PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. Albany/Duralast brake pads
  2. type r five lug
  3. Radiator with oil cooler
  4. aebs intake manifold
  5. Re-Installing Shocks
  6. :Your Two Cent Please:
  7. Parts suggestion
  8. New to the Family, Basic simple bolt ons to gain hp??
  9. What parts to buy for ITR???
  10. Power steering fluid leeking??
  11. 2001 integra fender question????
  12. Vavle job needed in SoCal (Orange County)
  13. my radiator is finally starting to let go..
  14. are any of u guys looking to sell your seats?
  15. cv joint boots
  16. Integra Carbon fiber hood?
  17. Mounting tires
  18. Self Locking nut on Shock
  19. Racing ECU's? + MOre
  20. Integra tasty?
  21. How much to Replace Transmission and Clutch on a 2001 Type R?
  22. G2 Versions & Updates
  23. Hesitation under load
  24. Time for some new Rotors and Pads
  25. Any one with a white 95 gsr?
  26. Are they all at the same place?
  27. Rota Slipstreams or Circuit 8's?
  28. Break problem 93 Integra
  29. where to get fiberglass front end for a '94?
  30. License plate hole plugs; where to get them?
  31. Sleeved Turbo 2.0L Type R
  32. New to Integra, basic questions
  33. 2000 gsr cel on and throwing cel codes.Please help
  34. Year to Year differential Please.
  35. civic seats into integra fit right?????
  36. Oem parts
  37. horn & brake lights not working
  38. Need some advice on what to do, might buy a GS-R
  39. need to decide
  40. Wheel Help Please!
  41. Mugen Lip For 2nd gen?
  42. ABS code 8-2 ???
  43. My 96 ls special wont pass smog so...
  44. idle problem
  45. smogged today..high HC level
  46. motor mounts
  47. Pictures of our new Pro Street Online Project Turbo GSR
  48. Speedometer a bit off...
  49. Help! CARB/SMOG legal I/H/E setup for my GSR
  50. Tranny noise.....noise record included
  51. humming noise
  52. caliper hanging up...i'm at a loss...
  53. price for 97 itr?
  54. Q's For California folks
  55. Smog Help Needed.
  56. Crank Sensor
  57. Need Help and input
  58. apex rsm installation
  59. Helms Manual
  60. I Can Barely Hear VTEC, How Do I Get VTEC To Scream?
  61. Rally in east bay area?
  62. Brake Calipers
  63. Spoiler LED??
  64. Alright, if you had $15k to spend on a car and mods....
  65. recaros
  66. where to find the check engine light plug?
  67. ITR rear swaybar
  68. LS turbo Upgrade? Some Q's
  69. Removing the Resonator?
  70. aebs intake manifold
  71. vtec not working
  72. I found the #, yay!! 97 ITR # 345
  73. any consequences of a tight belt?
  74. Compatibility
  75. Front Tie Bar Help
  76. i need someone to run carfax
  77. sound deadening in trunk
  78. *** Important Posting Guidlines *** Please Read ***
  79. Car Dynoed...help?
  80. noob question?driving without gas cap!
  81. Timing belt parts needed??
  82. ECU Code #6 (coolant temperature)
  83. Elusive vibration problem in steering wheel and seats
  84. Help! New clutch cost?
  85. 1990 integra burning oil
  86. Opinions from owners of exhausts...
  87. Modding a 97' LS AT Teg
  88. Cold Air Intake
  89. Wierd "creaking" noise
  90. Anyone rockin'' Powerslot rotors on their ITR
  91. 95 rs running poorly
  92. removing rear wiper setup
  93. Torque Steer issue
  94. What kind of engine?
  95. Will this just bolt on?
  96. '86 Integra LS - Brake Lighting Trouble
  97. Installing power steering, need equipment
  98. GSR looking for better sound
  99. Tanabe NF-210 or TEIN H-Tech springs??
  100. 91 Integra GS Charging Problems?
  101. 91 and 94 integra have the same motor?
  102. difference among ITR years?
  103. I replaced O2 sensor and Cat Converter. Check engine like still comes on?
  104. i need some help with info.
  105. Getting new tires. Need advice
  106. flywheel
  107. HELP! Car Shaking after lowering
  108. Boosting a high milage gsr
  109. Value of a Mugen N1 ECU for DC2?
  110. Check engine light came on
  111. Problem With Brakes
  112. Serious problem w/ VENOM intake manifold
  113. '87 Integra LS Fuse Panel Diagram?
  114. ITR seats??
  115. Looking for Bay Area Junk Yards
  116. If you installed your exhaust header yourself...check in here.
  117. stuttering or misfire HELP!
