- Bumper Repair
- Power Windows Won't Roll Up
- Ls vtec
- guys.. are the coupe and sedan hood swappable?
- carbon fiber install
- ITR axle back
- Finally got updated pics of the GSR keke... :P
- Focal R3's
- carbon fiber integra
- ITR Number Placard Location?
- My PIX trying to get working tell me if it works?
- exhaust question
- KYB-AGX with H&R Sport Springs
- integra engines
- Noisy valve train
- Vacuum Lines for GSR IAB?
- To keep the cops off my back....
- Idleing Low at 500 RPM
- Switching from G2 to G3
- One of the most noobtastic Q's I've had in a while... Tire Pressure.
- Stage 1 stage 2 clutch Question
- Installing SLR/Diablo LED Mirrors?
- 90 SiR b16head
- Hydrolock & a bent rod
- 450cc DSM injector seals
- Shops in TN?
- stuck '95 teg sunroof
- weird bolts on my clutch!
- Oil pressure Switch Socket Size?
- plans for future mods
- back fire... help
- My cold air intake what a pity and funny story....You might learn a thing or 2 here..
- starter problem
- All engines that can fit in an integra?
- Am i getting ripped off?
- my 91 integra
- Mystery of the Month..Where is the valve screw?
- Chip Reader for 92 Integra
- Whats The Difference between a Gs-r and a Ls??
- Gas Milages
- Good shocks???
- buying teg . . . good deal or what ???
- Skunk2 vs. Spoon Rear Lower Tie Bar
- Integra fuel pump kill switch??
- 95 TB install on 96 gsr, need help
- Heeeeelp, push red button then engine go Boom!
- 400hp Type R
- Bad Vibrations
- IAB's, wiring and possible problems (97GSR)
- B16B vs B18CR intake manifold
- haters messed up my car....
- DA vs DC?
- 90 Integra o2 sensor question
- performance chips
- Tuner Shop
- Compression for Nitrous
- Integra GRS vs LS Manual transmission
- New suspension
- B18A1 ?'s
- Has this ever happend to you? AC Question
- valve adjustment?
- differences
- Gauge Pod Cracks, Odometer, & Sunroof Questions
- power windows
- 1998 Integra Manual Transmission Problem
- Replaced headgasket, need help
- no more PPL 24458??
- Need Damper (Shock) Replacement Recommendation
- can u fix a iacv by cleaning it
- Im trying it!
- rear squeeling?
- idle control sensor help please 911
- ??? Abut Timing Belt
- what is a fuel relay
- Help my car wont start!!!! Fuel relay or electrical problems??
- Skunk2 stage 1 cams vtec problem
- MSD 6A + '92 Integra GS-R
- Little help
- oil pressure
- performance Mods
- lsvtec 2.0 turbo
- i just got an idea
- Bleding ABS System
- What's best place to change timing belt for 98 LS?
- need timing belt for dummies
- whats needed for a 5 speed swap?
- help...C.E.L light 70
- The new b20 issue
- Help. '92 Integra Electrical problem? Big short in the system?
- Cooling System Issues...Please Help!
- stereo system pics plz
- please help
- 1998 Intergra GSR Driver's side window...
- New ECU problem!
- 98 GSR Coolant resevoir. Question on level.
- lighter flywheel losing torque???
- I just went for a lil drive...
- over heating
- ABS Accumulator Replacement
- Gone-
- TB install
- PWR or Fluidyne or Koyo
- "Mystery Intake Manifold Theatre" - a two part series
- grille questions
- Rim questionz
- DC Header Gaskets?
- More torque!!!
- type r manifold
- Rubbing / grinding noise from front right
- Metallic Rattling at 3500 rpm
- Tire Rubbing Front Fender?
- ok b20VTEC part2
- 1994 Acura (3dr Auto) - Ignition/Milleage/Dampness
- 2.0L integra
- Picture of Carb badge on headers
- Suspension Squeaks Bad
- Help!!! My teg just stopped running....
- New Plugs, Rotor, Cap and Clutch
- Integra LS Surging, Idling, and general crapiness
- Overtightened Spark Plugs
- how much will a turbo shorten engine life?
- My idling is steady but a bit higher than normal
- Just got a new clutch, need help!
