- 96 rs integra clutch problem
- brake issue
- Water in Integra headlights
- 2001 B18 to 1994
- Power Window Broken
- Water In Integra Trunk
- 90 Pass auto seat belt stuck-
- ATS 4.928 final drive
- 98 Integra - Burning smell
- hows the skunk 2 intake manifold on a gsr integra
- Synthetic AT Fluid for Gen2
- Resonated Test Pipe
- 98 Integra LS mis-fire problem
- 1988 Integra Restoration Project
- 2000 Acura Integra Fender Removal/Replacement
- 92 LS Starts Then Shuts Off
- Point me in the Direction of...
- Transmission Axle Seal Leak Dilemma
- 98 GSR Check Engine Light ?
- '88 Integra Running Slightly Hotter After New Radiator
- 94-97 teg front rotor same for LS and GSR?
- Timing belt loose with pics..WTD?
- Still Got the R (Two Pics Inside)
- Stereo Head / Ebrake question. + Maint
- Suggestions?
- Question about '94 Integra radiator mfr.
- Fuel Pump / Relay
- Wheel bearing ?
- Rough Idle. Sell or rebuild?
- Misfire - stumble
- Noise from trunk/rear seat when car is shut off.
- Clutch ??
- Rattling noise under hood near firewall
- Help. Can someone recommend a SF bay area shop to resurface a flywheel?
- Stolen: 1990 integra rs
- Touch-Up Paint - Online Source?
- Options for broken front lug
- How to retract the rear brake piston 2001 Integra
- turbo install step by step
- Brake Pedal Slowly Goes to Floor
- 95 GSR shut off on freeway
- how do i remove the transmission plug on my 1991 acura it is not coming out
- 94 Integ Rs Help!!??
- Help w/ Swap: B18C5 into 1988 Integra RS
- wheel clear coatings
- What Next? to Fix Dipping/Low Idle on GSR
- Need trunk light ass'y for 3 door hatchback
- P0141(oxygen sensor) Issue tried everything
- Auto to Manual
- smoke from oil cap
- ECU Code 22 - VTEC Oil Pressure Switch
- Help me plz!!!
- 91 Integra Brake Bleeding
- Misfire v. Plug Wire
- 90 LS starting problems
- B18a1 tdc
- i fanaly blue it up lol after 6700 miles
- 90-93 integra gauge cluster pinouts
- Short shifter
- 94 LS project, where to start?
- Is This True?
- 90 Integra ABS relay
- Multiple Questions.
- I Have A ?
- 91 integra starting problem
- not a clue [95 integra]
- idle problems with my b20 integra
- 98 integra distrubitor ????
- Resonator Question. Removal or replacement?
- Need help i am going crazy!
- Why do i keep burning up alternators?
- Speedo not working
- 92 Integra won't start
- 98 GSR Check Engine Light?
- quick distrubitor question
- 98 Ingegra gs oil pan intall
- 99 GSR Axles Shot
- Electrical Problems Spreading on 1988 Integra; Time to Pull the Plug?
- Are these any good?
- Horrible Grinding/Vibration From Shifter at Hig RPM's
- Blower Motor Air Flow Weak After Installation
- A/C Causes Blower Motor Fuse to Blow 1988
- One Question?
- Update on 98 GSR
- tps sensor
- I Have a question need help with ??
- Lighting Helper arrived!!
- Valve Ping
- AEM FPR orifice verification...
- 2000 GS wont start
- Good boost kit for an LS
- which motor should i get, i plan on boosting which ever.
- Issues with Map sensor Voltage.
- Vtec not kicking in... Anyone any thoughts?
- Walking timing belt
- Headlight Condensation
- Need a Dizzy 98 GSR
- Help a guy out please, anyone got unlimited CARFAX??
- Can't a GSR use a Type R?
- Fuse Keeps Blowing
- Have anyone used Accell Wires?
- Integra Headlight Bulb
- whats it worth
- GS motor swap
- gsr stock block
- radio turns off after few seconds
- code 13 message
- 1995 integra ls attenna?
- 1988 Blower Motor Troubleshooting
- Bent Wheel Woes: A Cautionary Tale
- P06 ecu
- help CRANK QUESTION
- b18b dark spot on top
- Factory Service Manual Download
- Time for Motor Rebuild
- 92 Integra LS Won't Start
- 98 GSR Oil pan gasket questions?
