- Zex question
- Stock ride height
- Coilover installation help
- auto x tires
- 94 Integra GS-R Questions
- 1990 integra distributor interchange??
- Bump for the Vtec Engine Quality!!
- Integra Type R Picture (Update)
- JDM headlight wiring
- ECU/Capacitor problem
- thermal 3"s
- i need some suggestion on what i should do first on a stock r
- West Michigan Integra Owners?
- New Exedy Clutch
- Couple questions....
- Holding the flywheel
- Exhaust hangers
- z motor
- heads up on rear gsr seats
- Upgrade suspension
- door open wire
- What kind of computer is this???
- Any body want a Turbo Type-R??
- my weekend projects *PICS*
- OEM rocker panels
- Door Sills and other info
- Where are the best O.C. California import performance shops
- ITRCA down?
- Car vibrating at idle
- gear oil
- Tune Up Questions for a 98 LS
- pr4 ecu codes(trouble shooting)
- What If??
- Sideskirts
- Integra Manuals
- Please post LARGE pics of your race seats here
- Stroker Kit
- Cams for 94 teg
- itr steering rack ratio
- Hood latch
- s2000 antenna
- Power Steering and Steering rack ratios
- Took some pics and movies of my '95 Integra
- maf sensor on honda motors
- Lowest Drop
- cams question...
- Wing or No Wing?
- Typical Race Between RSX and GSR?
- wheels decision
- Light bulbs for JDM headlights
- Compression test results: plz help...
- 95 ls abs wheel sensor rr
- How low is too low.
- jdm headlights, condensation stains!!!
- rough idle> stall> sporadic start
- Can I join the Club: 98 GSR New Owner :)
- gsr vs ls/vtec?
- low idle?
- Rpm At 60?
- Losing coolant
- Nitrous VS Turbo
- A/T vs M/T #2
- lower front strut bar (pic request)
- blox intake manifold
- car trouble with cel
- canister and evaporative emission soliniod
- Rear upper arm to frame problem
- fuel pump problem
- s2k antenna on 94 integra
- evaporative emission purge trouble
- Timing belt tension adjustment access?
- A/T vs M/T?
- hey new to this forum wanted to say hi
- Type R TB
- HID for 95 Teg
- Starting Issue
- iacv valve
- 1997 ITR Washington
- Getting my car painted?
- Aftermarket Clutch
- Cams???
- DropZone coilovers?
- does anyone make a trans adapter for a manual swap yet?
- 500 whp
- Radio Malfunction
- What do you guys think of these?
- 92 Auto tranny, 4 door, worth modding?
- is STOCK ITR radiator any good?
- can someone scan me OBD2A and OBD2B diagram
- decisions,decisions....
- Is there really much u can do to 93 LS besides.....
- Cruise Control not working, need wiring help
- Power for FM Modulator
- OEM Switch
- Stock Clutch replacement vs Aftermarket Clutch Replacement
- How many miles did your teg go until you needed new brakes?
- Help its not bolt on
- Antenna
- ITR intake manifold on B18B
- knocking that isn't detonation... help
- Loose Steering Wheel?
- Stock Vs. Aftermarket Radiator clearance
- HAN Stickers
- Nitrous
- clean the IACV
- questions...(from a girl, since that seems to get more responses)
- Cel ?
- My R near Atlantic Ocean
- ITR running lean... any way to correct??
- Vtec engine swap to nonvtec & Harness questions??
- 95 Integra Special Edition (Any Thoughts for potential Buyer?)
- problems with my clutch
- Radiator overflow reservoir/fan questions..
- type r suspension mods
- B18B1 Air Intake questions (yes I searched forums already)
- Body shops in the NJ/NY area
- POS mileage...
- shifting problem after changing some stuff
- CV Joint Axel Question
- 97 integra LS auto miles/gallon....
- Transmission Question
- New member!
- Cam Gears
- Exhaust that came on my G2.....
- Light clutch
- Lighting Problem...
- Integra interior peice
- Grinding from 1st to 2nd
- Burning smell....
- Main relay
- Rota wheels: Are they good wheels?