- The last piece - comment on my exhaust plan
- Advancing Ignition Timing
- Dead!
- suspension noise - front end
- good deal for price ?
- Need To Borrow Stock Intake
- Integra 5 lug hubs.
- Dual Bend or Single Bend Short Shifter?
- slight oil leak
- Better Ac Refill
- 93 Factory Manual
- Mud Flaps on 91 teg...
- DC 4-1 header
- Radiator Trouble
- Intake Manifold gasket leak?
- 94 Integra with OBD2 GSR Engine - Failed Smog
- Update on Motor(b18c5)
- Timing chain replacement
- gsr vtec
- b16 head vs lsvtec conversion
- extended wheel studs?
- Tail light(bulbs) question
- OEM Plugs Pregapped?
- aftermarket parts
- looking for a good mechanic/shop in LA valley
- Question about AC
- the short....90 ls
- Help! How do I shut off "Maintenance Required" light?
- Manual swap or everything swap?
- My shifter is very sticky !!!
- Compression
- Adjust and tightening timing belt
- 94 Rs Idle And Speed Niddle Goes Up And Down And Car Turns Off
- TEG oil Problems
- pr4 or p75
- 94 Acura Integra Maintenance Required
- Control Arm Problems...Help
- Orange Corners for 96 Integ
- weird vibration on one of the plug wires
- how can i lean out my fuel mixture?
- new car questions
- new teg owner, got ?'s
- K&N FIPK
- Oil Pressure gauge
- Oil pans that fit on a GSR
- Car idles way too high
- What can I do with my JDM headlight
- Replacing Alternator on 89 Integra
- First flat on teg
- My suspension questions
- Bumper and Corner bulb
- kill switch
- top speeds
- help on turbo
- Which Cam to choose on B18B?
- What is that burning smell from my exhaust?
- Just a Couple OF ??????????????
- resistance for ignition coil
- Dub's for '98 LS
- Question about telescopic antannae and rear hatch release
- G2 Widest and largest rims with a 1.5" drop?
- Is this a normal security thing in my car?
- Cai Or Sri
- Trying to get the most speed
- How much will stock exhaust hurt this setup?
- trouble HELP-
- a couple of questions!
- Please Help My GSR Has No Power
- 92 B18 in a 90....Someone answer a few questions?
- Skunk 2 IM w/ SRI or CAI?
- removing rear seats?
- Integra LS Horn problem
- Anyone running 16X8 wheels? Too wide for teg?
- what is redline for ls?
- Raising up the front w/ lowered suspension?
- 350z exhuast...on integra?
- Transmission won't shift when stopped and engine running!
- Just received my first mod
- Black Wheels
- 95GSR Blown Coil - wont start
- Rotors from 95 del sol fit 95 4dr gsr?
- DC Header dyno?
- Fuel Question
- just bought, no reverse lights
- Shift Problem ??
- Gone for 4 Years
- should i ditch the b18b and go with a b17a?
- General A/C Question
- Its Gone
- rims on 2000 gsr
- I cant get over 120 mph in my gsr!!
- I didn't know My 91 teg had four wheel disk brakes
- 90 4dr
- shaved emblems?
- DA trailing arms... 4door -- 2 door .... same?
- turbo timer?
- AC problem.
- turbo for sale?
- 90-93 integra fenders
- A/C Compressor Relay
- Looking for part: Passenger Blinker Mount
- Question About A/C & Compressor
- valve cover
- Helms manual for 94 and later integras
- Just got a B20z
- Integra Radio Removal
- Can anyone identify this Cat Convertor
- best integra deal u think i could get for 5 g's or under
- Need Help Please!
- Oil Leak
- Brake Hose
- cluster removal?
- I need a clutch!
- Acura Integra tops most stolen list
- strut tower braces
- Almost ready to dyno - check my mod plan for holes
- best pour in cleaner
- wiper fluid motor problem
- Engine builders in MA/RI/CT please help me!
- Will a jdm type r exhaust fit into a '96 LS?
- Where to buy OEM Parts?
- in need of body parts for 91 ls
- Looking for '98 ITR #264
- help! smog test problems on 96 integra gsr
- Gas
- Engine Sputtering
- Replacement Parts
