ECU code
Old Mar 17, 2006 | 05:24 PM
koter18's Avatar
koter18
Default how to remove Check Engine light
my Check Engine (Malfunction Lamp) light came on a couple days ago n stayed on til now...the guy at a retailer where i got the car from said car's running fine but i wanna know HOW TO REMOVE THE LIGHT FROM THE GAUGE...
Old Mar 17, 2006 | 05:35 PM
Schwa's Avatar
Schwa
Schiggity
Remove the negative terminal from your battery for 10 seconds, this should reset the ECU. IF you have the stock radio though you will need the radio code to reactivate it.
Old Mar 18, 2006 | 03:48 AM
koter18's Avatar
koter18
Default ECU code
my check engine light came on so i checked n i got the code 3 which is MAP sensor.
could putting a short ram intake cause the light to come on?
Old Mar 18, 2006 | 06:08 AM
teg92's Avatar
teg92
WHAT OK YEAH!
putting an intake on wouldnt cause a check engine light to come on. Try re-setting your ecu and see if it still comes on.
Old Mar 18, 2006 | 06:56 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
If you possibly unplugged the MAP sensor or even pulled a wire out of the connector then yes, it could. If one day everything is fine, you change something, and then it's not. 99% of the time whatever you did caused the problem. I'd retrace my steps and ensure that what you did didn't have an effect on it. Resetting the ECU will not magically solve the problem. The code will go away if you fix it.
Old Mar 18, 2006 | 07:01 AM
hondaripper's Avatar
hondaripper
Default lights
you shouldnt remove the light because it means something. its on for a reason. what type of car is it?
Old Mar 18, 2006 | 07:18 AM
koter18's Avatar
koter18
Default how bad is this?
got the code 3 for ECU which is MAP sensor: defective circuit or defective sensor
i'm trying to fix this myself(can't afford to pay rite now). Please help!
Old Mar 18, 2006 | 07:31 AM
koter18's Avatar
koter18
i agree w/ u westcoaststyle but all i did was putting an intake n there was nothing to u as you'd know... since it's a defective sensor problem should i not worry bout it too much?
Old Mar 18, 2006 | 07:45 AM
westcoaststyle
Check the wiring. Go over the steps you took putting the intake on and see if anything's up with the MAP sensor. That's not a sensor you just want to have messed up. The MAP sensor is what reports to the ECU regarding your the pressure inside your intake as opposed to the pressure outside. The ECU reacts to this sensor by updating fuel/timing maps. If the MAP sensor isn't reading correctly, your ECU isn't dynamically tuning the engine correctly resulting in poor performance and gas mileage. It needs to be fixed.
Old Mar 18, 2006 | 07:48 AM
westcoaststyle
Wow, this is a thread full of horrible information and advice. Again, please keep your questions regarding the same problem in one thread. Don't create multiple (now 3) about the exact same problem.