  118. exhaust question
  119. Need help with immobilizer...
  120. Acura immobilizer questions...
  121. Bride seats
  122. Need Help. Engine Trouble
  123. Buzzing noise from engine compartment
  124. DIY air intake, Icebox style
  125. Spoon Crate Motors
  126. The Integra Movie
  127. Maintenance Q's for my new 95 Teg' please help
  128. price of gsr?
  129. so my exhaust...
  130. Tell me about LS Tegs...
  131. What do you clean your car with?
  132. One of them new fangled cars.
  133. hatch struts
  134. 2.0 or 2.5?
  135. Platinum Spark plug lifespan
  136. automatic gsr possible?
  137. im new here...and had a question...
  138. Smoking?
  139. How Much HP???
  140. TYPE-R b18c or c5?
  141. problem with typer
  142. b20 advice
  143. quick question
  144. Oil Leak
  145. How to organize car meet/stripping
  146. Almost got my Integra!! (noob) with Q's
  147. 5th gear popping out in Integra GS-R
  148. Spark Plug cover
  149. Some pics of my GSR Sedan & My formal introduction :)
  150. Sway bar setting
  151. SRS light??? what is srs
  152. Hondata questions
  153. Finally put my camber kit in yesterday
  154. A/C anyone
  155. GSR cam cap specs
  156. Strut and Sway
  157. Braille Auto RWD Integra placed 2nd at Falken Drift Showoff and set to podium again!
  158. All you AFC hackers READ THIS!
  159. emission problem
  160. so i drove my sisters g2 today....
  161. 1990 Acura Integra
  162. Aftermarket Sedan Exhaust = Retrofit Coupe Exhaust?
  163. Rear hatch struts??
  164. fuel problems need help quick !!!!!!!!!!!!!
  165. ITR test
  166. Engine troubles
  167. need different oil?
  168. Questions for Turbo Integra
  169. My Expo 4 videos & other tidbits...
  170. B18A vs. B18B
  171. engine swap?
  172. Winter Wheels and Tires
  173. "High Milage" oil............
  174. Need your opinions Please...
  175. Finally got the supercharger..
  176. Is engine braking bad for your car?
  177. Looking for small graphic of a teg
  178. timing belt
  179. new exaust but idles rough
  180. Timeing must be off
  181. turbo D16A1?
  182. this is unclear to me
  183. New member needs timing belt advice
  184. why does the "maint req" light blink?
  185. Whats the difference between a JDM integra Type-r and a uk type-r?
  186. Adjusting Clutch
  187. do i have to use premium gas?
  188. mitsubishi truck turbo
  189. who has the highest mile teg here? N/M
  190. Removing Dash Center '94 LS
  191. 95 Integra LS help!
  192. AEM C.A.I. trouble
  193. new guy here(wheel question)
  194. which header would you guys recommend?
  195. 1990 Integra LS.....engine dies after 10 mins.
  196. Hhhmmmmm
  197. Omni-Power Camber Kit?
  198. i found a sweet gsr need some help
  199. NEED HELP on Turboing a Integra
  200. engine swap
  201. What intake is better?
  202. New Teg owner
  203. 95 Civic springs on Integra
  204. VERY LOW 4DR = A lot of rubbing.... HELP!?!?!?!
  205. Noise when accelerating
  206. Light Idea!
  207. No Start 88 LS
  208. ACT or Clutchmasters??
  209. Having Problems!!
  210. Would this work?
  211. Clearcoat degrading, suggestions?
  212. Gsr Rebuild Incomplete?
  213. Flywheel: ACT Prolite or Streetlite?
  214. How much should i sell for?
  215. Just bought a teg
  216. 2004 ITR EXPO was great!
  217. Type R Spoiler
  218. Maintence light troubles
  219. Best Oil???
  220. fuel problems
  221. 94-5 GSR owners, we have something they do not!
  222. Miss Firing On All Cylnders... Help!
  223. Weird ticking noise after valve adjustment?
  224. A small comparison
  225. Wheel hop, NOT Launching
  226. O2 sensor wiring
  227. Volk racing TE37s, Bronze or Gunmetal?
  228. someone help! using touchup and sandpaper
  229. Can I fit 14" wheels on my 99 GSR?
  230. A Lap of Beaverun
  231. Expo Pics?
  232. LS VTEC or Build LS head?
  233. saying goodbye to the gsr....
  234. ls and gsr???????????????????
  235. Fuel filter
  236. 215/45-16 on Lowered Integra
  237. whistling after installing itr tb on my gsr
  238. Damn Water Spots
  239. act clutch for 01 gsr
  240. What's next for the teg!!??
  241. Strange Death
  242. Greddy E-Manage
  243. fuel pressure
  244. how beneficial is rasing c/r?
  245. B18C1 Valve Adjustment
  246. Idle overheat
  247. need help on how to get the rear wiper off
  248. SRI coolant drain?
  249. brake shudder
  250. hey whats up! new to the site...
