95 Acura Integra LS making LOUD Squeaking Sound over speed bumps!! HELP!!!
Old Jan 22, 2008 | 01:19 PM
chrisco455's Avatar
chrisco455
Default 95 Acura Integra LS making LOUD Squeaking Sound over speed bumps!! HELP!!!
Hey guys. A couple of months ago a very LOUD squeaking sound starting coming from my front drivers side wheel. It is especially loud when you go over speed bumps. It also makes the loud sound when i make a sharp right turn at 25-30 mph. It sounds like a very loud bed squeak. One mechanic said that it is my hub bearing that is the problem. But another one just said that it was the cold wheather that is making it squeak. That didnt seem right to me... cause the loud squeaking is only coming from the front left side. Anyway. Does anyone have any incite on this matter? Should i just be getting my hub bearing replaced? Let me know what you think guys- Thanks!
Old Jan 22, 2008 | 04:15 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Do you have aftermarket suspension or stock?
Old Jan 22, 2008 | 07:11 PM
Venom62's Avatar
Venom62
If it was the bearing it would probably be making more of a growling noise at 30 mph.
Old Jan 23, 2008 | 12:18 PM
Lynxs1981's Avatar
Lynxs1981
Do you have urethane bushings in it? Mine squeaks a bit when it gets colder.
Old Jan 23, 2008 | 02:24 PM
chrisco455's Avatar
chrisco455
Nope , No aftermarket parts.... suspension... nothing. I should have specified that it also makes a grinding sound alittle when I make that turn. So i guess that makes it hub bearing... but would that also make the loud squeaking sound when I go over spead bumps?
Old Jan 23, 2008 | 05:33 PM
Line7's Avatar
Line7
Platinum Member
Ohh, bearings do indeed squeal.
Old Jan 24, 2008 | 07:00 AM
Lynxs1981's Avatar
Lynxs1981
If its grinding, then its most likely a bearing.
Old Jan 24, 2008 | 08:58 AM
chrisco455's Avatar
chrisco455
So it could be the bearings as well making the squeeking noise while going over speed bumps?
Old Jan 24, 2008 | 06:35 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Check your LCA bushings. They are probably worn out. I was having the same issue.
Old Jan 28, 2008 | 04:05 PM
chrisco455's Avatar
chrisco455
Could you explain to me what LCA brushings are? And also, what is the severity of my situation involving this part. Am I at risk of my having my wheel fall off while I am driving?? Or is this a simple non vital fix?
