Camber kit
Old Dec 11, 2007 | 07:12 PM
perrotto's Avatar
perrotto
B18C1
Default Camber kit
10_2.jpg...90 91 92 93 INTEGRA FRONT REAR ADJUSTABLE CAMBER KIT...I bought this kit which comes with 4 pcs for the front and 2 for the rear. The ones in the rear replace the control arms. I haven't figured out the ones in the front. Any thoughts...???:hsdunno:
Old Dec 12, 2007 | 08:46 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Where did you purchase them from? I'm sure the info is on there or you can look up the info on the kit by the brand..........unless it's one of those ebay no name things.
Old Dec 12, 2007 | 10:42 AM
they replace the ball joints ... look like low price stuff though, normally when you buy a quality camber kit, you are buying the front control arms with adjustable ball joints. could use a better pic of the ball joints to give you a better idea
Old Dec 12, 2007 | 07:27 PM
perrotto's Avatar
perrotto
B18C1
It's not going to fit where the stock ball joints are...I did buy them from ebay...I guess I should have bought the whole deal with the control arms included...:upset:
Old Dec 13, 2007 | 06:13 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Looks like an ebay special. I would scrap it and opt for a Skunk2 kit if you really need it. Why do you think you need a camber kit?
Old Dec 13, 2007 | 12:32 PM
2001TEGGSR's Avatar
2001TEGGSR
Camber kits reduce UCA to shock tower clearance. Even on a moderately lowered car, they will cause problems. They are usually not needed, just get your toe set to 0, and rotate your tires often.
Old Dec 13, 2007 | 05:22 PM
perrotto's Avatar
perrotto
B18C1
The guy @ C & J Tires said the only way to adjust the camber angle is to get the adjustable kit...Is this true...???The toe was zeroed...It just feels funny when I have to crank the wheel all the way in one direction to make a turn...
Old Dec 13, 2007 | 05:24 PM
perrotto's Avatar
perrotto
B18C1
My toe was @ zero about 2 months ago...It should still be fine, right...???
Old Dec 13, 2007 | 06:16 PM
Provocateur
On permanent hiatus
It is true but why do you have to adjust camber angle? With negative camber, you should have better steering response.
Old Dec 13, 2007 | 10:30 PM
perrotto's Avatar
perrotto
B18C1
I was worried about tire wear...I was unaware that I would have better response with a - camber...I guess I'll leave well enough alone...Thanks for input...I would truly be lost w/o this website...:woohoo:
