ECU code
Old Mar 18, 2006 | 07:52 AM
Duce's Avatar
Duce
i had that code a while bad replaced the map sensor fixed the problem they got them on ebay for like 40-50 bucks
Old Mar 18, 2006 | 09:12 AM
koter18's Avatar
koter18
i went over the steps very carefully n just IAT sensor not MAP sensor... how bout i just replace the sensor n see? or is there any other way? what u said up there sounds kinda serious...
Old Mar 18, 2006 | 11:54 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
I've merged these 3 threads together now.
Seriously, there is no need to start a new thread for each phase of your diagnosis and repair. :a:
Old Mar 18, 2006 | 11:57 AM
F22H22's Avatar
F22H22
just hook up a scan tool, or go to autozone for a free scan tool test and they push 4 buttons and its off, takes like 20 seconds
Old Mar 18, 2006 | 12:03 PM
TheOtherDave™
Apathy Kills
What on earth are you saying? :eh:
"... very carefully n just IAT sensor not MAP sensor..."
Are you telling us that you only removed the IAT sensor and left the MAP sensor alone?
If we're going to help you diagnose the problem, please use real english so we can understand you.
Old Mar 18, 2006 | 12:05 PM
TheOtherDave™
Apathy Kills
Christ... that's not going to tell us anything new. :a:
Resetting the code is not going to fix the problem either.
He already has the ECU code and has looked it up.
Plugging a scan tool in is not going to magically fix damaged wiring or repair a faulty sensor.
Old Mar 18, 2006 | 12:33 PM
koter18's Avatar
koter18
sorry for misunderstanding... wut i was sayin is that the instructions tell me nothing about the map sensor. they do say about the iat sensor but only for other models like civics
Old Mar 18, 2006 | 12:45 PM
TheOtherDave™
Apathy Kills
So.. when you installed this intake you never removed the MAP sensor nor disconnected the wires leading to it?
(I'm just confirming that I understand you fully.)
PS: What year is your Integra? Also is it a RS,LS,GS or GS-R?
Old Mar 18, 2006 | 12:48 PM
koter18's Avatar
koter18
i did disconnect it(just the plug from the sensor) once or twice b4 n after the light came on
i hav a 96 rs
ps. just found out that i could test the sensor w/ a voltmeter, does anyone know this method?
Old Mar 20, 2006 | 07:51 PM
gsrsol's Avatar
gsrsol
slow and low
yeah if you set it to read ohm you should have a sertain amount of resistance if you don't if its more/less then it is a bad sensor. although i don't know what it is supposed to be. sorry koter
