anti lock brake pressure issues
Old Dec 4, 2007 | 12:10 PM
bosko81's Avatar
bosko81
Default anti lock brake pressure issues
1991 Acura Integra GS. Almost every time I start my car and am in low gear, the anti lock brake system creates a vaccum to create the correct pressure in the system. This should not happen every time I start up, just once in a while. Do I need to replace a hose, motor, sensor...??? Maybe slam on the brakes at speed to activate the system to reset the pressure?
Old Dec 7, 2007 | 05:36 PM
Spec R's Avatar
Spec R
i dont remember off the top of my head if the 91 gs abs systems had a fillable fluid reservoir for the abs module. if it does, give it some fluid.
if not, try doing a brake fluid flush of the whole system. do it with the car running, so there is vacuum assist thru the booster. it'll help move the fluid through the system easier.
DB Squad
Integra Forum Moderator