- ECU wiring questions
- brake lines
- sound clip of flowmaster 40 series on integra?
- ***How do you tell if its a GS-R?***
- Blown CV Joint
- 1989 Integra
- Has any1 bought generic coilovers off Ebay?
- Summit Point Driving School (10/23-10/24)
- G2 cat-backs?
- 92 integra not starting..need help
- 94-01 Integras sought for Beta Test
- I Need Some Help!!!!
- Integra Problem
- 2000 Type R parts
- Body work
- hp gains?
- Need a transmission
- transmission
- AEBS still in box
- help a newbie (timing belt)
- New to forum and new Integra owner, has a few questions.
- Right front upper ball joint sounds
- steer me in the right direction.
- 1997 INTEGRA GS...A good buy?
- Brakes
- trouble getting into reverse
- High pitched "screech" noise @ 2500-3000 RPMs
- B18B Rebuild for Boost
- Car shaking/steering wheel vibration at 80 mph..
- Difference between RS and GS-R
- Please help: Broken brake master cylinder
- Hi, I'm new...
- Looking to buy TE37's
- 99 GSR has a minor backfiring going on...
- 91 LS doesn't like to start
- abs fuse?
- headers
- Type R 5 lug conversion concerning abs
- Info needed in Maryland and where can I find fuse box diagrams?
- 94-01 Integra transmission drain plug
- not running...
- 1990 Acura Integra won't start (starter motor not happenin)
- Oh... $hit!!
- do G2 seats fit G3?
- How Much could I sell my car for?
- Problems with Autometer Air Fuel Gauge HELP!
- Air Condition A/C problems. manual switch?
- Disconnecting ABS 92 teg Please help
- Rattling noise lfrom front passenger side
- JDM ITR front seats
- Diagnose my old motor. (pics)
- bilstein shocks
- GSR Turbo problem
- Results from Greddy Turbo Install (also not 56k friendly)
- Installing S2000 or RSX seats in integra
- bRAKE JOB DONE!
- 98 GSR Camber Specs
- 90 Integra cooling fan problem
- Brakes
- Good online part stores for Integra?
- Need some help
- Paint problems with my black 2000 GSR
- I need a new muffler.
- 90-93 Integra ?
- shift at what RPM for best gas mileage?
- wires and plug replacement time
- Need help on brake problem!
- Ignition wires
- Flywheel Question
- How do you install an O2 Simulator?
- b18b vs.b18a ?
- check engine light help
- Comptech rear sway/tie bar Q????
- Clutch Problems 94 GSR
- Type R AEM CAI intake filter Size?
- spun a bearing, bottom end needs rebuilding, which kit?
- maintence required light came on
- What do you think?
- where to get ITR tuned?
- 96 GSR: Clutch or Hydraulic Problem
- will they fit?
- How to check for cracks in the radiator
- Stiff or Rust stick shift......
- where can I tap into ignition wire in a 94 Integra?
- Clutch Setting?
- Timing Belt at 90,000 or 105,000?
- Axle and Wheel Bearing Problem
- Hooking up Autometer Air Fuel and Oil Pressure Gauge In Teg
- help!!!
- check engine light solved
- Where to buy high flow cat/ stock catalytic?
- im tellin u dawg.. its ur axlez..
- exhaust leak
- a grinding noise coming from the back
- OEM Shock lifespan
- Newbie needs help w/ignition kit
- Who could figure this out!
- ABS Question
- Anyone have the manual for the Comptech rear tie/sway bar?
- P72 Legit Auction?
- Article Notification: 2005 Integra Type-R Expo Information Announced
- 1990 integra won't run - fuel system problem?
- $10 for u if u can fix my problem
- ECU Scanner 3 Port Plug on GS-R?
- Boulder CO - Clutch Problems - Seeking Mechanic
- squealing sound
- Clutch Trouble
- CEL comes on at 550rpm..
- 1991 ITR firing order
- cel code
- tranny or gear problem???
- I'm torn between the 2...
- Greddy turbo kit
- which clutch is good
- It's Hot Dammit. Need A/C
- brake kits
- cruise control fuse on a 95??
