- Why won't my gas light ever come on? Please Help!
- obd0 vtec distributor rotor problem
- 91' acura integra rocker arms.....fixed or no.......
- Coil / Igniter question - '94 RS Won't Start
- Best all around tires
- GReddy strut bars
- 90 Integra and 93 GSR AC removal
- CF Hatch
- 30 + Hp $9.00?
- Modacar STB
- Question about valve cover gasket?
- car won't start
- Illegal Drag Racing
- catalyctic converter after engine swap
- Help
- people with 1 piece header....
- JDM ITR Hub, Brake help
- good price for 92 gs-r?
- Need Info On Part Replacement for Potential Buy
- fuel filter
- So...
- How do I determine my chassis?
- 96 LS with some goodies
- 90 Integra tranny problem
- Bay Area body shop
- ls/vtec 2.0 liter turbo
- Why ME!
- weight reduction question
- Oil leak
- LS performance
- 94-99 gsr 4dr cat-back on a 97 gs 4dr?
- vtec lag
- Argh...Battery issue
- Can someone tell me what this is under my dash?
- tranny ?
- picture of my timing belt
- Are LS and GSR aftermarket headers compatible?
- howling brakes
- This sucks.....
- I need some help...
- Location of Main Relay:
- 5zigen fireball exhaust?
- jdm b18c ecu versus usdm ecu...
- Thinking about selling my teg..?
- 1991 integra RS, Cheap mods
- Hello, new to forums
- integra dual exhaust
- short shifter question
- HELP QUICK - brake master cylinder
- quick question
- lowering ?
- Misfire codes, fouled plug, bad idle, and bad MPG (SEARCHED)
- looking for a high flow cat for 94 gsr
- Vent help
- Idle Problem after skunk2 install
- Integra Problem
- Help - No pressure in radiator and car is half way to overheat
- AEM short ram, good deal?
- possible fraud
- Gauges
- What year? How much mileage?
- COMPTECH Stainless Axleback Muffler ON A 4DR
- External Coil
- off-white for teg?
- i need new cv shafts?!
- 9005 vs 9006 headlight bulbs?
- Why don't my clutch work?
- What brand turbo pieces?
- Exhaust Purchasing
- CV Boots Dry Rotted
- Best engine dress up kit?
- Blown Timing Belt
- lights ?
- Best Place to Buy...
- quick ??? auto 2 manual
- Bumper question ?
- i photoshoped my car *PIC*
- How old (a driver), if any age, is too old for a modified teg?
- Replacing camber kit bushings.
- twin intake filter??
- Integra rattle shakedown
- Teg questions
- CV Boot broken, engine won't start, is it because of a sensor to boot?
- Master cylinder ?'s
- LS-> GSR oil pump
- rear seat problem/question
- To old to mod??
- header for a 91 integra with b18b motor?
- obd2 ---> obd1 gsr TB
- Help me ID these cam gears!
- What is the best Integra for $2-$4,000?
- My Integra broke down, do I need a new engine? Help!
- Hello
- catback exhaust or header?
- good buy????
- Battery light, ABS, and SRS lights on while driving
- Coil overs / to raise vehicle
- My gsr and my friends ls
- Rim width for 92 TEG
- Just for fun...
- Front Hub Repleacement
- JDM Wheels
- Removing underbody heatshield?
- I'm so excited I can't see straight - Just got 94 GSR from original owner!
- Help on Integra Side Molding?
- Took a few Pics today 93 Integra
- ITR Manifold
- Determining motor's health
- I think my starter's going out...
- Stealth tach idea's
- Part number for the stock GSR change holder thingy
- Replacing Clutch...
- A very awkward request.
- trouble starting sometimes
- Battery relocated to trunk...
- Brake Dust?
- 3rd Gear doesn't engage please help!!
- How do you like your Integra...?
- JDM Cluster
- ITR Cam Gear upgrades?
- 95 GS-R Main Caps
- 2.25" exhaust worth gettin?
- oem rear bumper and rims
- help!
- Turbo Auto?
- AWD teggy
- is my sunroof button supposed to be lighted?
- Intake Air Bypass queston???
- Can I put any B16xx header on my GSR?
