Brake Master Cylinder tips
I have a 94 ls 4 doors auto with a bad brake master cylinder. Anyone has instruction on how to replace it as well as anything I need to pay attention while working on it? Can I buy it from local auto parts store or I must buy it from dealership. Thank You.
Tips: do some research on bench bleeding the master cylinder, bleed the entire brake system for air, hand start all your brake line fittings so you do not cross thread them, don't adjust your master push rod until you are sure their is not air in the system if you have to adjust it at all. If you do adjust it make sure you do not have brake drag.
I like oem parts.
I like oem parts.
