- Hatch Tray Cover
- speedometer help
- *rant* Brakes suck
- i need help to buy a integra 95 4 door
- gauge cluster removal
- Some n00b questions about maintainence (gonna ship my car out of the country)
- Headlights, HELP!!!
- Tint allowance
- Who makes the best intake mainfold.
- b16a2 in my teggy
- Bone stock gsr 1500$ what to do?
- Got some Spoon sw388s
- timing redone but still having soem problems
- 1st gear lock out?
- ABS Code 1
- Car Alarm!
- help
- Weird Electrical Behavior
- 5 lug conversion
- 88' Integra RS 5 Speed......Hesitation Prob.
- service info
- Rocker panels
- Roll Cage Pics
- Getting my obd1 p75 chipped...what sensors to kill?
- looking to get your radio reception back?
- I may be going to the dark side...Testing waters on the GSR
- G2 and G3 strut/tie bars compatible?
- 01 gsr s2 im tb wtf???
- Where can I find a type R front spoiler lip
- Suspension Help!
- Ebay Screws up once again! Please Help!
- code 3, 14, 16
- Problems!?!?!
- Carfax
- How much should a 1st generation lip cost from dealer?
- 99' integra dist rotor
- 1990 Integra wont start
- annoying squeak
- LS VTEC Rod bolt HELP
- can anyone get carfax?
- I need Some Help With my car "Missing"
- Header question
- Maintenance Reqd Light Is Flashing
- running on 3 cylinders...
- 91 w/ 92-93 bumper
- What the hell...here we go again.
- Who makes the best header for 98 GS-R
- no spark
- Weekend Horror!!!!!!!!!!!
- 02 sensor situation
- Steering gear boot replacement question???
- fuel filter
- Sensor by crank pulley
- turbo with stock cat
- Reving W/ No Gas
- quick ECU question for JDM swap
- mid-90's integra vs Accord
- Can someone help me on how to change my engine mounts and motor mounts
- can i get a vin check
- car is running crappy
- My GSR's transmission self-destructed this morning...
- Please Help Me!! Car Wont Start
- best way to clean/engine flsuh u r teg ;` 0
- I'm replacing my wheel bearing today.
- New video of my R motor :)
- Custom exhaust materials
- Help w/ b18c werid noise
- Tweeter mirror mounts
- t3/t4....63ar or .48ar?
- another exhaust question thread..
- Auto tranny problem
- my new valve cover what you guys think of it
- Question...
- '00 civic si apex'i N1 99 spec coilovers on my 96 GSR???
- steering ratio
- 99 Integra - Alternative to Ugly Antenna
- Differentiating OEM vs. knockoff
- 94 integra door removal
- putting cams in
- time for a brake job...
- vtec solenoid
- timing belt
- apexi world sport 2 for greddy evo2
- Valve Seals
- B18c Engine Question
- Anyone paint in RI area?
- Home-Made Grille
- just a quick carbon fiber hood question
- supercharged ls??? anyone?
- Alternator Prob with 1990
- fuel injectors
- cat welding question
- Cat Back Exhuast
- Cooling fan trouble
- 93 acura integra with unknow engine over heating!!!
- turbo faxs
- How important to use OEM parts instead of aftermarket
- Clutch install now? DIY?
- Need Help with wierd buzz coming from GSR
- TB Bore
- Finally done!!
- automatic AND manual?!?!
- new adventure
- Suspension
- Spoon Engines
- what is hid
- Hydroplane + Wall = :-( *pics*
- oil eater
- axle Question
- new integra ls
- Distributor Cap? O2 Sensors?
- this is a little weird.. the spacer on my ITR mounting kit is corroded.. *pics*
- suggested camber angles for integras
- 87 fuse box diagram
- strange idle
- Genuine?
- civic raditor in an Integra
- AAAARGH ...ridin' on 2 studs and a nub!
- aftermarket gauges????
- 64mm Gsr Tb And Skunk2 Intake Manifold
- Need answers!!
