Clutch and Flywheel Reccomendations
Old Nov 27, 2007 | 12:04 PM
ENFORCER's Avatar
ENFORCER
Default Clutch and Flywheel Reccomendations
I just purchased a 1990 Integra RS for $2000. The body is mint... 107k original miles and the entire car is totaly bone stock and very well maintained...... except for the clutch. I was wondering if anyone has had any experence with Ebay clutches and flywheels before. Do they hold up? Are they good for the money? Theres so much crap on there its hard to tell the good from the bad. Oh and here is a link to a pic of the ride sitting at the "dealer".
Old Nov 27, 2007 | 03:08 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Exedy or OEM replacement.
I wouldn't trust a no-name ebay clutch.
Old Nov 27, 2007 | 04:36 PM
ENFORCER's Avatar
ENFORCER
What about Beck/Arnley? RockAuto has a clutch kit for 128.... Not sure if thats OEM equiv?
Old Nov 27, 2007 | 04:57 PM
Provocateur
On permanent hiatus
Check this one out. That is what I would use if I were in your situation.
Old Nov 27, 2007 | 06:19 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I have this set-up on my 99 GSR. No complaints. Good OEM replacement and the flywheel is easy to drive on. Not like most will say about stalling and what not. Honestly, I never felt a difference in the driveability. I felt the change in performance when I gave it some gas for the 1st time. but other than that it drives great.
Old Nov 28, 2007 | 04:32 AM
ENFORCER's Avatar
ENFORCER
Yup I had seen that combo on there. Is there any difference between the flywheels with milled teath or press in/bolt on? The only reason i ask is that there is another combo here with an F1 flywheel which has milled teeth.
Old Nov 28, 2007 | 06:42 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
exedy clutch with oem itr flywheel im running and its been 100k so far still like day 1
Old Nov 28, 2007 | 08:16 AM
MC-14's Avatar
MC-14
Tri-man
Fidanza flywheel and Exedy clutch works pretty good. I have this setup in my boosted Integra GSR. You get good contact and it's pretty easy on the leg as a DD. Although, it does chatter a bit in a boosted integra. Just a little getting use to, but acceleration gains are pretty noticeable.
Old Nov 28, 2007 | 09:15 AM
mberndt's Avatar
mberndt
Why go so cheap on a vital engine part?
I have an ACT clutch and had it for ~80k miles.
I'm boosted now too and it has never slipped.
I have the ACT heavy duty pressure plate and organic street disc.
Of course I paid ~$520 for it 6 years ago but never once did I have a problem.
Old Nov 28, 2007 | 10:17 AM
Provocateur
On permanent hiatus
It is an OEM replacement. It shouldn't chatter at all.
ACT is way overkill on a bone stock motor. Even I wouldn't pay the rediculous amounts again for an average clutch. I'm going with a CC Stage 4 for my build...much cheaper for a better product, IMO.
All the OP needs is an OEM replacement clutch.
