Timing belt parts needed??
Hi,
I've decided to to the timing belt myself on my 95' LS SE this weekend, I ordered the kit online that comes with the new tensioner bearing and water pump for $143 or so.
My question is, what other parts do I need:
Water pump O-ring?
Cam cover gasket?
Spark plug O-rings?
Do I need these? and is there anything else I should get?
thanks
Chris
Water pump O-ring?
Cam cover gasket?
Spark plug O-rings?
thanks
Chris
Didn't I just answer this the other day???
When I got a waterpump it came with it's gasket (O-ring). Call & ask the place where you ordered it?
Cam cover gasket & spark plug rings are REALLY easy to change later. You aren't hardly wasting any effort since the VC is so easy to take off. You'll see. I generally re-use that gasket a few times until it gets hardened with heat/age. Consider those 8 little grommets under the VC mounting nuts. Sometimes it all comes together as a VC gasket 'kit'.
Anything else? External drive belts? Cam seal plug? Leaking oil anywhere else? Since you have to drain coolant maybe that's an excuse for a new T-stat? It's pretty easy to think of 2 dozen other things to spend YOUR money on...