- fuel pressure on a GSR
- Low Temp Gauge
- d16z6 plug wires on a b18c1???
- help w/ ordering parts using parts diagram
- How can I make my car more sellable?
- What does a B18 to a B20 block mean?>
- 95 Teg RS Heater problem
- Is this the right ECU? P75-A03
- Can some run a VIN test for me?
- Pics of Suspension Install...Thanks HAN!
- what do u guys think of this
- i need fenders
- Turn Signal Wiring Harness
- Timing belt went on 95 integra
- intake question
- 95 integra SE
- 96 GSR Sedan Value?
- Cat-Back Recommendation
- anoying rattling/buzzing sound....
- code P0141 even after replacing o2 sensor...
- Polyurethane Shift Linkage Bushings
- 89 Acura Integra Vs 96 Honda civic Dx?
- Need a new battery
- Gude Performance
- from auto to sport shift.. how much?
- Baaaaaaaaaad Turbo Fitment!
- Car alarms
- problem calibrating TPS?
- GSR engine temp
- temp question
- turbo rebuild
- Keyless Fob Question
- Hey I'm New
- turbo rebuild
- shiftlinkage question
- Clutch sensors. plz help!
- Bottom end vs. top end?
- Blew Headgasket
- Help with installing a new suspension kit !
- Valve job
- Starting Problem
- Lil problem
- my integra gsr is very slow!!!!! help
- Last week
- ECU Question????
- ITR Guage in GSR
- Clutch Question
- Oil in GSR
- CEL Code 89???
- Mount Bolt Size HELP!
- Apexi Safc...Would it benefit me?
- 99 hood on a 97?
- Headlight bad connection
- weight of stock gsr flywheel?
- '98 headlights on a '97?
- rebuild for turbo?
- Wheel hub!
- sway bars
- no spark cyl 2...new tune up, someone help
- i just found a ecu
- taking your advice
- B20vtec
- HID Questions
- 1990 integra clicking sounds when turing
- My Horn doesn't Work. Integra 2000
- Brake Pedal feels odd
- JDM B18c Compression low?
- Speedometer getting stuck?
- abs....
- power locks
- PCV valve picture please!!!
- GSR Shakes
- cheapest place to buy itr sway bar
- Codes
- 91 ls shifting problem
- Running like poo...codes...07..54..65
- best (cheapest) place to get OEM cap and rotor?
- Has anyone else experienced a "groaning sound" from your Integra while it's sitting?
- Is it the Strut/shock mount or Strut/shocks making this noise
- neuspeed front upper tie bar
- hondata s200
- Burning Alot Of Oil And Gas
- o2 sensor on 1993 teg
- Vin Check
- 94-01 integra with stock projector and HID
- injector question
- jdm 4-1 header
- clunking after shocks and springs
- How many cc's are stock b18b injectors??
- 93 Integra Ignition problem?
- 95 GSR problem
- remote start question..
- headgasket question
- help car stalled and wont start again
- thoughts about Type R springs on stock GSR shocks
- tranny service...
- Making a turbo exhasut
- Intake Manifold question
- tsudo exhaust
- Omni Camber Kit & Stock brake line holder ?'s
- D2 Racing Coilovers-Opinions
- Interior lights
- 98+ conversion
- Generally speaking - how much CF ?
- A strut bar is a strut bar is a strut bar?
- Does Suspension from 95+civic fit 94-01teg?
- All BOOSTED please look
- hows this come off(pic)
- Best place to get fuel
- H&R or Tein Basic's? Sounds like a good deal!
- is it worth it?
- All Turboed Tegs, question
- Is this bad?
- milky white ps fluid?
- water pump?
- Smoke from exhaust
- Master Cylinder
- What do you guys think???
- TYPE-Ruushhhhhhh
- 93 Integra stock tire size
- CF lip question
- gearbox stuff
- hoe much boost can you run on stock type r?
- 2001 auto tranny swap
- Help with front bumper lights
- Is this a good deal?
- Timing belt install next week
