PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. possible dc4 future owner, any known issues?
  2. engine stand bolt up location
  3. hey guy just saying hello
  4. Type R rotors
  5. integra [1990 GS w/ starting problems]
  6. gsr with high miles
  7. Teggy owner taunting fellow Teggy owner-What Gives???
  8. breather chamber
  9. MAP Sensor
  10. I know this isnt a teg question but?
  11. ECU code
  12. PCV valve & hose
  13. Hi guys!! Newbie here with 1st integra!!!
  14. need a decent wire set
  15. sunroof
  16. test spark plug wires
  17. dupli color paint
  18. 97 Integra brake pad retainer breaking
  19. need advice for a replacement part
  20. Has anyone bought a hiflow cat of ebay?
  21. turbo and boost question
  22. ACT vs Exedy
  23. i hear a squeak
  24. Good deal or bad?
  25. passenger door sticks?
  26. Tired motor, what to do?
  27. transmission flush
  28. 1997 acura integra ls cd player error code
  29. Sorry
  30. Matching right pads with rotors.
  31. wrong distributor on my teg?
  32. oem springs
  33. gasket prep??
  34. Tranny issue
  35. Transmission: Replace or Repair
  36. would replacing radiator cause AC not to work?
  37. My first Integra ^_^
  38. do i need one more
  39. Exhaust Leak....
  40. Purpose of the engine breather tube?
  41. gsr going crazy
  42. Speedometer stopped working
  43. What do you think?
  44. squeaking
  45. Overheating Problem.. Please help.
  46. Spark plugs
  47. Car runs great but cant keep tailpipe clean
  48. Question about Windshield molding/stripping
  49. transmission
  50. if i am runing rich i should?
  51. Curse you dizzy!!!
  52. c pillar bar instalation
  53. 0-50 Eneos Full Synthetic Race Oil-Good or No Good?
  54. Spark Problem
  55. Kyb Agx with Eibach Pro Kit
  56. GS-R Price?
  57. more problems
  58. funny noise..HELP
  59. help - fuel pump not working after head swap - 87 integra
  60. OEM brake rotor prices
  61. gsr turbo
  62. Basic Turbo questions
  63. min. rotor thickness
  64. power antenna switch?
  65. air leak
  66. H&R Integra/Civic dilema
  67. ITR Motor in an LS. Need Help.
  68. idoling problem
  69. inexpensive buffer
  70. Need help passing DEQ!!!!
  71. rim repair how much?
  72. back seats
  73. Distributor Problem?
  74. 1994 integra radio code needed
  75. What to do..
  76. Rota Slipstreams
  77. rims im going to buy good deal PICS!!! ON car
  78. Yellow tinted headlights/high beams
  79. Lights
  80. Is It Meant To Be?
  81. Found the leak!!!
  82. Comparison
  83. Integra seats interchange
  84. car running poorly
  85. Teg body styles
  86. Tax $$$$$$$ = ?????
  87. Is this a bad thing? I think it is...
  88. VTEC controller
  89. Thank you, my GSR, and security
  90. JDM ITR conversion...
  91. EXEL - Paris Wheels
  92. 2000 Integra LS Suspension Nosie
  93. 99' integ brake pads
  94. trouble with a rear strut bar
  95. GSR Clutch
  96. hottie in distress!!
  97. Boring Stock GSR???
  98. Clamps too weak for BOOST?
  99. Need more head room
  100. 91 Integra idel problem...
  101. tsudo N-1 cat back exhaust Sound Clip anyone?!
  102. JDM ITR Header on 94 GSR - Buzzing A-pipe
  103. Fixing Up AN LS
  104. 1990 integra..prolbems with starting...relay prolbems
  105. Will Integra LS Motor Mounts fit on a B18C?
  106. racing seats in the fron and back
  107. 91 Integra GS RPM Raves
  108. quick question
  109. totaled gsr
  110. gsr cluster in a 95 ls
  111. vtec engagement
  112. im thinking of doing this
  113. VIS or Seibon cf hood? or other?
  114. Just sold my LS.
  115. Rat out ur homies and get $250!!!!
  116. Broken bolt
  117. How many belts are there in the GSR?
  118. Do i need a new valvecover gasket guys
  119. greddy turbo kit with 24v intercooler for sale
  120. Engine Build Question
  121. Internal Upgrades
  122. Turbo and Wastegate for sale
  123. RE:Slotted vs Cross Drilled?
  124. rebuild issues
  125. Sound......
  126. since when do these fit on tegs?!
  127. how much hp did i gain with my i/h/c/e
  128. pic request rota attacks on g3
  129. 89 prelude si vs. 91 integra ls
  130. new shocks/springs
  131. springs....