- B181A vacuum diagram
- Roof swap?
- Maintenance Schedule
- gsr block with spun bearing?
- 96 Teg 4-door GSR trailer plug
- timing issues head/jumped timing help
- Car Running issues
- trunk latch?
- No power anything now
- 97 gsr block
- 1988 Integra Radiator Replacement Problem
- Steering Rack and Bearing Questions
- Sleeves
- Looking to Buy.
- 98 gsr?
- integra 95 trouble with interior, trunk, and side marker lights after smog..
- type r lip material
- '91 Integra GS Hubcaps Theft
- R/R of headlight/turn signal stalk...
- bored out ls question
- type r block gsr head timing ?
- ls vtec question regarding rods, bearings, etc.
- ls or gsr tranny?
- Stock FPR comparison...
- Idle issue
- B18b1 Engine horsepower
- 91 DA help
- Gorilla wheel locks, but no key...
- help
- type r wheels knockoff (look alikes)
- Cracked head and ding on block
- Reliable Body Kit Sites Please!!!
- 95LS Front Driver Side Brake Pad Wear
- got HID light kit...
- 94 ls sedan trany swap?
- Timing readings off? The cause?
- Underbody paint (subframe)...
- integra s15 front end
- Automatic transmission slipping
- Integra Electric Condenser Fan stays on
- altenater
- How to remove...
- 99 Integra CD Player
- Higher compression/Tune?
- would a 94 ls head fit a 1993 block
- floor mats
- obd1 to obd2 valve cover
- Integra over heating
- Timing HELP
- Replaced Oil Pump; Still Have Oil Indicator
- 1998 Integra ecu question
- Greddy Emanage
- Poll: Which ITR to buy???
- quickest way to twist
- Short Throw Shifter
- Does It Matter on OEM Parts GSR ?
- flame outa back when i shift
- 94 ls motor [Which ECU?]
- whistle/whimper?
- turbo gsr.. bad missing link?.
- Radiator Hose?
- Rear brake wear issues
- Skunkworks 22mm bar and ASR brace...?
- Which one would you guys choose?
- integra vibrating
- Prepping used windshield for install...
- '93 Integra shimmy repair
- Sunroof maintenance...
- Powre steering
- 91 vacuum line issue
- Question about Stock Stereo
- Painting 95LS Outer Pieces White
- A/C compatible turbo manifold?
- How to check the engine light on 00 LS?
- Sparkplug Wire ?
- The infamous ckf bypass trick..
- lighter socket!
- Help on Acura Integra Type-R Passenger Window. (NewMemb)
- Power steering leak
- Where DO?
- tmperature problem
- Air in Cooling System
- tire popped, tire size question
- Exhaust rattles at several different RPM ranges.
- 93 integra won't start
- oil problem
- n/a jdm b18c build...
- Quick exhaust question...
- please dont cut off
- DA9 not starting
- Both cars stolen (Cash reward)
- E-Brake Handle Cover and Boot
- Compression question for ls vtec
- Lug Nut Help
- HELP! 1990 teg hard click wont turn over
- Running rich and weak vtec crossover with Junk2 mani on my gsr
- After market endlinks
- b16a1 motor and tranny needs a new home
- Lsd ?
- 1990 integra question, need info
- Brake issues
- Question about CYP, CPS, & TDC sensor specs. Plus testing procedure.
- Source for sensor testing & specifications?
- Bad cat?
- AutoMatic Ls VteC Build!!!!!!!
- Radiator Crack
- Need Check-Strap
- Troublesome Motor/engine mount '90-'93
- beep beep beep......
- Water in Trunk
- How Do I Take Off ?
- Help with 2001 Integra Alarm
- 94 Integra Lx Maintence Question
- brake fluid
- Sudden engine problem + Code 71 (2000 teg)
- new member + need help finding this engine part
- Ideas on Integra Performance Parts
- Help 98 GSR wont turn over?
- HID Issues, Bad Ballast?
- Is this good or bad??
- need a little help car dosent stay running?
- Replacing oxygen sensor-`98 integra
- follow up to car hooking left
- clutch
- Headlamp Bulb Issue
- interior light wiring?
- Annoying Rattling 3000-3400RPM 96 GSR
- Is This Good For A GSR?
- Noise coming from brake pedal?
- Integra Thermostat Temp
- anti theft radios
- Clutch issues
- intake manifold
