal but my headlights got screwed up in that same switch...so take it out and examine.
Old Nov 20, 2005 | 10:45 AM
tientruong's Avatar
tientruong
how does the switch effect my hazard? and yea, my headlights work, high beam too.
Old Nov 21, 2005 | 05:25 PM
tientruong's Avatar
tientruong
my whole dashboard lights are out. so are my standby lights, (the red light in back when you turn on your headlight)
any ideas?
Old Nov 21, 2005 | 05:52 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
sounds like the switch to me
Old Nov 21, 2005 | 07:02 PM
reno96teg's Avatar
hmm, check your fuses.
3rd gen (early) - should be similar for all tegs - layout:
under dash:
under hood:
Old Nov 21, 2005 | 11:07 PM
tientruong's Avatar
tientruong
I would also like to mention that when i press my alarm, my dashboard and signals blink. So that means it has power going into them. however, doesnt work when i turn on my headlights.
what does that mean?
p.s. i have a 96 integra LS se sedan
Old Nov 22, 2005 | 07:24 AM
jragon's Avatar
jragon
Does your parking lights (standby lights) on the exterior flash when you activate your alarm? That would mean all of your relays and wiring appear to be good. I would check for a connection that is faulty in your blinker switch.
Old Nov 22, 2005 | 11:26 AM
tientruong's Avatar
tientruong
Yea, they do blink so it has to be the switch.... the switch is the thing you twist to turn on the headlights and stuff? so why does the switch turn on the headlights? and not the dimmers/turn signals?
and... where can i find another one?
Old Nov 22, 2005 | 11:56 AM
Brar's Avatar
Brar
because the switch has 2 functions. and not on the same connectors. u can go to a junkyard or if someone is parting a G3 u can get it off of them for about ~30tops i got one for my G2 for 20