- 18" tire prices
- ECU Switching?
- Idling Problem and Misfiring
- front end noise when turning
- Got Cams, Do I Need Camshafts?
- Hi, introduction/questions
- Wilwood BigBrake Kit - opinions?
- WOW... this is a pain in the ass!?!?!
- need new engine mount
- Stupid AWD question
- Motor swaps...tell insurance?
- How difficult is it to replace the front bumper?
- Intro...
- trunk light
- newb 93 teg rim question
- Is this normal for "old" disc brakes?
- 98 Acura Integra - Engine code1456
- Engine Swaps for the ITR
- how do these numbers look?
- Quick Important Question????
- Blue Smoke
- launching rpm for you gsr...
- clutch slip? or in need of lsd.
- Yay...bent valves!
- replacing o2 sensor in my integ
- Cleaning VTEC solenoid?
- turbocharging the type r
- Anyone know of a good website for Rota wheel/tire packages?
- 92 Teg wont start, no spark
- "Dead Cat" and ?s
- 2000 GSR Threw Code 71, Should I be Worried?
- oil pan gasket replacement
- Burning smell from air vent when braking to a full stop
- no 3rd brake light legal??
- Map Sensor And Emissions Control System
- Installed!
- oxigen kit?
- Tire on the bypass
- Problem with Electrics - Dials, Remote locking, Radio and security not working!
- Problem with Electrics - Dials, central locking, security all not functioning
- What causes "sticky" disc brakes & how to fix it?
- Proper Heel-Toe Technique
- Best place to buy brakes for a Canadian?
- just bought a Teggy..
- my teg!
- Brake system loses pressure? 95 Integra
- Went to get my alignment....and
- iat sensor 97 teggy
- 88 integra wiring diagram
- How Do I Remove The Bottom Pulley.....
- Integra w/ a swapped engine!
- what do you itr owners pay for insurance?
- Timing belt break 95 GSR
- NEED Integra Antenna
- Question about 94 Integra Sunroof
- Ooops... busted nuts
- How difficult is it to remove the "floor console"
- What is the best color for the 94+ Integra?
- pencil through vent
- Where are the bulbs located? (floor shift indicator)
- Shift Lock Release
- Does 94 GSR have a stock alarm?
- Intake + water = bad
- I need seats!!
- Need to know some fundamental Info about the GSR!
- HID Problems
- ITR with or w/out spoiler looks better
- timing belt kit question
- tranny problems
- I want to tow with my TypeR
- integra cai install help!!!!
- When 1st Tuning Your Teg
- 93 integra intake
- GSR mounts vs GS LS RS mounts
- carbon fiber overlay for gsr cluster?
- Integra down - need help
- GSR vs Prelude
- vehicle speed sensor [repair] **Merged**
- what is this part ??? *PIC*
- So I Have A Bad ECM...
- Knock sensor
- looking at a 2000 GSR.. help
- Door speakers
- Who Would Win????
- whats up, look at my 2001 integra LS Turbo [12 sec]
- two fuel injector failed within a month ?
- spring rate
- Climate Control Out of Commission, HELP!
- How difficult to replace a "D" buld in the dashboard?
- fuel filter washers
- Strut Bar Problem
- sway bar
- my taillights
- gauges problem
- need some help
- Got Some Good and Bad News
- Which mount could it be
- whiteish/greyish exhaust color
- 92 teg gs w/abs...booster interchangeability???
- 97 GS sedan
- Suspension Issue??? Weird Noises...
- Want to push out dent on rear panel, help.
- RS*R ExMag muffler DOES IT FIT A 4DR?
- Major Issues With My Teg?????????
- Motor decision
- Need help...can't rev over 3500 rpm
- Weak VTEC
- Might be a new member to the Honda family
- water leak please help?
- GSR spark plugs... where to get them?
- Type R Side Skirts !!!!! Need Help.
- civic cat back on integra??
- South meet 16th of July sandbanks
- idle problems
- USDM wheels vs JDM wheels
- Will This Setup Work?
- CEL On
- Still Stuck! Creative ways to remove crank pulley nut
- Engine Planning
- Put the WS2 on my Integra last night.
- venom 400
