Miss Firing On All Cylnders... Help!
Misfiring On All Cylnders... Help!
I have CEL codes 71,72,73 and u guessed it 74. I have replaced the plugs, and checked the cap and rotor which are about 19k old, wires are about 50k old 8.5mm wires. I threw in a fuel injector cleaner.. but still no luck. It runs fine when your on the gas, but I have no VTEC engagement and a sputter filled idle.
Let me know what you guys think. Thanks!
Apathy Kills
How many miles are on teh car in total?
This sounds like an issue with ignition timing.. perhaps the wrong heat-range of plug?
Did your old plugs look sooty and/or blistered?
Have you visually inspected your new plugs?
If they're fouling already, you may have more serious problems...
we had the same problem a couple weeks ago... i had misfire on cylinder one and come to find out it was the valves that needed adjustment..... i loosened them alittle and the cylinder started firiing.... but now we have and have had real bad valve chatter when under a load.... i am think the timing is off