  132. How much to rebuild transaxle?
  133. Engine build up
  134. jdm radiator support
  135. Fuel Rail Question Part
  136. how many type r's did they make
  137. Front and rear lower tie bar
  138. what would the compression ratio be ?
  139. catalytic converter?
  140. My 92 RS Daily Driver
  141. VTEC wiring-JDM B18C in 97LS ** PLEASE HELP
  142. must i replace this?!?!?!
  143. help?
  144. 5Zigen GN+ on my teg?
  145. Any way to get CEL back on?
  146. evap emmission purge control solenoid
  147. Intermittent ilding
  148. Itr 00-#1494?
  149. Looking for imputs about brake kits for 94 Ls
  150. Before and After - Must See!!! Help!!!
  151. Type R suede seats
  152. Steam Clean Engine Bay. Good or Bad?
  153. Gas cap question ????????????????????
  154. '94 Integra Blower Motor
  155. DC Integra Headers - GSR or LS/RS?
  156. Rear Motor Mount 96 GSR
  157. Sick of researching intakes, just need 1 question answered.
  158. black or red whats the difference
  159. Anybody w/ Rota J.Spl's?
  160. p8r head on my ls
  161. Need Help
  162. low oil pressure light
  163. Oil pressure gauge threads???
  164. not sure if right thread, but need some rim help
  165. help?
  166. idle problems
  167. Integra LS: erratic idle, drags decelerating
  168. 95 integra dash.
  169. Anybody use the Fumoto valve?
  170. 95 gsr burning oil heLp!!!!
  171. thoughts on an underdrive pulley
  172. painting turbo and manifold
  173. Planned setup
  174. 99 integra code for radio????
  175. DSM injector ?
  176. Just wondering what you think.
  177. tires rubbing in u turns, need help!
  178. Better Header
  179. Fair price for a GSR clutch install?
  180. red "A" emblem, where to find?
  181. special or home depot will do?
  182. Help just bought an integra!
  183. Which one of these strut bars is better
  184. how do i put an h22 in a 94 integra
  185. My two babies[IMG]http://i51.photobucket.com/albums/f386/Montanatoni/twotypers005.jpg
  186. i need instructions on how to pull a radiator support for a 94 integra
  187. Need shop in LA area
  188. strange squeak
  189. unorthodox pulley kit
  190. Kind of a dumb Q...acuraparts247.com
  191. integra DA
  192. Vtec conversion from golden eagle
  193. '95SE What's it worth?
  194. do trailing arms making creaking/sqeaking noises?
  195. how do i romove and take out a radiator support for a 94 integra?
  196. Seafoam...
  197. Help w/ a 94' Integra
  198. Fluctuating Idle and Steam
  199. 91 teg with 94 gsr swap???
  200. building a gsr
  201. Inline pro manifold
  202. building an LS motor
  203. '91 Cold Air Intake Install
  204. Suspension Help!
  205. Coil-overs & rear swar bar Help!
  206. front bumper
  207. loud tapping
  208. Tranny Swap 95 Integra
  209. Help me find a good deal!
  210. Oil Filter Problem
  211. DC steering wheel on DA
  212. Finally....A small vid of my car!
  213. painting intake
  214. Integra LS misfire??
  215. URGENT Oil Pressure Sender Size
  216. compassion with those who know less!
  217. Problem with clutch - 2000 acura help!!!!
  218. Pictures of Spring heights integra and civic
  219. 00gsr, cant rev past 5k..feels like fuel cut, help!~
  220. $5000 to start.
  221. Torqueing Turbo manifold
  222. spark plugs and wires?
  223. Intake Manifold before LSVTEC
  224. Engine won't stop
  225. Just because...
  226. GSR get!
  227. Internal Upgrade
  228. Ls Cai
  229. rpm jump/shake?
  230. 1991 Integra hatchback
  231. What next....?
  232. Purchasing 2001 Acura Integra 4 Door Automatic Sedan
  233. 92 integra bogging down
  234. oil leak
  235. LS rides like a boat?
  236. "lug nuts" ?
  237. Type R accessories
  238. need help on the pulley/drum
  239. GSR-LS Intake
  240. Need expert opinion on this car I'm buying
  241. Vafc- Plug And Play Harness
  242. I need everyone help!
  243. I need everyone help!
  244. intake manifold
  245. Where's the best place to get a rebuild kit?
  246. Thinking about b20 vtec
  247. Brake bleeding question
  248. b16a1 spark plugs
  249. skunk2 vs Blox cams.
  250. Fuel pump relay question....
