- 99' gsr ecu
- Integra LS - turbo or VTEC
- question for the gear heads
- will 00 si dc headers fit on a 00 gsr
- New pics kinda gay
- what preps would i need for a turbocharger in a 94' ls
- Mackin Industries need test vehicle for ARC
- Camber/Suspension Question
- Intake/coolant?
- Integra GSR rear wing
- JDM Fog Lights
- Back seat removal?
- toda spec b's yay or nay! POW R cams
- need clutch cable someone help
- 1986-87 integra
- 95 Integra 4door Auto.
- Comptech Header
- just got dynoed
- Just purchased an Integra
- LS vs. GSR Suspension
- Oil pressure Question
- 94 to 98+ bumper conversion question
- Biggest tires on stock blades?
- Airbag switch
- WTF's that noise?...
- HELP: low control arm replacement
- Anyone have the newi Kosei K1 TS wheels?
- compatibility
- Grill insert
- Distributor
- Switchs
- Apex-i N1 Owners...
- Rear seats...
- help with head
- ls exhaust piping?
- ITR suspension on daily drivers?
- Tire Pressure
- need help installing skunk2 intake manifold
- My car is smoking but in front
- Itr #0663
- fuel filter question
- Anyone looking for the OEM Body kit, sides and rears?
- Which engine is likely to last longer - VTEC or Normal
- noise in front end
- vtec + ls tranny?
- Expo 4: Urgent
- How do I test ignitor and coil?
- Central grounding point
- LS <-> GSR catback fitting help
- Starter Cranks but Engine will not Start!?
- bumper pole switch as antenna override switch
- Help jacking car up
- new wheels and tires!!
- Timing Belt change
- what is this??
- KYB AGX Shocks Question
- jackson supercharger
- maint. required code? help please 96 gsr
- A/C line cracked and leaking!
- hydrolocked engine
- 97 DB rescued from a ricer YAY!
- Second Gen Exhaust Setup.
- thinking about getting a teg
- Clutch Q's
- Introduction
- New Member...
- new member to honda-acura.net
- Should I hassle?
- FS: Popular Parts: JDM 4-1 Header, Icebox
- cheapest way to gain torque
- speed limit govenor
- Eibach Prokits and Koni Yellow ?
- What type of Plug for B18C(Type-R)????
- Should I do it?
- Catalytic Converter?
- 93 LS just quit running "no spark?"
- Electrical Problem
- brakes..........
- Leaking bellows, fix now or can wait?
- need help with my ac... stopped working ... please help
- b18a/b crank?
- exhaust piping
- type r advice!
- What do u guys think of my set up?
- Are these tails JDM?
- Thanks to those who help in my search for a car for my daughter.
- block Q's
- Bought catback, now what? HELP!?
- rota fitment????
- LS or GSR tranny?
- I got a exhaust Question
- factory speaker size
- anyone know about D2's coilovers?
- Where is Main fuel relay on 92 Integra RS?
- Photo of My TYPE R
- Fuel Filter, replace how often?
- ITR Oil Pump Same AS CRV?
- New to Forum (saying hi)
- I need TIPS in driving new wheels & tires
- What type of teg?
- Spark Plugs Cold or Hot to use?
- Over heating?
- Gaskets or Seals?
- New owner.
- ice box with stock pipe? searched...
- setting idle/timing on tight budget
- need help! cam seal prob.
- Good bye R owners
- Help Timing Belt Broke On My 94 Integra While I Was Driving!!
- Ac Low pressure outlet
- 92 Integra RS Starting Problem
- turbo and road trip?
- Motor Mounts
- Tranny fill bolt WHAT SIZE?!?!
- short ram VS. cold air
- what clutch do you guys have?
- Stiffest non-adjustable shocks
- burning oil at 4k
- poking thru
- Ported Si intake manifold swap for my GSR
- Stolen TEG in Miplitas, Ca. Century theatre in Great Mall
- Fuse Question.
