is my timing off??
i did a tune up to my car changed plugs, wires and o2 sensor but my car still kills gas, i recently got a 00 ls head put on with new timing belt my car when it worms up it runs at 200 rpms or 1 line up from the off line. does that mean my timings off?
You would need a timing light. Hook it up to your battery the other lead over your number one spark plug wire. Flash it at your crank pulley. The pointer should point at any of the 3 red marks.
Now if its off your cam timing would be off a bit or your ignition timing is off.
If you never set your ignition timing in the first place, or you need to reset the timing belt, you need to get a timing light, rent one from autozone, or borrow one. The cheapest type will work just fine.
It sounds like you have other problems though, more than likely cam timing. Pull your valve cover, align the crankshaft pulley to TDC and double check the marks on your cam gears. I'm willing to bet this is your problem.
Buying the HELMS is certainly a good investment, but heres a link to download it in PDF format, they require you to register first though.
- http://www.hondahookup.com/manuals/
And here is a step by step on how to replace the timing belt, just follow the steps you need to verify yours is installed correctly.
- http://www.team-integra.net/sections...ArticleID=1044
