- Greddy EVO fitment
- short shifter
- limits of gsr stock internals
- 4dr Integra GSR
- lowering in NY
- window
- Engine quit, ck eng lite goes out on restart
- nitrous on 230k ls motor?
- teh noobs gauge
- b18c1 valvetrain questions
- Distributor
- header question
- trouble shifting
- Wiring in VTEC?
- RHD Conversion
- Torque steer?
- New exhaust w/o muffler.
- raced my teg last night all of a sudden 3rd gear wont pull no more
- car won't start after installing air/fuel meter
- fuel shut-off?
- Should I buy the Integra?
- Acura Integra is the Most Stolen Vehicle!
- Help!!!!
- No power coming out of the fuel injectors - HELP!
- Passengers´foot space gets wet... =(
- Buzzing In Steering Wheel ?
- Turboed GSR?
- Coolant in Exhaust! HELP! 1990 GS 209K Mi.
- GSR Poll
- throttle response?
- modification suggestions
- Uberdata Basemap Solid CEL (Shmoo help!)
- question ?
- window regulator
- squeaky clutch?
- Please Help new to honda tuning
- Car won't start
- 94 GSR Front Lower Ball Joint Tools
- Fender, and bumper cover replacement
- TB Gasket Picture
- coolant loss!
- b18 or b16 in my integra
- Couple of Questions
- Getting closer with my 91 integra
- turbo info
- oil filter on gsr
- drove the Nurburgring in an ITR...
- Front speaker question/help
- motor moung ??
- Opinions on N-Tercooler by NX
- HELP!!My check engine light is on!!
- am I getting ripped off?
- Bye bye GSR
- Im to rich..ahh!
- Speedometer stop running!!!
- interior
- psi ?
- clicking noise
- Auto to Manual Swap
- Maintence Required
- accelerating problem
- runs for 10 minutes and then dies
- what type of setup would be best
- Timing belt
- clutch and Flywheel???
- 90 integra 4 dr swap with 97 gsr motor likely????? instructions????Guides????INFO pls
- ughh!
- Is XTD Clutch a good brand?
- Opinions on Big brake kits
- Type R wing HELP
- type R wing HELP
- Stock Bore of a GS-R???
- ls bogging when takeing off
- 94 GSR performance questions
- help!
- No power from VTEC
- Won't start after new half shaft installed
- New springs.
- lowering spring ?
- My speedometer is off by 10 MPH!!!
- need help with 90 integ transmission fluid and belts
- i need yur help integra owners
- b18c1 - msd ignition install
- engine "gasping" need help
- b18b or b18c pros and cons
- windshield water hose on passenger side
- ls block and b16a tranny
- 92 integra fan not working, because of o2 sensor???
- factory spoiler 2dr/4dr?
- Rattle after new clutch and flywheel--HELP!
- Sounds like a new exhaust...
- What is the paint code for ITR Championship White?
- do you know what color is this?
- Too rich and fuel trim malfunction
- Catalytic converter problem
- turbb
- Whats w/ the p.o.s Ignitors ? Whats their purpose. Why so carpy?
- my teg is grinding
- 92 atoumatic tranny or 94 tranny
- 2000 gsr turbo. Is $9500 a good deal with 69k miles?
- how to diagnose D4 light flashing on a '95?
- itr pistons?
- Help with 93 integra broke down
- Where to Buy 2 Step Colder GSR Plugs?
- 91 Teg ls running rough
- $^@*#!!!! Urgent clutch help, please!
- Some pics of my Type R
- does the DC short shifter come with a knob?
- failed emissions...can someone look at my numbers?
- headers.......
- superchager on b18b
- stock muffler dimensions
- Valve adjustment issue tip for those who been struggling.
- why do I have to rev my engine to set the idle???
- Adjustabel fuel pressure regulator
- grinding gears
- DIY header replacement help!
- Clutch&Engine mount problems plz help
- B18C1 Valve Cover screw up Part II (Schmoo, help!)
- your preference on clutch/flywheel
- bad smoke when starting
- looking for honda integra pics. please!!
- Is it really a Type-R
- Last year for Integra
- Bardohl's
- paint job on my teg
- Cracked radiatoR
- build 4 boost?
