PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. 92 Integra auto to stick conversion
  2. 1990 Integra Needs New Motor
  3. Help with electrical issues!
  4. Where is the OBD data plug?
  5. Trouble Code 65??
  6. Timing and breather filters
  7. 93 integra OBD port location
  8. Disappearing oil
  9. Wrecked 1996 Acura Integra
  10. Fuse Keeps Blowing Need HElp
  11. Sunroof Problem with my new GSR.
  12. usdm type-r
  13. I just bought 93 integra misfiring
  14. Clutch squeak, changed master/slave cylinders, still not helping.
  15. Help With Egr Valve
  16. Paint and body work
  17. in need of a b18c series head
  18. Exhaust problems
  19. what's the cause
  20. Son broke 2001 OEM taillight, car fails inspection
  21. So, my car failing smot = bad cat :oh:
  22. My suspension is P*SSING me off advice plz
  23. Rear Trailing Arm Question
  24. Back in the Honda Community..1st post
  25. Im poor!!!
  26. Broke Diff Housing 90 Integra
  27. DA swap
  28. Bad CV Boot/Axle?
  29. Evaporative Control Canister??
  30. Type R vs S
  31. Are these good?
  32. B16, CEL 1, new o2 sensor, same problem...
  33. Newbie Question, Oil Change
  34. Tach-o-my god
  35. Shaking when I drive
  36. simple question
  37. Quiet GSR Header for Gas Mileage
  38. Am I being scammed? Firestone replaced distributer, now recommend Crank Sensor!
  39. header wrap?
  40. ABS Issue
  41. OMG supension issues maybe?
  42. Emergency, car just broke down! Please Help.
  43. Swapping auto for 5 speed
  44. Clutch problem
  45. dc headers
  46. Sketchy Advance
  47. I turboed my integra
  48. CF Spoon Style Front Lip
  49. 95 acura turn signal/running light problem...
  50. car question V.battery?
  51. Identify this clutch noise (.wav attached for listening pleasure)
  52. I need help with putting on new power side mirrors
  53. Drivers headlight issue.
  54. Integra´90 walbro fuel pump installation
  55. 99 Integra driver side door lock sticking
  56. 99 GSR keyless entry problems
  57. Does Integra have Mass Airflow sensor
  58. coolant leak...need help!
  59. new gauges
  60. Can someone help me with a Cold Air Intake installation?
  61. Auto VS 5 speed
  62. wire tuck questions
  63. Newcomer to the self repair scene
  64. Ignition And Injection Problem
  65. 92 GSR leaking Power Steering pump
  66. Anyone Know?
  67. should i install the new exhaust before i lower my car?? [Merged]
  68. fuel filter
  69. Question about lowering a Type R
  70. Requiem for a machine bolt: DC Integra owners take note...
  71. Need Help 91 Integra problem
  72. Clutch options?
  73. wired trans issue i think?
  74. Suspension question?
  75. Supercharged injector question
  76. Fog lights is their a way to test?
  77. Which one goes where?
  78. resistor help pleasse!!!
  79. ABS Light, BRRR! activates every stop..
  80. Compression Numbers for ITR
  81. Where can i get oem lips for my teg?
  82. cleaning throttle body
  83. CF Gurney Flap/Wing Extension for Stock ITR Wing
  84. Weird knock from brakes?
  85. quick brake question
  86. A/c Belt????Help
  87. 91 integra halo light removal
  88. help with 93 integra turbo ls
  89. Paint jobs?
  90. Si/gsr - Type R shockers?
  91. 90 Integra Transmission Stuck in Drive
  92. Cat Converter / Collector questions
  93. auto transmission shifter lock
  94. engine questions- 1990 acura integra
  95. Trunk will not lock but cannot remove lock mechanism
  96. DIY for HID conversion kit for '98 teg
  97. Oil Consumption
  98. B18C1 Help
  99. How to replace climate control fan speed switch
  100. clutch needs more play?
  101. Head question
  102. proper valve cover (gasket) torque
  103. I need help (fog harness)
  104. whistle sound?
  105. passenger seat rattles and moves
  106. Matience light wont turn off
  107. front end shakes
  108. More horsepower out of an N/A B18
  109. Need some help regarding the Comptech Icebox Air Intake.
  110. Good Performance Part for $500
  111. Need help with Cigarette Lighter
  112. airbag
  113. integra smoking bad....need help!!!! asap
  114. Stock Rebuild...Slight Compression Raise???
  115. Brake Master Cylinder tips
  116. moisture build up
  117. rota rims
  118. HOW to change tail lights
  119. ls to ls/vtec
  120. exaust installation instructions
  121. Valve Question?
  122. 95 teg not blowin heat
  123. 94 to 99 engine swap
  124. help help HELP!!!!!!
