Is this a bad thing? I think it is...
On permanent hiatus
So, I was having some misfire issues this week after I put a new set of spark plugs in this weekend, so I took them out to regap them and look what I found:
The conductor has two fractures running all the way through it. What caused this on a new plug?
Heat maybe? :dunno:
Put in a new one and see what happens.
On permanent hiatus
Originally Posted by Exadar
damn man, no good... refund on said spark plug maybe?
Originally Posted by dubcac
Heat maybe? :dunno:
On permanent hiatus
Originally Posted by rugsr
Id put another one in and see if it does it again. How long were they in there for? If it does it again it may be cylinder 1's wire that could be causing it
If there is something wrong with your car that your cannot quite figure out internally it is going be taken out on the plugs when the cylinders fire. Was the car backfiring along with the misfire or just a misfire? Did you get on the car while it was still cold? You can crack a head doing that, maybe a spark plug too? I don't know...
