Kyb Agx with Eibach Pro Kit
Old Mar 12, 2006 | 10:57 AM
Schwa's Avatar
Schwa
Schiggity
Default Kyb Agx with Eibach Pro Kit
How good is this setup for the teg? Will I need a camber kit? Drop says 1.3" F and R.
Thanks
Old Mar 12, 2006 | 02:51 PM
dubcac's Avatar
dubcac
I
Most likely won't need a camber kit, but you will need to get an alignment to adjust toe. Should be a decent setup if that's enough drop for you.
Old Mar 12, 2006 | 03:16 PM
kartman2's Avatar
kartman2
Default H&R and Agx's
I have the same setup with H&R race springs and it is working well. Still
need a new alignment but the rest seems good. The drop was more than
I expected. (1.5 - 2.0 ")
Old Mar 12, 2006 | 04:28 PM
Schwa's Avatar
Schwa
Schiggity
I know a lot of people were/are running H&R springs, just wanted to see if the Eibach Pro Kit was a comparable spring, and to make sure the springs and shocks are well matched. I'm waitin for TheOtherDave to chime in...
Old Mar 12, 2006 | 04:52 PM
Schwa's Avatar
Schwa
Schiggity
Actaully, just did a few searches and I found what I wanted. Seems liek this setup is pretty decent for a daily driver. Feel free to give opinions though
Old Mar 12, 2006 | 07:01 PM
dubcac's Avatar
dubcac
I
The springs are good....I had them on my old prelude. They didn't provide enough drop for my taste for the integra, so I went with H&R. Great spring though. I have the H&R sport combined with KYB's...great setup.
Old Mar 15, 2006 | 10:43 PM
sk8ps's Avatar
sk8ps
I have the agx adjustables and the eibach sportline setup. Personally I would have preferred an even lower drop, but it still looks nice. My rear tends to sag a bit but not noticeable to anyone but me. I like the shocks but the adjustability doesn’t alter much. I have tried EVERY combination of adjustment and I can BARELY tell the difference. However; this combo is like night and day over stock. You may not need a camber kit, but my setup did. I used the Skunk2 adjustable upper control arms and several washers in the back. I took the car for an alignment and they didn’t even charge me. They said I had it perfectly aligned. It took about an hour of eyeballing the stance for me to get it set right, but that hour saved me 50 or 60 bucks on an alignment, or better yet a set of tire.
Old Mar 16, 2006 | 03:09 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
dubac, you have any pics of your car?
Old Mar 16, 2006 | 07:40 PM
95tegraGSR's Avatar
95tegraGSR
I had this setup on my 98 Eclipse GS-T and loved it. The ride was really nice.