- Just turbocharged the Type R
- Stock P72 ECU on GSR motor
- TPS Question
- stock cd player code
- Clicking from door when i turn off the car!
- Will Trunk Supports From a 90-93 Fit a 94-01?
- Is the CTR and ITR JDM Momo steering wheel with SRS the same?
- Moonroof Problem
- Air bags
- Stick vibrates
- Stock GSR ECU wit skunk 2 manifold
- Port and Polish
- belt question
- replacing dash
- fuel pressure
- recharging ac on 93 integra
- what do u guys think
- 1000$ to spend
- motor mounts
- What would be the best bet?
- • Integra Tech: [Read and post your basic questions here.]
- GS stalling
- Boiling coolant????
- NGK Blue Wires Model # for 2000 GSR
- ECU Nightmare
- Question about Aftermarket Shocks
- B18C1 Head screw up
- plz help, trying to buy a integra gsr..
- more fuel efficient 94 integra
- WTB Piston Rings?
- Whats availible
- Destroy ABS?
- DSM 450cc Injectors
- ls with gsr turbo
- maybe i have a busted axle, but which one?
- Wheel hub assembly
- Omni Valvetrain???
- Door Lock Problem...Please Help
- Help! Broken Trunk Hydraulics
- Fuel Pump Relay
- Problems with integra please help, pretty please
- home made exhaust
- My teggy is shaky when accelerating and when idle
- LSD's
- clutch problem help now
- header torque spec?
- LS/Vtec Swap...suggestions?
- have some ideas, need imput
- one(1) bolt on distributor?
- A day at the track!
- my gsr dyno
- Cel 43
- vtec set
- Hello...just got a 90 teggy GS...
- 88 Integra Intermittently Won't Start
- ECU Chip for a LS
- Scraping noises from passenger rear...
- Looking For Reliable Engine Builder In San Diego/orange County
- 1995 Integra Ls Questions!
- Re-build engine
- relpacing stock front lip of 95 ls
- port and polish
- Gas Log over the last 3 months.
- JDM 4-1 HEADER & JDM CAT
- Help me with my Acura! =)
- 2 dr rear bumper fit a 4 dr rear bumper
- rear quarter panel
- 5w20 oil change in INTEGRA bad??
- Car not accelerating
- air intake question
- clutch
- New Suspension???
- Broken antenna mast
- axle back exhaust prices???
- would this work?
- stock integra rims
- Oil feed Line Turbo Leaky
- Power windows sticking on my ITR
- 90 Integra GS...won't start...got fuel AND spark tho...kinda like the 91 Integra...
- I'm sad, my car's too low
- GSR wheel stud and sway bar
- A/C Question
- Engine Rebuilding
- < Integra Tech Thread #1: [Post your SMOG questions here.]
- lsvtec
- ECU help!!!
- Another Pulley Thread...Grrrrrrrrr
- Video: Integra vs Viper
- Theft Prevention - Alarm vs. Pedal Locks vs. LoJack
- '91 Integra, won't start, no spark, dry plugs
- 1989 b16 head for...
- timing belt tensioner bolt rounded
- 98-01 Integra Hatch release question, how it works?
- Anyone know how to tighten the throttle cable?
- Just got me a 98 GSR SSBP
- Service connector location 94GSR
- Auto + Turbo good idea or...
- Computer
- All G1's came with Ford Wheels?
- Smoke from the exhaust
- Rear bumper cover
- 95 Integra LS: What is a reasonable price? (Not a for sale post)
- Corners Screw
- new clutch
- checking cel
- 1993 LS Gauge Removal
- confused about my new integra
- (plz help ASAP)so i'm about to install my kill switch...
- rebuild gsr or ls/vtec turbo?????
- Possible 1995 Integra SE (LS) Problems?
- b20 LS
- headers
- Rear trailing arm bushings
- Vtec mileage?
- Bore or Swap?
- bad track times 93s-r
- whub ub ub ub ub =(
- What Are Typical ITR Problems to Watch For?
- Turbo a 1999 Integra 4-door?
- my car cant get warmed up.....
- Need Mechanic in Orlando FL
- What exactly is a 1995 Ac Teg Special Edition???