- antennae problem
- Wystar tires
- help!! seafoam prob
- resetting IAC valve - 92 Integra LS
- how long should it take me....
- how to wire
- weighting options for looks
- A/C compressor/clutch problem???
- getting ABS DTC code 17, how to fix?
- mounting kit stereo
- pls. help check engine
- B20 Swap Concerns.
- SRI or K&N
- Body Kits
- Need some V-AFC2 advice.
- accident....pics*
- Camber Kit / Suspension questions
- old teggy maintenaince
- hatch release problem??
- Learn to drive Stick
- R.I.P 1994 Acura Integra GS-R
- Do all BlackI Integs have Tan Interior?
- Should I get a used RS/Vtec?
- What grade of gas should I put in my 00 Integra LS? 87--89--91?
- one more problem for my friend
- How do I "regap" spark plugs???
- Chassis life?
- rough idle: 92 Integra LS
- itrca.com is down
- Fog Lights.
- auto parts stores
- Newbie Question (No luck w/forum search)
- clutch question again
- exhaust on 01 gsr
- Insane Timing
- lowering my teg
- Unorthodox racing pulleys
- Need to Understand N20
- 2001 type R lip on 97 GSR
- HID"S for the teggy
- Wind diffuser?
- 2000 Gsr
- 91 teg running as if on 3 cyl
- just some new pics of my very stock dc2.
- Best places to purchase Cobalt or Hawk Brake pads?
- hdss
- One Peice Lights
- spark plug info
- 91 RS --- Wont turn over
- Where to buy GCs and shocks?
- Humming Noise
- leather steering wheel...
- auto transmission question
- exaust suggestions
- Sorry for the huge pic, but is there any way to tell if these are truly ITR springs?
- NOS wet kit or not
- Turbo Help
- Car Vandalized, looking for part
- I wanna go lower
- My new axle is crap
- 2nd Gen Teg'
- KYB AGX, ebay
- oil leak... need part?
- Thinking about getting a 97 gsr
- GSR Tranny?
- Can anyone car fax this VIN for me?
- Type R swaybar
- Backpressure?
- sub air filter?
- vtec all motor?
- anyone know this car's paint code?
- Maitenence Light
- 92-01 civic windshield in 94 integra?
- Price
- clicking noise cam gear area
- lbs... kgs... oh spring rates?
- my R is giving mad problems
- People who own a Skunk2 dual bend shifter.
- 205x17x45 series tires
- 205x17x45 tires
- Vis carbon hatch
- Vibrating steering column
- vtec conversion
- xenon headlights
- Odometer
- full coilovers vs. sleeves + shocks
- 92 teg,now what to do?
- fuel pump??
- Clogged cat?
- Best Fluids for 00-01 GSR
- Hello, and I have a question
- Final Drive of 4.9
- Teamtoilet DVD is now Available!
- 96 LS Shift Release Lock
- cv boot joint
- Friend wrecked Integra - Buy for $400?
- Dual exhaust
- 94-95 oil pan fitament
- hondata ???
- Integra Suspension Help Needed
- integra jdm's
- Who owns 1998 integra?
- Please Help!!
- Transmission Q
- clutch/flywheel recommendations?
- Stock Alarm Goin of Like Crazy
- Cam Gear help...what brand to get?
- will this fit on my 99 integ?
- Greddy Turbo questions and a few others
- Need help finding a shop in Cleveland
- Golden Eagle products ANY GOOD?
- Remus Exhaust...please give me your opinion
- Adjusting Integra Headlights
- OK, I know you guys hate n00b posts...
- LS/vetc swap
- Halo Projector Lights
- check engine light after r134a retrofit
- What rotors/pads do you guys have?
- running wire through firewall
- tire question
- reduce stiff ride!
- spoon themostat
- Plexiglass- is 1/8'inch too thin for windows?
- RSR Exmag pics?
- setting up an exhaust, thoughts?
- b18a1 vs b18b
- throttle body question