  125. Ah Stupid parts, need some help with parts.
  126. Verifying if this is simply a case of a broken ignition switch or worse...
  127. GSR AC Idler pulley assembly
  128. Passenger wheel feels loose
  129. header???
  130. whats better and why?
  131. Help with valve cover bolt
  132. i need help with fixing my 94 integra ls
  133. Power Steering Rack Boot
  134. I Got A Deal
  135. Update of my Turbocharged 98 Type R
  136. Injen cold air intake
  137. ALB light on 1990 Acura
  138. will these wheels fit????
  139. door fitment
  140. Need Help Removing Bumper Lights
  141. Turbo stock ls or bi8c1 or c5 swap?
  142. GSR Axles
  143. Machine Shop
  144. tire size
  145. spark problem
  146. gsr engine stalls at idle??
  147. rear caliper bolts striped. help guys
  148. 95 acura integra needs brakes
  149. Ball joint boot
  150. Hey guys question about new Pulstar Plugs
  151. 90 Integra ABS Problem Help!
  152. Acura Integra Radiator Replacement Instructions over the net, anyone?
  153. Belt Chirp
  154. p1361 sensor internittent interuption
  155. Wondering about possible mileage tampering
  156. 95 Acura Integra LS making LOUD Squeaking Sound over speed bumps!! HELP!!!
  157. Cam'ing my B18C2
  158. LS-Vtec
  159. Clutch replacement time
  160. How To change regular dohc to vtec dohc
  161. Power locks not working?
  162. water leak in car
  163. How can my ecu go bad?
  164. 98' 328is vs. 96' Integra
  165. whats yours mpg on your integra?
  166. replacing passenger fender on 00 integra
  167. acura parts
  168. Carbon-Fiber Fenders
  169. Dead Battery or Current Drain
  170. Bought a CAi, no Im scared..
  171. transmission question
  172. motor mount inserts
  173. Engine hitting hood on 92 integra
  174. Overheating smell on 95 integra
  175. Integra LS "Special"
  176. Clutch engagement
  177. stock motor? put a turbo on it!
  178. b18c1 rebuilding questions.
  179. B16a running problem
  180. b18 ls build question
  181. alternator problems maybe
  182. Turbo Sound
  183. b-series on engine stand
  184. quick question...
  185. Broken Rotor.... Bad Distributor Bearing?
  186. Intake fitting question
  187. 2000 5sp Questions
  188. gsr gasket set?
  189. ABS Sensor Problem
  190. Fill in My trunk!
  191. question about porting heads on a b16a
  192. Keeps stalling
  193. Brake/Tail Lights Malfunctioning
  194. gsr turbo
  195. Identification of 4-door 1995 Integra Model
  196. Stolen White 4dr, SF Bay Area [Recovered]
  197. Rare B18C with SKJ labelled gear box -LSD
  198. 97 LS Headlight enclosure
  199. Window Molding
  200. Harmonic balancer trouble
  201. Left Blinker is Faster Than the Right
  202. maintenance light is blinking 10 times.
  203. I took Have no spoiler, help?
  204. Best Place Online to buy Sylvania SilverStar bulbs
  205. Clanking Noise
  206. changing obd0 to obd1
  207. 96 GSR Turbo, Now back to stock and no oil pressure???
  208. neded to know
  209. LS with Type R Transmission.....Clutch Choices????
  210. cosmetic help
  211. ITR Sedan?
  212. new, please help
  213. Getting 250 miles per tank..... 24 mpg
  214. Radiator fan not working
  215. 06 si foglight install on 95 teggy
  216. 90-91 and 92-93 rear bumper difference?
  217. engine mount help
  218. time for her to go
  219. Camber kit
  220. 92 integra unsolved frontend vibration
  221. heated seats
  222. Which suspension to get???
  223. Cam Gears?????
  224. help installing integra type r gauge cluster
  225. Greddy SUS Header for 94-99 RS/LS
  226. teggy oil pan gasket
  227. 93 seats in a 94
  228. Help engine is making a weird noise
  229. B18b in DA9 help
  230. is my timing off??
  231. Need some handa guru help please.
  232. 94 integra
  233. need help with TYPE R 4 Lug Conversion
  234. High Flow Cat
  235. anti lock brake pressure issues
  236. Trouble starting 95 gsr.
  237. No Brake Pressure
  238. 92 GS with b18c1 ecu trouble
  239. Confirm Bad Clutch MC -- pIcs inside
  240. Ignition Timing problem: won't advance enough
  241. Just installed 1.8a1 wont rev past 3500
  242. Need to replace ball joints. lil help!
  243. Need motor history if you can help
  244. Steering issue
  245. Alternator?
  246. 1989 integra steering knuckle??
  247. 92 1.8 DOHC, low power/hesitation under 2500RPM
  248. tranny problem...shift linkage problem...
  249. Pulley snapped on 95 GS-R(type r replica)
  250. Clutch and Flywheel Reccomendations
